02-08-2012, 02:56 PM | #1 |
Supreme Allied Commander
3776
Rep 54,162
Drives: F80 M3
Rogue Engineering BMW 1M Short Shift Kit
Rogue's BMW 1M SSK is designed from years of experience building BMW shifters, and addresses many unique shortcomings of the OEM shifting system that are often left ignored with more basic short shifter solutions. From the shift carrier on, Rogue has improved on BMW's own shifter design.
Rogue's modified BMW shift carrier raises the pivot point of the shifter, effectively raising the handle height without increasing the length of the throw for a more ergonomic solution. The carrier also perfectly centers the shift lever, giving the correct shifting geometry, ensuring a smooth feel. Delrin carrier bushings round out the carrier, and give the shift lever itself a stable base with no deflection, for added precision. By relocating the shift lever's position up, the shifter is positioned closer to the steering wheel for a better, more ergonomic feel. A special selector rod also allows for better geometry and a properly aligned shift mechanism. Weighted Shift Rod is included but not pictured. For price and ordering information please visit: http://www.1addicts.com/forums/showthread.php?t=645226 Last edited by HP Autosport; 02-26-2012 at 12:45 PM.. |
02-09-2012, 10:47 AM | #3 |
3776
Rep 54,162
Drives: F80 M3
02-10-2012, 03:46 PM | #5 |
Rep 908
I'm confused by RE's phrasing. How does relocating the shifter up and to the rear move it closer to the wheel?
I have the snap-in 3rd cupholder and the knob is pretty close to the cupholder in 3rd and 5th. Will this SSK move the 3rd and 5th gear points any closer to the front? Thanks
Vorsprung durch Gas Geben!! 172 of 740 Last edited by Drillslinger; 02-11-2012 at 04:28 PM.. |
02-10-2012, 03:59 PM | #6 | ||
3776
Rep 54,162
Drives: F80 M3
02-11-2012, 10:08 AM | #7 |
14
Rep 42
I installed mine last week, I didnt take any photos of the process, but it was a bit of work. I was glad I had the lift at work, and the instructions are a bit lacking. The opening paragraphs are confusing, and contradictory. The installation is straight forward, but some of the diagrams seem to be missing, and the "yellow arrow" is not on the selector rod to indicate which end goes forward.
The throw is SHORT and FIRM. the shift knob is moved forward, towards the dash. I would have preferred for the stock position, as I am short and have short arms, but it is not uncomfortable where it is at. Reverse is my biggest complaint. you lose the positive detent that could be felt with the stock shifter. The side to side throw is so short that reverse is a bit more difficult to engage. I need to order a new shift knob and boot, because mine broke while attempting to get it to seat on the shifter. The plastic ring at the base of the knob split, and tore the boot. The knob did not want to grip, and when I get a new one I will have to find if it was a problem with my knob or the shifter. |
02-11-2012, 02:25 PM | #8 | |
Rep 3,070
02-11-2012, 06:19 PM | #11 |
Rep 3,164
Drives: Many
Garage List 2020 BMW M2 CS [0.00]
1994 Audi RS2 Avant [0.00] 2021 Audi RS6 Avant [0.00] 1988 BMW E30 M3 [0.00] 2011 BMW 1///M [0.00] 2017 BMW F80 M3 30 ... [0.00] 2018 Porsche 991.2 GT3 [0.00] 2015 Porsche Macan ... [0.00] 1998 Porsche 993 C4S [0.00] 1994 Lancia Delta I ... [0.00] 2008 Audi RS4 [0.00] |
Thx for the review Greg. A quick question as the description from Rogue sounded somewhat counterintuitive: shift lever is actually longer than stock, and the shifter itself is pushed towards the front of the car. You confirmed that latter that in your case is was more uncomfortable than stock, just wondering how much higher it sits relative to normal? I've had the Rogue SSK on other cars, very happy with it, but if anything, lever was A). shorter, and, B). the entire assembly was closer to the driver rather than the front of the car, a bit counter logical IMO.
2011 BMW E82 1///M: AW, all options; Renntech, Akrapovic, Forge, P3, RevoZ CF bits, many mods
1988 BMW E30 M3: Hennarot, S14, stock 2018 Porsche 991.2 GT3: PtS, CXX, LWBS, PCCB 1998 Porsche 993 C4S: Zenith Blue, last aircooled widebody, Bilstein PSS10, Fister II + Fabspeed exhaust 2008 Audi B7 RS 4: Sprint Blue, Audi Exclusive Euro Bucket Interior, Premium+Titanium, many mods |
02-25-2012, 09:05 AM | #13 | |
Rep 45
anyway, i had a workshop install it. it was a breeze but my mechanic had to trim off a bit of metal from base so that reverse would engage better. also, we had to trim/dremel off a bit of plastic from the seat of the shifter otherwise it just won't go in. i guess this is the problem AzGregg encountered as he tried to force the shiftknob to lock into the metal shifter. it just won't because the plastic base of the shiftknob hits the base of the metal shifter before the lock can engage. good thing we didn't force the issue. but all is well now. hope Rogue can take notice of those 2 things that need to be addressed in future batches. the reverse gear position and the base of the metal shifter being too fat on top that the shiftknob won't lock to it. otherwise, fantastic mod. should have come out of the factory this way. i don't understand why they don't. |
02-25-2012, 10:40 AM | #15 |
45
Rep 582
Theres no lack of fit and finish. The shifter is actually amazing, 4 gear is basically where neutral use to be. And 2 and 6 would be about equal but to the left and the right. Neutral looks like the car is in first or third but the shifts are nice short and notchy. So short and you can shift so fast. Also when the shifter gets a few throws on it it starts to feel oem like. Still like a knife threw butter but way shorter honestly for 395 one of the best mods you could buy
02-25-2012, 11:04 AM | #16 |
3776
Rep 54,162
Drives: F80 M3
02-25-2012, 12:12 PM | #17 |
Rep 1,358
02-25-2012, 12:14 PM | #18 |
Rep 908
Do any of you folks with this SSK have Nav and/or the "snap in" cupholder? With my std shifter my hand comes pretty close to this cupholder as is and I'm wondering if the Rogue SSK would result in bruised knuckles :-) (and my M is my DD so going without my morning cup of coffee is not an option, lol)
Thx
Vorsprung durch Gas Geben!! 172 of 740 |
02-26-2012, 12:45 PM | #21 |
3776
Rep 54,162
Drives: F80 M3
