Jb4 issue!
01-02-2012, 05:04 PM | #1 |
Rep 44
Jb4 issue!
Hi everyone,
I installed jb4 today morning, everything felt great until later when I went WOT on freeway, the engine started shivering, Ses lit up and it remained that way. I exited , thought It needs time to get used to and went on to delete codes and start driving again, softly. I went wot again on a ramp, the same issue popped again. It shakes and throws Ses light when ever I go wot. All this in map 1. So shifted to map 0 , all\'s fine. Tried the map 1 again with same results at wot ( Ses and engine shake) I checked the codes 29f3 and 29ce popped up! Some one help me! Mine is still under CPO warranty. |
01-02-2012, 05:07 PM | #2 | |
3441
Rep 79,211
01-02-2012, 05:12 PM | #5 |
3441
Rep 79,211
You have a few options to fix your problem.
First and foremost re upload your firmware. Either swap your coilpack 2 to 3. See if problem goes away. And OR/ get new sparkplugs. They should be changed ever 25K. Your one code was something fuel related but its probably nothing. The other was misfire cylinder 2. 9/10 people on used vehicles need to replace sparkplugs before a tune. In fact it should be mandatory with the amount of threads and problems. |
