Anyone have a BT scanner tool in the area?
01-30-2012, 12:35 PM | #1 |
Rep 712
Hey guys,
I got a code this morning driving to work. Can anyone help me out by letting me borrow or atleast check the code and reset ? I will be forever thankful!!!! I am in the Worcester area and willing to travel with my reduced power |
01-30-2012, 02:37 PM | #4 |
17
Rep 263
I'm on the North Shore, although Bababooey, I do have a friend who works in Canton. The cable I have is just a standard OBDII cable though, that I use for coding. I believe it can be used for diagnostics too, it's just more complicated than something like the Bavarian Technic one. If you know how to use Inpaload I'd be happy to lend you the cable via my friend.
01-30-2012, 05:53 PM | #5 | |
Rep 149
OP sorry for the hijack! |
01-30-2012, 08:53 PM | #6 |
***** noob
1369
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
most bavtech tool is vin locked and limit to 3 so I cant help you since i only have 1 free slot.
but just drop by advanceauto or autozone and see what generic code you have, maybe I can look it up for you
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
01-30-2012, 11:24 PM | #8 |
***** noob
1369
Rep 10,479
checked bentley.....generic p0204 = 2E33 injector circuit/open cylinder 4
this doesnt sound like ignition coils nor spark plugs as these two are very common and codes are well known on e90post.com but it doesnt hurt to check your ignition coil (#4). I'll say you have a bad injector or a bad wire/connection. Try to do some searches here to see if anyone else have the same issue...good luck did a google search Symptoms - Engine Light ON (or Service Engine Soon Warning Light) - Lack/Loss of Power - The engine may be harder to start - Engine hesitation Possible causes - Fuel Injector 4 harness is open or shorted - Fuel injector 4 circuit poor electrical connection - Faulty fuel injector - Faulty Engine Control Module (ECM) P0204 BMW Description Engine Control Module (ECM) checks the injectors circuit resistance and monitors the voltage drop during normal operation. The ECM will trigger the P0204 code when the resistance or voltage drop at the injector 4 is out of specifications. When is the code detected? The P0204 is set if the Engine Control Module (ECM) is detects a low or high voltage drop or resistance at the injector 4.
2006 325xi (Sold)
01-31-2012, 08:28 AM | #9 |
Rep 712
ska325xi - Thanks so much dude. Those are exactly the symptoms I am getting and i kinda had a feeling it was the injectors after doing some research. You saved me some trouble!
01-31-2012, 05:28 PM | #10 |
***** noob
1369
Rep 10,479
no problem, thats what the forum is for
if you plan on diy, let me know and I'll try to take some pics for you
2006 325xi (Sold)
