Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > JB4 2/7 Firmware Meth Dyno Testing!
      02-09-2012, 02:26 PM   #1
Mike@N54Tuning.com
Joint Chiefs of Staff
4918
Drives: 2007 335i, 2015 M3
Some more meth dyno testing results for you. The JB4 + WW meth is a pretty strong runner! Also very interesting info on duty cycles and targets that were discussing in the other thread. This 5th gear dyno run looks sexy as hell.
Test car and relevant mods: 2008 135i step, CPE downpipes, CL midpipes, BMS DCI, eBay version "big tom" intercooler, 93 octane, mid 70s in the dyno room.
1) For the testing I was running a 80/20 meth mixture with a CM10 nozzle.
2) The richer low end AFR targets are working well on and off meth. We're targeting around 13:1 now down low vs. 14.7:1 down low stock. This is with a 60% enrichment factor. There is plenty of room to go richer but this is the sweet spot for this firmware/mapping.
3) I used a 65 additive in 4th gear runs which resulted in the back to back 440+whp runs but with a ~2psi under target at redline. I could actually write a paragraph on duty cycles, targets, etc, but long story short just keep in mind on a dynojet doing ~5 second 4th gear runs you will have more of an under target tendency than on the road or a load dyno. Also note on the road I would not run a 65 additive unless you have race gas in the mix.
4) I've been running a 50 additive around town and boost is always right on target so as a test I did a 5th gear pull which instead of ~5 seconds took around ~10 seconds. A little closer to reality. The result was the highest output and boost back on target. Also glad to see the SLD is working well as the car would otherwise be capped at 130mph.
5) As you can see from the 5th gear runs it does not take a ton of boost to make a lot of power. All you need is 18psi tapering to 15psi at redline to pretty much max things out.
      02-09-2012, 02:34 PM   #2
triggz
56
Drives: E92 335i
WOW!
      02-09-2012, 02:38 PM   #3
hotrod182
hotrod182's Avatar
812
Drives: 2023 i4 M50
Almost 500lb Tq on stock turbos without mega-boost.. impressive.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra,
2008 Black 335i Sedan. 11.11@ 129.47 mph
2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds
2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy)
      02-09-2012, 02:46 PM   #4
zeel
Drives: 08 AW e92 335i
people are looking for the big single dyno's and you guys just keep churning out the big stock turbo dynos! looks good lol.
      02-09-2012, 03:08 PM   #5
dzenno
273
Drives:
great #s for stockers!
      02-09-2012, 03:33 PM   #6
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
Where's the baseline?
E90 LCI N54 6AT
      02-09-2012, 03:48 PM   #7
BobS
BobS's Avatar
97
Drives: M3
Wow, makes me want to get Meth :-)
ESS 650 ACM-R Upgrades
      02-09-2012, 04:04 PM   #8
Mike@N54Tuning.com
4918
It's the same dyno they use (SpecialtyZ) and I'm sure there are plenty of baselines floating around for it. I remember seeing 305-310rw FBO before? On the same day they did 395rw with the Cobb S2+ Aggressive on pump gas so I'd say it's a pretty average dynojet. I'm looking forward to seeing the 60-130s on this combo. Maybe it will give Hotrod a run for his money?
Mike
      02-09-2012, 04:05 PM   #9
jayk877
jayk877's Avatar
Drives: 2007 335i sport
meth is gonna be my next buy....after i install the VRSF downpipes im waiting on Those are great numbers! was this an auto or manual? If auto how did it hold up with almost 500wtq? thanks
Current car- 2003 cobra S/C stockish
* previous cars
2007 335i e90 Jb4, downpipes, intake, magnaflow exhaust, 375+whp
2005 SRT4 big turbo built to hell.. 420+WHP in a 2700 pound car!
      02-09-2012, 04:21 PM   #10
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
Mike
Lol, that's an optimistic dyno then. On my purported poor dyno runs, I baselines 277whp STD FBO, which is 30 whp under what this dyno is spitting out.
I surmise I would be at 436-440 whp with the Cobb race map if I were on this dyno. I dynoed 373whp STD on Cobb stage2+FMIC aggressive on this low reading dynojet which would be around 403-405 whp on this dyno in Cali.
Hotrods secret is weight reduction through seat removal, unsprung weight drop through lightweight wheels and favorable conditions. No secret behind that.
We NY/NJ guys may be at sea level or better, but we routinely see 40-100% humidity, something the west coast guys almost never see.
E90 LCI N54 6AT
      02-09-2012, 04:23 PM   #11
nailer335
nailer335's Avatar
Drives: e90 335i f30 330i g20 m340i
2008 335i  [0.00]
2022 m340i  [0.00]
2017 330i xdrive  [0.00]
Very nice
      02-09-2012, 05:22 PM   #12
Mike@N54Tuning.com
4918
277rw is what cars put out stock on this dyno. That is pretty normal I think for dynojets. If you are only making 277rw with full bolts ons your dyno reads lower or your car is making less power than others. Did you do a few runs stock + FBO to ensure you had the full advance and no throttle closure? Sometimes you can game the system by doing a "stock boost" run with the wrong adaptions and get a really low number but you won't be able to make that over 2-3 pulls stock tuning. Find a better dyno to find out.
Mike
      02-09-2012, 05:27 PM   #13
secretsquirrel
secretsquirrel's Avatar
130
Drives: f80
277 stock FBO is definitely 25-35 HP low.
Incredible numbers Mike.
      02-09-2012, 05:42 PM   #14
hotrod182
hotrod182's Avatar
812
Drives: 2023 i4 M50
I'm near sea level. But only a few miles from the ocean, so humidity is definitely not considered low here. Foggy very often, dew on the car in the morning leaving it soaking wet. Many of my tests were done on fairly damp surfaces from the fog/humidity. But definitely the best conditions are on the lower humidity days. But I also have record breaking numbers in ~90% humidity. Also, as I have shown, my stock numbers were right in line with magazine times.
2019 i3s Terra,
      02-09-2012, 05:49 PM   #15
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
Mike
There another dyno I did my 135i on which gave me 295whp baseline FBO stock mapping. Needless to say, the numbers made more sense on that dyno hitting 424whp. Goes to show without a baseline, peak numbers are useless.
E90 LCI N54 6AT
      02-09-2012, 06:52 PM   #16
ichi_ban
Drives: X6 50i
So if we run meth is this our predicted outcome? Or is this an update for JB4 users later? Sorry for the newb question.
@ichi_ban
      02-09-2012, 07:06 PM   #17
jetblack07
Drives: 2007 335i
If you are on the fence with meth...pull the freaking trigger! You will not look back. I've fallen in love with my car all over again. Made 414rw on a 40 additive with a 293rw baseline with jb4, dp's, dci and meth. Care pulls like a freight train!
07 335i sedan AT 414rwhp/446rwtq
jb4, raceland, dci and meth...
12.06@117 with a 1.91 60'
      02-09-2012, 07:37 PM   #18
ichi_ban
Drives: X6 50i
Oh I plan on getting it LOL. I was just wondering if BMS will make the meth map available to the public/current JB4 users. You made only 293 with those mods? I would think you would make an easy 350.
@ichi_ban
      02-09-2012, 07:41 PM   #19
Beemw335
Drives: 335i
Well, running the stock turbos at pretty high psi is gonna make a lot of torque but not as much power as bigger turbos.
IMO, Id rather make less torque and more hp, I love having a lot of torque, but torque is what kills transmissions
      02-09-2012, 08:00 PM   #20
jetblack07
Drives: 2007 335i
No 293 was baseline on map 0. I made 414rwhp and 446tq on meth.
      02-09-2012, 08:27 PM   #21
ichi_ban
Drives: X6 50i
Nice I guess I can expect more gains
@ichi_ban
      02-09-2012, 09:21 PM   #22
Rotary Rasp
Rotary Rasp's Avatar
241
Drives: 2009 E92 335i 6MT
When will this firmware be public?
