Pumpkin bolts
02-09-2012, 08:06 PM | #1 |
151
Rep 1,677
Pumpkin bolts
Got my built pumpkin with Quaife LSD. However, it didn't come with the 3 bolts to mount it up. I do have 2 shaft seals and 12 new axle bolts.
Is it absolutely necessary to have brand new bolts? I'm talking about items 2, 3 and 4. Thanks! |
02-09-2012, 08:14 PM | #2 |
The Engineer
26
Rep 329
Drives: AW 07' 335i
Use the stock ones?
02-09-2012, 11:33 PM | #4 |
The Engineer
26
Rep 329
Drives: AW 07' 335i
Sarcasm is lost online. I used my original ones when I installed my wavetrac. I think ordering the axle bolts is a good idea though. They are very easy to round. If you don't have inverted torque wrench I found that a 5/8 12point boxed end wrench worked best. Hope that helps.
02-10-2012, 11:40 AM | #5 | |
Rep 280
Did you install your LSD? If so how hard was it to do? Can somebody with common sense and some mechanical skills do it? Thanks |
02-10-2012, 02:23 PM | #6 |
151
Rep 1,677
I got new bolts from the dealer. Problem solved. The shop is now ready to install the pumpkin along with M3 suspension parts. Can't wait!
I had VAC build the pumpkin with Quaife LSD. Unless you're stock diff is bolted, you'll need a shop with specialized machinery to get the job done. |
02-10-2012, 05:07 PM | #7 |
Some dude
92
Rep 1,780
To answer the original question: The original bolts are OK to reuse. TIS states 100Nm (75lb-ft) on the M12 bolts on the front, and 165Nm (124lb-ft) on the rear bolt. It does state to use a new nut, but this is to account for the self-locking feature of the nut. It is OK to reuse the nut a few times, since the distorted-thread lock nut still holds up well. It's not even really necessary to use a self locking nut in that application, just good practice. They are not prone to vibration and loosening.
RRT
E92 335i/6MT with stuff and things |
02-10-2012, 07:08 PM | #8 | |
AutoXer
34
Rep 683
2009 135i, Alpine White, 6MT, M-Sport, iDrive, iPod/USB, Heated Seats, Premium Sound, BMW Assist
02-11-2012, 01:32 PM | #10 | |
151
Rep 1,677
Ahh damn. Used bolts FS. Lol.
