Cobb + BMS WW Meth Kit Dyno Testing!
02-08-2012, 08:00 PM | #1 | |
Joint Chiefs of Staff
4923
Rep 115,999
Hey guys,
Since Cobb + meth has been a hot topic lately I thought some of you would be interested to see how it performs on the dyno. Runs were done with the WW kit using a basic boost switch type setup, and then with the JB4 doing progressive control. Quote:
02-08-2012, 08:44 PM | #3 |
Rep 2,626
Impressive! Just saw this on the other forum.
will be running this setup soon
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
02-08-2012, 10:12 PM | #5 |
Rep 2,626
Terry has big tom fmic on his car?
02-09-2012, 01:45 AM | #7 | |
Objects in the mirror are losing
105
Rep 1,133
Drives: 2007 BMW 335i E92 AW/CR 6MT
I just installed the same intercooler last weekend but with 2.5" outlets...was a royal pain in the ass but now that its done the car pulls great.. Great post Terry...Looks like I might be keeping my JB4 afterall...
PERFORMANCE: JB4 G5 \ Backend Flash \ DCI \ BMS Downpipes \ CX FMIC \ ER Chargepipe \ Synapse BOV \ KW V2 \ Muffler Delete \ CDV \ ZHP Shifter \ Cyba Scoops FUN: M3 Front \ Mtech Rear \ JL 10W6 \ ModMyNav \ V1 Hardwired \ LUX H8 \ Gloss Black Trim \ Gloss Black Roof \ Cyba Quads \ Cyba Mtech Diffuser |
02-09-2012, 02:02 AM | #8 |
105
Rep 1,133
BTW any runs with JB4 intergration on Cobb S2+ Sport?
02-09-2012, 02:28 AM | #9 |
Rep 37
I'm getting so confused now with all these different tunes .It seems each company is in war trying to put each other down .From the looks of things cobb flash looks like it makes the most on pump .Stacking different tunes seems dangerous.You can flash a Cobb while having a jb4 connected ?What does cl mid pipe mean ?
02-09-2012, 02:38 AM | #10 | |
Rep 4,995
Stacking seems to be fine as proven by Dz. I just joined the club and purchase myself a BMS WW kit |
02-09-2012, 02:53 AM | #11 | |
Rep 7,377
It requires logging and understanding them.
02-09-2012, 02:58 AM | #12 |
Rep 37
Wow ! You guys are brave stalking tunes and using all these fuels .I rather stick to good old pump gas..How do we know these tests are fair.Did they really use 93 oct ? I did some research and saw people hit over 408 whp using Cobb stage 2+?Dam it every time I think I choose the right tune for me someone makes a new thread with a different test .lol.Maybe I'll keep it stock .
02-09-2012, 03:21 AM | #13 | |
Rep 7,377
02-09-2012, 10:19 AM | #14 |
153
Rep 1,809
Of course there were power gains since the boost was increased by the JB4. Seeing these logs, I don't like what I see about Cobb. The timing is too low (let's say it's ok for non-meth), the boost doesn't reach the target. Plus boost oscillations. Hopefully this will be solved soon. There is a lack of Cobb logs on this forum...
02-09-2012, 10:34 AM | #15 |
Rep 6,631
Considering others are also underboosting Cobb + JB4, it's safe to say my unique issue was indeed tune related. Terry needs to go isolated boost control, pronto. As of today, Procede boost control is still superior to both Cobb and JB4. Hopefully not for long though.
E90 LCI N54 6AT
02-09-2012, 10:53 AM | #16 | |
65
Rep 1,708
02-09-2012, 10:57 AM | #17 |
Rep 7,377
here some logs , first one stage 2 plus and rest stage 1 and jb4 progressive meth .
02-09-2012, 11:13 AM | #19 |
153
Rep 1,809
02-09-2012, 11:22 AM | #20 |
Rep 7,377
here you go
02-09-2012, 11:30 AM | #21 | |
4923
Rep 115,999
Mike |
02-09-2012, 11:31 AM | #22 |
4923
Rep 115,999
You also need the JB4 target. DMEBT will be the same as the JB4 target on map 4 but on the progressive meth map the JB4 target will be higher of course.
Also with larger turbos I would expect the Cobb to be more likely to over target than under target since it's duty cycles are programmed for stock turbos. Mike Last edited by Mike@N54Tuning.com; 02-09-2012 at 11:49 AM.. |
