Cobb stage 2 traps 105??!
01-03-2012, 01:38 PM | #1 |
This isn't your captain speaking
9
Rep 102
Hey guys I recently went to the drag strip in Sacramento and had a great time out there with some friends but after about 10 runs the best time I could get was 13.5 @ 105 granted that was with 2.4 second 60 ft time but I thought I should atleast be trapping higher, my friends headers and axelback gto was able to cut a 13.0 @ 109 and he beats me from rolls all the time. Anyway my mods are afe sealed intake, AA downpipes and Cobb stage 2. Is there something wrong with my car maybe? Or did I just buy a dud 335i. :/
"How hard can it be...?" - Some British guy's
01-03-2012, 01:56 PM | #3 |
33
Rep 1,034
Did you Try stage 1?
01-03-2012, 02:03 PM | #4 |
3441
Rep 79,211
Without logs we are just guessing.
A 2.4 60 foot either means you rolled out from the light slowly or spun a lot of tire. So you need to clean up your launch. -Elevation? DA? Actual Slip? Last edited by Jeff@TopGearSolutions; 01-03-2012 at 02:31 PM.. |
01-03-2012, 02:18 PM | #5 |
151
Rep 1,809
I think it's actually a pretty normal time. Most people talk about 115-118mph traps and when you look at most timeslips you don't see more than 110...the boost is pretty low at higher RPMs on Cobb Stage 2. The timing is also not very high. These times are normal.
01-03-2012, 02:24 PM | #6 |
9
Rep 102
I had it on stage 1 with the downpipes installed and it pulled the same as stage 2 with downpipes. I was using my friends gto as a base mark because he pulled the same amount on both stage 1 and 2.
01-03-2012, 02:37 PM | #8 |
70
Rep 2,197
No offence, but either you're a terrible driver or something is very wrong with your car. A header back GTO should be good run for a stock stage 1 car, stage 2+ should embarass him. At least that's result i got when i was messing with a GTO a couple weeks ago.
01-03-2012, 02:37 PM | #9 |
2 car lengths ahead on the left
Rep 176
cam_lg:
I have a couple questions. What's the track's elevation and conditions? How bad did you spin down track? Even with the bad 60ft, that's a low trap speed IMO for your mods. Did you let the car cool down at all before making your runs? I usually allow for cool down between my runs at the strip.
The R
01-03-2012, 02:42 PM | #10 |
9
Rep 102
Ya I just keep seeing people getting mid 12's and over 110 trap speeds on Cobb stage 2. Guess I need to work on my launch and maybe throw an intercooler in there too.
01-03-2012, 02:51 PM | #11 |
9
Rep 102
I was at sacramento raceway it's elevation is 100ft and it was about 60 degrees out i spun 1st pretty bad and a little bit of second and I was shifting at 6200
01-03-2012, 02:59 PM | #12 |
3441
Rep 79,211
Depending on the situation spinning can make or break your trap. With a 2.4 60 foot you are not getting a good snapshot of the true capability.
If you have any logs that can tell us the rest of the story, otherwise you probably just need to improve your launches. |
01-03-2012, 03:14 PM | #13 |
9
Rep 102
I'll run some logs and get my timeslip next week I'm on vacation right now. going from wrx launches to rwd launches is a bit harder then I thought it would be haha
01-03-2012, 03:22 PM | #14 |
Rep 4,936
The hole shot makes a big differnce in you trap speed.
Tune,intake,meth on 17psi and i only could do 13.1 @110mph. With a 2.2 60ft. spinning all of first and 2nd gear. I got my 60ft down to 2.0 and did 12.7 @ 113 spinning 2nd gear
[SIGPIC][/SIGPIC]
01-03-2012, 03:46 PM | #16 |
9
Rep 102
I knew I should have bought a 135 haha
01-03-2012, 04:25 PM | #17 |
Rep 623
Man Honestly Im not too familiar with the cobb setup and stages since im running the JB4. I have AR downpipes Stett CAI Stett exhaust along with the JB4 on autotune map 5 and at the strip im pretty consistant on my launches trapping 1.7 60' launching in 2nd gear (because first is pointless all you do is spin) and I run right around a 12.3-12.4 at 115-117mph. I also run a 3 gallon E85/93 mix on a regular basis and peak boost is around 16psi. I also shift right around 6200 as well as OP said because the more you go to rediline the more the boost drops off and you loose LOTS of power. You might want to log some runs bro because to me, that just doesnt sound right. I think a stock BMW 335i runs a 13.1 from the factory so I would assume somethings not right with your car. Also you definently need to improve your launches as well so try 2nd gear instead. Should be ALOT better for ya!
01-03-2012, 04:47 PM | #18 |
9
Rep 102
Should I try 2nd gear even tho I have a Manuel ? Because I'm pretty sure that would toast my clutch a bit..
01-03-2012, 04:52 PM | #19 |
70
Rep 2,197
No, i would not launch in 2nd with a 6MT. Just practice launching in 1st. Depending on conditions, you may not be able to "launch" it. You may just have to take off aggresively and roll into it in 1st. It's not ideal, but it's better than doing a burnout to the 60' mark lol
01-03-2012, 05:31 PM | #20 |
Rep 5,450
13.5 at 105 is basically what a dead stock e92 335 will run - something is up, either you are spinning a lot, asleep at the wheel or the flash didn't take!
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
01-03-2012, 05:55 PM | #22 |
OEM+ is the shit
34
Rep 543
Get a bigger aftermarket IC
M-Tech - MFD - 9/10,5x18" BBS E28 - H&R - COBB - Supersprint - BMS - BigTom IC - Ultimate Racing www.Youtube.com/user/CarleeSWE www.Garaget.org/Carlee82 |
