The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Help! Low coolant and engine overheating.
      02-07-2012, 01:08 AM   #1
ace008
Drives: 2013 F10 535i
2007 335i  [0.00]
While driving on the highway, I noticed the low coolant yellow light came on. I saw the temperature rising over 250 all the way to 280 and the engine overheating light came on. I was about 2 blocks from my house, so pulled over, let the car cool down, and made it back to my house. Also, I noticed that when trying to use the heater to let the car cool down some, it was just blowing cold air... How do I check to see if the coolant is low? I bought some prestone 50/50 for now. Can I use that to top it off? Is bleeding required, or can I just top it off and pour it in the coolant tank? What do you guys think the problem can be? Should I bring it into the dealer instead? Thanks for the help in advance!
      02-07-2012, 02:02 AM   #2
ace008
2007 335i  [0.00]
Well I checked the coolant tank and it looks almost completely empty... I bought some prestone 50/50 for now. Also, some people recommended that I just distilled water for now, until I can get a coolant change. What do you guys recommend? Also, after filling it up, should I take it to the dealer for them to take a look at it?
      02-07-2012, 02:06 AM   #3
soulja620
Cpl D
soulja620's Avatar
38
Drives: 07 335i
non bmw coolant = fail
07 AW e90 335 :jb4/dci/ic/meth= 12.2 @116 :jb4/dci/ic/meth/RaceGas/Slicks/gutted = Broken ET BOARD!
88- Mitsubishi Starion Turbo- Built~My feedback~ http://www.starquestclub.com/forum/i...0&fromsearch=1
      02-07-2012, 12:53 PM   #4
ace008
2007 335i  [0.00]
Its at the dealer now. Hopefully extended warranty covers it. Car has 86k miles btw.
      02-07-2012, 02:54 PM   #5
apme123
apme123's Avatar
25
Drives: 2002 Honda S2000
if you dont see and you are loosing coolant, check the head gasket, otherwise look for leaks or a faulty water pump and thermostat
      02-08-2012, 07:42 PM   #6
ace008
2007 335i  [0.00]
Dealer called back, and they still don't know what the issue is... They said the radiator cap was off or blew out, which caused the loss of coolant, but now, the engine is also misfiring and white smoke came out of the tailpipes. I had to authorize an engine teardown ($2000) while they take the engine apart and see what's going on. I have extended warranty through GE, thank god, and hopefully this will all be covered, but they need to find out what the issue is before they can start the warranty claim process.
      02-08-2012, 11:25 PM   #7
rader1
70
Drives: Cobb Stage 2+ 135i
sounds like a headgasket.
      02-08-2012, 11:52 PM   #8
Kris 335i
Kris 335i's Avatar
Drives: 335
Yeah you can't make it far without coolant before something (usually the head gasket) goes.
      02-14-2012, 12:54 AM   #9
ace008
2007 335i  [0.00]
Got the car back today. Turns out the water pump went bad, and also they had to replace the radiator. No engine damage. Car seems to drive fine now.
      02-14-2012, 01:08 AM   #10
JunkStory
Drives: E92 M3, 8V RS3
yep, water pump failure is becoming more common these days as the car ages.
      02-16-2012, 07:47 AM   #11
correll24
Correll24
Drives: 2006 BMW 325i
If you cannot get to the BMW dealer, Try O'Rielly's AutoParts. They carry Pentosin products which are made in Germany and good in just about all German cars.
PF-NF-1.5L Pentafrost
      05-28-2012, 02:49 AM   #12
villanueva3c
Drives: 2007 335i
I need some advice, today my 2007bmw 335i's overheating light came on. My cap was loose and lost some coolant. Went to fill it and the light came back on. Used peak coolant BTW. My water pump is pumping. Thermostat, don't know. It's got 140000 miles on it. Any feedback on what the problem is would be really helpful
