Question about map 6 for jb4
01-06-2012, 12:32 PM | #1 |
Rep 868
I was e mailing Terry about 1/4 times and gas.
I told him I used e85/93 oct 50/50 mix and 4 gal 100oct best ET 12.39@114mph. I also told him I can buy 104 oct local, Terry said to use 104 only on map 6 set boost to 19 so it targets 18 psi. is the boost the only settings I change? I can't find much about map 6 and I'm not sure how set it up? Can Anyone advise me or send some links so I learn what to do? Ty, Ron
JB4 G5 ISO , AR DP's, DO Meth kit Trunk Mount, ETS 5" Intercooler, M6 Rims, ER Charge Pipe, Fordged DV's, MMp relocated inlets, Ebay 4" chrome Tips, Lux Angel Eyes **********11.910 @ 117.09***1.851 60'********** |
01-06-2012, 02:12 PM | #2 |
103
Rep 3,177
jb4 does not alter timing values without the CPS module, so boost is the main setting that you can alter. you can pickup a CPS module, however, i hear that the new aggressive jb4 maps will require it
01-06-2012, 11:06 PM | #3 |
Gunny
30
Rep 623
Drives: '07 E90 335i 6MT, 2016 F10 535
Just email terry. He's currently testing some new firmware that takes advantage if E85. I'm testing it now for him. You increase the boost (for map 6) and the fuel pressure. It's been a noticeable improvement for me so far. Just don't use more than about a 30-50% mix of E85. If you've got race gas, that's even better.
2007 E90 335i 6MT, ZSP, Nav, PDC, CA, Montego Blue, Terra Dakota leather, CDV, clutch-stop, E46 M Shift Knob, Logic HVI, JB4 PnP, MS 3" downpipes, Koni Yellow adjustable sport shocks, RE 12mm(f)/BMS 15mm(r) spacers, Blacklines, LUX 5.0 LED halo ring lights, DAEOS (Vista) harness, GP Thunder 7500k fogs, 35% sides-20% rear tint, matt black kidney grill, matt black 335i trunk badge
01-06-2012, 11:22 PM | #4 | |
Rep 793
01-07-2012, 01:52 AM | #5 |
Rep 868
Thanks for info
Terry did e mail me the map 6 boost numbers and info but I didn't see it cause it was at the bottom of the e mail, so I had it all along. He didn't mention about e85 map he just told me not to mix e85 with race gas.
01-07-2012, 07:44 AM | #6 |
Rep 2,602
^^can you forward the email? Tcolon911@EarthLink.net. I also have been looking for that info. Thanks!
