TV / player / amp / Humax - how to connect?
01-28-2012, 11:16 AM | #1 |
Rep 1,179
Hi
I'm been given conflicting advice on how to connect a HD TV, Yamaha soundbar, Humax HDR Fox T2 3D HD blu-ray player. Dealer 1 suggests connecting Humax to TV via HDMI and player to TV via HDMI and then TV to soundbar via optical audio. Dealer 2 suggests connecting Humax to TV via HDMI and player to TV via HDMI and also to the soundbar via HDMI then TV to soundbar via HDMI. I understood that HDMI was better for sound than optical audio as it supports true HD sound and other high-end formats that optical audio cannot. Either set-up is compatible as there are plenty of HDMI and optical audio connectors. Which set up is best pls? |
01-28-2012, 11:53 AM | #3 |
Rep 1,179
Thanks, that's fairly conclusive.
Do I need 4 HDMI cables or just 3? I.e should will the player send the picture to the TV and via a separate HDMI, send the sound to the soundbar? |
01-28-2012, 11:54 AM | #4 |
Rep 3,022
based on your system HDMI will be spot on. Oh, and you dont need to spend much on HDMI cables either.
I think only purists use Optical cables, and even then, that may be changing.... Assuming you want to use the yamaha for normal TV as well...so use a HDMI from the Bluray player to tv, then tv to soundbar (if the TV has a HDMI out - check the manual?)
M2 Arrived!
Family 5er |
01-28-2012, 04:38 PM | #5 | |
Rep 1,179
01-29-2012, 02:34 AM | #6 |
Rep 6,946
I went through all this recently but have a sky + HD box. The advice seemed to be to use an optical cable from it to the amp in my home cinema kit. Is this correct or is HDMI better?
01-29-2012, 06:25 AM | #7 | |||||
Rep 791
Back to OP's question... You have to switch the HDMI signals somewhere. It's unlikely the TV will feed an audio bitstream back to the soundbar, so assuming the soundbar has multiple HDMI inputs and one or more outputs, I'd run the Humax and player by HDMI to the soundbar, then run HDMI from the soundbar to the TV. You then switch source by selecting the HDMI input on the TV and choose either the player or the Humax on the soundbar. What make/model TV and what model soundbar do you have?
2019 VW Golf GTI Performance | H&R rear ARB
Previously 2007 E92 335i SE auto | Quaife LSD | Birds B3 ARBs | Evolve Stage 1 |
01-30-2012, 08:35 AM | #8 |
Rep 1,179
All, thanks for input so far.
Sean Tv is Panasonic TXP42G30 Player is Panasonic DMP310 Soundbar is Yamaha YSP2200 PVR is Humax Fox T2 I've been reliably informed (my brother-in-law has reviewed the specs / manuals) that dealer one's suggestion is fine. No difference in sound quality between HDMi and digital optical. |
01-30-2012, 09:00 AM | #9 |
Rep 791
I'm not sure I agree. The TV won't pass the unaltered bitstream from its HDMI inputs straight out of its optical output as this would break HDCP (copyright protection) - it's likely it'll just pass an unencoded PCM stereo signal out of the audio output, which your soundbar might upsample to a surround signal, but it's not going to be as good.
The soundbar has three HDMI inputs and one output, so I'd stick with plugging the PVR and player into the soundbar with HDMI, then plugging the soundbar into the TV with HDMI. You'll get the best possible quality that way and don't have to bother with optical cables.
01-30-2012, 09:07 AM | #10 |
Rep 791
Also, looks like both the TV and soundbar support Audio Return Channel (TV on HDMI input 2), which lets you funnel audio from the TV back to the soundbar without an extra cable, so you don't lose anything by sticking with HDMI throughout.
01-31-2012, 11:25 AM | #11 |
Rep 1,179
OK, many thanks. How on earth is layman supposed to know all this stuff?
If the Soundbar feeds the TV. How will the visual signals get to the TV? Will it send both the audio and visual signals? |
01-31-2012, 12:05 PM | #12 |
Rep 791
Yep - the HDMI from the soundbar to the TV will carry the video from the attached players
02-08-2012, 02:13 PM | #13 | |
Rep 1,179
I spoke to What HiFi today (as they have recently tested the products I'm buying) and they confirmed your recommended set up. So thanks very much again. One last question. Is there any point getting a better quality aerial lead, i.e. with better shielding? |
02-08-2012, 04:53 PM | #14 |
Rep 791
What, didn't you trust me?
There is if you have problems with your TV picture breaking up / going blocky, but if it's fine, there's no point - again, with digital, if enough signal is getting there, you won't make it better by adding more.
02-08-2012, 05:57 PM | #15 |
70
Rep 1,733
I've got Yamaha 2200
Everything goes into it, and use the ARC to go to the TV. That way the unit will switch on and off with the TV. Great bit of kit. You'll love it once you've set it up properly. Use the cheapest HDMI cables you can find. It either works or doesn't with digital. Enjoy |
02-09-2012, 10:54 AM | #16 | |
Rep 1,179
I live in an area where Freeview is not officially yet available but our TV says the signal strength is high. At least once a day the picture does break up. I'm hoping once the digital signal is switched on in April it will be fine but I've bought a better quality cable to minimise interference just in case. Many thanks. |
02-09-2012, 10:57 AM | #17 | |
Rep 1,179
