Cannot launch my E92 335?
01-02-2012, 01:35 AM | #1 |
Rep 40
Ok... so I've had a read on the forums re: launching, etc., but still having problems with launching my car.
I have a 2007 E92 335i with the steptronic transmission. I've tried... 1. Launching by just 'hitting the accelerator' in D/DS/Paddle, with both levels of traction control turned on/off 2. Launching in 2nd gear (using paddle shifters) 3. Holding the brake down until 2-3rpm and then letting go In all of my tests, the car just will not launch off the line. No tire slip, no quick acceleration. It just 'thinks' for a second and then takes off. Once it gets going it accelerates fast, but it just won't launch. If it's a rolling start (e.g. slowly taking a turn and then accelerating) I can get it going as quickly and with as much wheel spin as I want. Any thoughts? In case it's related -- my HPFP is playing up, although it seems to fix itself when I turn the car on/off. Taking it to the dealership next week. |
01-27-2012, 09:12 PM | #2 |
16
Rep 328
Drives: 2008 BMW 335i E92 6 MT
Sounds like the following but hard to tell from your description:
1. Throttle response switch may be bad 2. Check for boost leak 3. or transmission ..... If under warranty take it to the dealer and have them check the throttle switch/sensor or whatever it's called now a days.
.../// TURBO! Why in the world would you choose anything else?... /// |
02-09-2012, 03:56 PM | #3 |
Rep 1,404
Hmm,
Here's a thread that my interest you: http://www.e90post.com/forums/showth...launch+control See post #7. I've used his technique and works for me. Check it out and report back your findings.
Name: Blanca | 07 E92 | AW-Blk | ZSP | Alcon BBK | M3 Bits | VM RR Links | Koni | UUC Sways | V5 | Dinan CAI | ETS IC | Fge DV | ER CP | Cyba | Raden. Exh | Mod Step | Trunk Drawer | Perf LED Wheel | Illum Dr Sills | IS Shifter | Parrot | Philps D1S | 6000k fog | MTECH RR | CSL Trunk | Aero | Roof Spoiler | PSS on BBS RS-GT 19s
