Oil Leaking
02-06-2012, 06:13 PM | #1 |
196
Rep 2,669
Oil Leaking
My mechanic that was trying to fix a boost leak says that I am leaking oil quite severely, I go through about 1 quart every 10k miles (to the point it turns on a low oil light)
He is saying that there is oil covering everything on the bottom of the motor, He says there is a defiant leak on the oil filter housing (not sure what seal he is talking about) Just curious if there is multiple places that are frequent leaking areas. Im at 91k Miles, E90 335i is this a common problem? |
02-06-2012, 08:35 PM | #2 |
29
Rep 968
Drives: 2007 335i Coupe
Oil filter housing is a common place for leaks on the N54. The coolant tends to eat away at the gaskets in the exchange area. Replace both gaskets at oil filter housing and you should be fine.
02-06-2012, 08:42 PM | #3 | |
Rep 464
1qt every 10k miles isnt bad at all lol i use 1 quart every 5k and i have no leaks..asked bmw and they said its normal to have to add 1 or 2 quarts between oil change! but if u have a leak deff get it fixed!
Current car- 2003 cobra S/C stockish
* previous cars 2007 335i e90 Jb4, downpipes, intake, magnaflow exhaust, 375+whp 2005 SRT4 big turbo built to hell.. 420+WHP in a 2700 pound car! |
02-06-2012, 08:44 PM | #4 | ||
29
Rep 968
02-06-2012, 09:29 PM | #5 |
Rep 6,631
I was losing a quart every 700-800 miles, turns out the oil filter gasket was toast at 25k miles. dealer replaced it no cost under warranty, no problems now.
E90 LCI N54 6AT
02-06-2012, 09:36 PM | #6 | |
196
Rep 2,669
I don't have a warranty, Have any of you guys had a shop replace the gasket, He quoted me 220, which i feel like is expensive.
Can you DIY? Is it hard? Thanks for the quick replies. Quote:
I agree, but I can't be loosing that much oil considering I only have to add a quart every 8-10k miles. The car has 90k miles on it, and I doubt the bottom has ever been cleaned, Im not sure if It has had a leak before that the dealer fixed, I doubt they would clean everything off after fixing the issue. Last edited by E90SoFlo; 02-06-2012 at 10:15 PM.. |
02-06-2012, 10:23 PM | #7 | ||
29
Rep 968
$220 is not bad the intake manifold has to come off to get to one of the bolts for the oil filter housing. It's a good time to clean your valves. |
02-06-2012, 10:27 PM | #8 |
196
Rep 2,669
02-07-2012, 12:35 AM | #9 | ||
Rep 586
It is an easy fix... I did it my self for 20.00
2021 Mercedes G550
2015 X5M 2020 Supra-JB4, DP 2008 M5 with muffler delete-sold 2007 650i-sold 2008 335i-JB4, DP, Meth-sold |
02-07-2012, 05:24 AM | #10 |
Rep 464
220 isnt bad at all! id jump on that if he knows what he is doing...yes u can DIY i believe there is one you can search for. prob would take an hour or maybe 2 if its ur first time...intake manifold is the hardest part and that bolt that it covers..good luck
02-07-2012, 08:18 AM | #11 |
Rep 6,990
Drives: 15 F80 M3, 22 G01 X3 30i
Interesting...my E92 is 5 1/2 years old now and I've never had to add oil between changes.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
02-07-2012, 08:48 AM | #12 | |
Modder Raider
753
Rep 8,633
Drives: M3
Here is a thread that i started that has to do with the gasket and cleaning the valves. If you have an oil cooler then do both gaskets. http://www.e90post.com/forums/showth...ghlight=valves
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
02-07-2012, 09:05 AM | #13 | |
196
Rep 2,669
I do not have an OEM Oil Cooler, But I would like to go to my local BMW and get them to add one. I will see what the mechanic says. |
02-07-2012, 09:07 AM | #14 |
Rep 8,693
Drives: 06 330i
easy yob mang
02-07-2012, 11:03 AM | #15 |
Rep 204
I definitely use about a quart of oil every 2k miles or less. Dealer insists it is normal to go through a quart every 700 miles and says there is no oil leak.
02-07-2012, 11:07 AM | #16 |
Rep 3,730
1 qt / 10K isn't bad. I would highly suggest changing out your oil every 3-5K, especially if you are running the car hard and or using methanol. You can DIY the gasket, it's rather easy but time consuming.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
02-07-2012, 11:44 AM | #18 |
Rep 2,626
Dude 220$ is super good, my dealer quoted me 750$, and another dealer quoted me 625$ !!
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar.
'05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT COBB, FBO, st2 LPFP, Mfactory LSD | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
02-07-2012, 05:28 PM | #20 |
Modder Raider
753
Rep 8,633
Drives: M3
No. Just be careful not to get the coolant/water in the oil when you take the housing off.
02-07-2012, 05:33 PM | #21 |
Modder Raider
753
Rep 8,633
Drives: M3
I was running Meth and running my car hard. I had oil analyses done and the interval that I used was 6500. This was with Valvoline syn power 5w30.
