BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Pictures of old spark plugs
      02-05-2012, 11:53 PM   #1
skinrock
Agent Smith
skinrock's Avatar
270
Drives: 2016 i8
2016 BMW i8  [10.00]
As you may have gathered from previous posts, I replaced all 6 spark plugs this weekend. I had an issue removing from cyl 5 and had to buy a longer extension, but I finished the job a couple hours ago. I swapped the 4 and 5 coils just in case the misfire comes back. But I took it out with the Cobb Stage 2+FMIC Sport reinstalled, hit 4k a couple times (hard to redline around here with Stage 2), and it felt really smooth. It felt like the delivery was a lot more consistent and predictable, especially down low. No codes after a 15 minute drive, but I'll continue to monitor it.
The main point was to share my pics of the old plugs:
The i8 needs a V8 amirite?
      02-06-2012, 12:01 AM   #2
RnmEvo9
247
Drives: 2007 335i
Yep, mine looked identical at 55k miles when I replaced them with new ones. Solved my misfire issues!
      02-06-2012, 01:43 AM   #3
Streetsweeper360
Drives: 135 I
Typical 55 k Plug wear .The car looks like
It was Running well from the looks of them .
Top plug must be cylinder 1?If so ,that's normal for it to
Look different then the rest of them.If the misfire didn't come
Back now ,then it looks like it solved the misfire .
      02-06-2012, 01:45 AM   #4
skinrock
Agent Smith
skinrock's Avatar
270
Drives: 2016 i8
2016 BMW i8  [10.00]
Car only had 39k, only 8k are mine. No idea when or if they were replaced before. Plugs are in no particular order, I forgot to mark them.
      02-06-2012, 01:54 AM   #5
Streetsweeper360
Drives: 135 I
Thought you had that many miles for some reason
Must be the original plugs.Was the car running a tune for a while ?? And of so which ones ?
      02-06-2012, 01:57 AM   #6
skinrock
Agent Smith
skinrock's Avatar
270
Drives: 2016 i8
2016 BMW i8  [10.00]
Well it is an 07, but it had low miles to begin with and I don't drive to work. It had a JB4 for most of the 8k miles, mostly on Map 1 then Map 2 towards the end. I've only had the Cobb for a few hundred miles.
      02-06-2012, 02:08 AM   #7
Streetsweeper360
Drives: 135 I
Nice enjoy ! Keep is updated with it.I know your loving your Cobb Over the piggy.
      02-06-2012, 02:19 AM   #8
skinrock
Agent Smith
skinrock's Avatar
270
Drives: 2016 i8
2016 BMW i8  [10.00]
No comment I do appreciate the benefit of removing the extra hardware, and the ease of logging without having to pull out my laptop. That being said, I need to get back to the dyno and drag strip once I ensure everything is running okay to make a true comparison.
      02-06-2012, 03:55 AM   #9
franzzz
franzzz's Avatar
Italy
142
Drives: BMW M4
Mine after 60.000km
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
      02-06-2012, 06:51 AM   #10
RnmEvo9
247
Drives: 2007 335i
Can't wait to see your results! Another low 12 second Cobb car in the works?
      02-06-2012, 07:02 AM   #11
nitehawk
nitehawk's Avatar
102
Drives: e92 335i 6MT
Mine looked the same after ~35k miles. No oil residue or anything.
      02-06-2012, 09:04 AM   #12
Bash
Bash's Avatar
Drives: E92-335i
OP what type of camera did you use? lol seriously excellent close ups
COBB S2+ - Mr.5 CAI, Catless DP, Catless MP, AMS FMIC.
      02-06-2012, 10:23 AM   #13
skinrock
Agent Smith
skinrock's Avatar
270
Drives: 2016 i8
2016 BMW i8  [10.00]
I would hope so, at least on Aggressive if I mix with 100 octane. It would be nice to see if it's running okay on Sport and see what it does with that map as well, since that will always be my DD map.
Nikon D300S + Nikon 105mm Macro + Off-body flash
      02-06-2012, 11:02 AM   #14
nitehawk
nitehawk's Avatar
102
+1 on the amazing closeups
      02-12-2012, 05:37 PM   #15
skinrock
Agent Smith
skinrock's Avatar
270
Drives: 2016 i8
2016 BMW i8  [10.00]
Took it out for a nice drive today, finally. Seems to be running much better, no misfires on Sport map. Since I was getting them even on the stock map, just getting on the expressway, I'd say this solved the problem. I did a lot of pulls, including one from 30-75 onto the expressway, and it never threw a code. Still seems to be adjusting after switching maps, but it seemed to be pretty much dialed in at the end of the drive.
My oil temp stayed between 228-232 the whole drive, water was around 200-202. And maybe it's a placebo, but I popped the hood at home and overall the engine seemed much cooler. Wouldn't be too surprised since it's probably running more efficiently.
