Fun new cat codes
01-09-2012, 05:14 PM | #1 |
112
Rep 4,771
Fun new cat codes
P2C7F
Lambda probe after catalytic converter 2, trimming control P2C6A Lambda probe after catalytic converter reversed, That's how they showed up. I assume this means my O2 sensors are bad. Running COBB Stage 2+. SES light comes and goes. Which bad boys (sensors) do I attack with fury tomorrow? |
01-09-2012, 06:10 PM | #2 | |
Rep 5,040
07-15-2012, 02:13 AM | #4 |
midnight modder
Rep 81
I have the exact same codes running cobb stg2+ after DP install. Checked to see if sensors are installed incorrectly and they are fine. Gray on short DP, black on long. Did OP ever resolve this issue and if so what was the fix? Bad sensor? I don't have any other issues other then the light and codes.
COBB Race E30, CDV Mod, Pedal Stop Mod, KW V2, M3 control arms and 28mm Frt Sway, Helix FMIC, AR DPs, DCIs, ER Chargepipe/Tial BOV, Agency Power Mids, CPe axleback exhaust, BMS 4LED Angel Eyes, BMW Perf CF mirror caps, Bimmian Amber Delete, Alufegen SF71 Hankook Ventus[/FONT]
07-15-2012, 01:00 PM | #5 |
112
Rep 4,771
This happened to me on the early Stage 2+ maps. They never reappeared after the next map update so I don't know what it was.
The SES light would come and go and it would trigger these codes. It's been a while so I can't remember which update it was, but I updated to the new COBB maps when they were released and it never came back after that. |
07-15-2012, 07:00 PM | #7 | |
28
Rep 457
Regardless. Post cat lambada sensors don't do d-ck really at all. It's the pre cat ones that matter. |
07-15-2012, 07:07 PM | #8 |
Rep 232
i have the same problem with o2 sensor after cat,bank 2,the problem began using cobb with atr, maybe because i change the afr ?
2007 335i coupe AT-- I80AS--FBO -stock turbos--COBB v402 beta stage 2 + ATR-- NITTO'S 275-40-17 NT05R --- 12.025 @ 120 mph -- full weight
07-15-2012, 07:20 PM | #10 |
Rep 232
yes they have a fix build in on stg2
07-25-2012, 10:06 AM | #11 |
dat boost doe
238
Rep 1,823
im running jb4, im only getting the one though
03-03-2013, 05:32 PM | #13 |
Rep 147
Just out of curiosity, can you elaborate what to look up?
Tony Wang
