BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Cobb AP Error Code Help
      02-09-2012, 01:01 AM   #1
blakonblak
blakonblak's Avatar
9
Drives: 08 Blackmobile 335i coupe
I recently installed my DPs and flashed to stage 2 on Cobb. However I am getting the Service engine soon light still. I get the following codes:
P2097
P0041
P2C31
P2c6a
P2c28
Can someone help me out what this means? Will my car explode?
Blackmobile||all black erthang
      02-09-2012, 03:30 AM   #2
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
P2097
P0041
P2C31
P2c6a
P2c28
yeah probably , happened before with those codes .
I would do an ECU reset and delete codes and see if they come up again. You sure you installed the lambda on the right downpipes?
one of the codes is: 2C6A - AfterCat O2 sensors switched......
      02-09-2012, 08:39 AM   #3
blakonblak
blakonblak's Avatar
9
O man.... I got it done at a shop cuz I don't have a lift, maybe they switched it on install?
      02-09-2012, 08:42 AM   #4
enrita
enrita's Avatar
Sweden
161
probably. just tell them they have to check and fix for free of course
      02-14-2012, 02:42 AM   #5
blakonblak
blakonblak's Avatar
9
went to my shop today and did a 3 hr diagnostic.
they checked the o2 sensors and they were correctly in place and were not switched. then we reflashed. I did an uninstall and install and we got the same readings. however, now the engine starts to kick and the fan goes crazy after a while and then the kicks and shaking begin to shake. t
they said it is a software issue considering the o2 sensors r getting readings and voltage. so I tried flashing to different stage 2 maps and now the car does this crazy nonsense in the beginning with the kicking and shaking.
now I get these codes,
p2c28
poo40
p2c24
p2ee6
h2c24
I am starting to think I should just go back to stock.
      02-14-2012, 02:55 AM   #6
enrita
enrita's Avatar
Sweden
161
p2c28
poo40
p2c24
p2ee6
h2c24
call cobb for support.
      02-14-2012, 05:11 AM   #7
woptang22
woptang22's Avatar
169
Drives: 2009 E92 BMW M3
P2097
P0041
P2C31
P2c6a
P2c28
I was recently considering doing the same thing. Having DPs installed and flashing to stage 2 with my cobb. This situation make me pretty nervous. I think somewhere on this forum is a post of different error codes. I cant find the page right now. But if I can locate it I will post it so you can see what all the errors are.
      02-14-2012, 09:05 AM   #8
E90SoFlo
196
Drives: E90 335i
If you are running cat less downpipes you have to run stage 2.
It still sounds like they could have installed the O2 sensors wrong.
Call COBB they have awesome support and will get your going quickly.
      02-14-2012, 10:54 AM   #9
COBB Tuning
COBB Tuning's Avatar
233
Drives: 335i
Do your downpipes have O2 spacers on them? These codes would typically be related to bad O2 sensor readings, but I'll point Rob in this direction and he'll be able to help figure out what is going on.
Ian
      02-14-2012, 11:01 AM   #10
Rob@Cobb
Drives: 2011 E92 335i ///M Pack
p2c28 - Lambda probe before catalyst 2, System check
poo40
p2c24 - Lambda probe before catalyst reversed
p2ee6 - Coolant temperature sensor, measuring range of plausibility.
h2c24 - Lambda probe before catalyst reversed
I would assume the car has the same behavior after an uninstall? When uninstalling the AP puts your 100% stock ROM back on to the ECU.
Other than the O2 sensors being swapped (easy to do), bad exhaust leaks can wreak havoc on the O2 sensors as well. It is also possible for the sensors to be damaged while being removed/re-installed.
Cheers,
Rob
      02-14-2012, 11:12 AM   #11
import36
Burrito bowl connoisseur
import36's Avatar
Drives: 2015 Nissan GTR Black Edition
my guess is that the sensors are either still swapped and the shop doesn't realize it...or they are damaged.
      02-14-2012, 01:36 PM   #12
blakonblak
blakonblak's Avatar
9
Cheers,
Rob
I have not tried running the car without the tune. Should the irregular startup happen without the tune as well?
      02-14-2012, 02:02 PM   #13
blakonblak
blakonblak's Avatar
9
Ian
just called you guys and left a message... I will shoot an email to you guys.
      02-14-2012, 02:16 PM   #14
enrita
enrita's Avatar
Sweden
161
pretty sure your 02 sensors are still swapped or damaged. your shop will of course blame the tune so go back completely stock and see if you still get the codes.
      02-14-2012, 02:21 PM   #15
BMWGURL
Drives: 97 bmw 318i
i just got a bmw yesterday...and it will only rev to 42-4500 rpm...its totally stock...i have no idea why its doing this or how to fix it...does anyone know if you can use vag com for bmws? i want to tune my computer but i have no clue how...can anyone help me?
      02-14-2012, 02:23 PM   #16
blakonblak
blakonblak's Avatar
9
uninstalling now... error codes read misfire now too. Think my car is crapping out?
      02-14-2012, 02:27 PM   #17
blakonblak
blakonblak's Avatar
9
sounds like it is in a lean mode... Used or new? usually you don't want to push your car until it is warmed or if it is new 5000 miles i think is broken in.
I went to IU by the way. GO hoosiers
      02-14-2012, 02:28 PM   #18
Projekt_BooGie
Average Car Exceeding Expectations (ACEE)
Projekt_BooGie's Avatar
Drives: 2007 335i e92
2007 e92  [7.00]
Misfires....I can't really say anything about the O2 sensors...but if its misfiring now...check spark plugs. How many miles are on your current ones? I know a few local members have gotten misfire codes, and they basically changed spark plugs and were good to go.
too much to list...just know its wide and bagged
      02-14-2012, 02:30 PM   #19
blakonblak
blakonblak's Avatar
9
not sure. Got the car CPO at 26k miles... dont know if they change em or check em when they are traded in.
But now I have 28k miles. So from the beginning maybe 28k? Do I have to get BMW spark plugs and coils?
      02-14-2012, 02:31 PM   #20
BMWGURL
Drives: 97 bmw 318i
it is used its a 97 bmw 318i it has 145,000 miles on it...my first time owning a bmw or even driving one...and i have no clue what lean mode is.... everything is stock...how do u change the mode? or how do i program my computer? im very new to all this...know alot about audi's though lol, and sweet i live like a couple hrs from IU!!!
      02-14-2012, 02:38 PM   #21
blakonblak
blakonblak's Avatar
9
Not sure about older BMWs, but usually you can buy a piggyback system, or in my case a accessport to "flash" the ecu to gain more power. look on bmw mod sites and such.
If it is lean mode then the ECU is limiting you cuz theres something wrong with your engine or overheating.
      02-14-2012, 02:40 PM   #22
blakonblak
blakonblak's Avatar
9
found the similar threads, but they offered no solutions. Seems like problem was solved but they didnt post it.
