Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Which cobb stage one to use?
      02-10-2012, 12:46 PM   #1
Zuluaga
Drives: 2009 E93 6 speed
Installing Cobb on my 08 e-93 right now.
There are 2 options for aggressive stage one and 2 for sport. I'm completely stock- what do you guys recommend?
Thanks
      02-10-2012, 12:51 PM   #2
BlackBB6
Drives: E92 335i 6MT
Do you mean the linear vs stock throttle? I use stock, it depends on which one you prefer. I've heard stock is better for for city driving.
      02-10-2012, 12:53 PM   #3
Zuluaga
Whats the difference? Linear being less turbo lag perhaps?
      02-10-2012, 12:53 PM   #4
E90SoFlo
196
Drives: E90 335i
Stock Throttle Map is my fav.
Linear is more, well Linear
Only use aggressive if you have 93 oct. Gas
      02-10-2012, 12:56 PM   #5
OfficialBOLO
OfficialBOLO's Avatar
Russian Federation
37
Drives: 2013 F30 335i X-Drive MSport
i use stock throttle as well. Linear just felt......un-BMW-ish. Hard to explain but if you try both out you will notice the difference.
2013 F30 335i X-Drive / AW / CR / MSPORT / PREMIUM / TECH / HK / Heated Seats / Sport Auto / PDC / M Performance Grills and Spoiler / 20% tint (sold)
1995 Toyota Supra Single Turbo (for sale)
      02-10-2012, 12:57 PM   #6
BlackBB6
From their blog:
"The factory stock throttle mapping is non-linear and tends to be much more aggressive in the initial range of throttle pedal. This throttle mapping gives drivers that “kick in the pants” feel of power ramping up very quickly. The COBB Tuning linear throttle mapping keeps throttle profile linear across the entire range of the throttle pedal. Linear throttle is more appropriate for driving on a race track or for drivers that prefer a very predictable and consistent throttle pedal throughout the entire range. "
      02-10-2012, 01:01 PM   #7
Velocity26
Resident old fart
Velocity26's Avatar
146
Drives: 2010 335i M-Sport
It has to with how the computer controls the throttle. On stock throttle, you get about 80% of the power with the first 50% of the throttle. On linear, 50% throttle gives you 50% power.
Once you are accustomed to stock throttle, linear makes the car feel unresponsive and slow. You have to use a lot more throttle to get the same response.
Some claim that Linear gives you much better throttle control on the track.
      02-10-2012, 01:40 PM   #8
335TWNTURBO
Drives: 07 335i
go with stock throttle
      02-10-2012, 01:41 PM   #9
marv85
marv85's Avatar
70
Drives: '07 E92 335i MT
Try them both
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar.
'05 C55 AMG
SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT COBB, FBO, st2 LPFP, Mfactory LSD | '07 E90 335i, PTF COBB E50, FBO, HFS4
      02-10-2012, 03:37 PM   #10
max
max's Avatar
Drives: E93 2011 335is
You're in Miami so use 93 octane gas and stage one stock throttle aggressive. You'll love it.
__________________________________________________ ________
      02-10-2012, 03:59 PM   #11
Zuluaga
Reporting back.
I had installed the linear one first and was somewhat dissapointed.... but let me tell you- after putting in the other one.... wow.... went up to 15.5 lbs of boost and the car feels freaking awesome!!
Cant wait for intercooler and a charge pipe... I know the blow off doesnt do anything for performance, but would like to hear the swooosh
      02-10-2012, 04:27 PM   #12
RnmEvo9
247
Drives: 2007 335i
Skip the blow off valve and get downpipes so you can see what Stage 2+ feels like.
      02-10-2012, 04:38 PM   #13
Zuluaga
and which one would gain the most power over stock... aggressive drive or sport?
      02-10-2012, 04:39 PM   #14
Zuluaga
Down pipes is my last option since its very time consuming to switch back to stock in case I would need to take to the dealership, no?
      02-10-2012, 04:49 PM   #15
Sniz
Sniz's Avatar
654
Drives: e92 335 - gone // e36 M3 turbo
being your in FL, do an intercooler then downpipes. doing it quickly you can swap to stock DP's in just under an hour.
      02-10-2012, 07:54 PM   #16
My335XI
Drives: 2010 335I XDrive
Is everyone running V301 stock? V203 seemed to have the most kick, but this weekend I may try the 301 stock.
      02-10-2012, 08:07 PM   #17
cleex024
104
Drives: 2008 BMW 335i Coupe
from start to beginning there is no way anyone can do this under an hour the right way. i did mine twice because i messed up the first time and the second time i did it just over 2 hours and that was rushing. so a pro can probably do it just under 2 hours with the right tools.
now if you arent counting all the time to pull the car in and taking off the bottom and all then yeah.
either way for downpipes the dealer really cannot not do warranty work because you have downpipes. they would have to somehow show that the downpipes was the actual cause of the problem at hand...which in most cases it is not.
there is no way that downpipes could be the cause of an hpfp failure. plus all you really have to do is get to know one of the techs that is ok with the mods and work with them...only ask for him to work on your car when you bring it in for warranty work.
Space Gray l 6MT l OSG LSD w/ VAC Race Diff Cover l Cobb e30 l Morr vs8.2 l UUC SSK w/ DSSR l VSRF Catless Dps l RPI Intercooler l CDV Removed l HID AE 8000k l ETS Catback l AST 5200 w/ Vorshlag Camber Plates l ER Dual Oil Coolers l Rear Camber and Toe Arms l K&N Drop In l Solid Tranny/Diff/Subframe Bushings l Bridgestone RE-11
      02-10-2012, 08:16 PM   #18
BlackBB6
I've heard this repeated here a lot, and I agree that should be the case. However, I've also seen a lot of people who had their warranties voided because of mods unrelated to the problem. If you aren't buddies with your SA or dealership, I would go in stock.
      02-10-2012, 09:50 PM   #19
cleex024
104
well what everyone should do is just call into one of the local dealerships and talk to them and see if they are ok with mods...i dont know why dealerships would not take work from modded cars.
if they can just do the work then whats the big deal really? because they get paid from bmw back anyway...so i would think from a business stand point if there really isnt any real signs of wear just replace and get reimbursed lol.
      02-11-2012, 06:13 AM   #20
ajsalida
ajsalida's Avatar
226
Drives: 95 M3, 02 R1150GSA, 09 335xi
The dealership does not void the warranty, BMW does, and then maybe not immediately. For example, you go in for an oil change, dealer says nothing, scans ECU or flags forbidden item on a check list (say DP's), you hear nothing for a year. Then you come in for a warranty claim, BMW reviews files, decides not to pay due to evidence of mods flagged from a year ago.
Plus I would not dismiss a dealership saying "we're OK with mods" to get your business now and then tattling on you to BMWNA for brownie points. You'd never know until you needed to. For example mods won't prevent you from getting routine maintenance (say, oil change) under warranty, or other non-engine stuff done.
Hell I have heard there is one notorious local dealership that scans these boards to identify cars with mods specifically to deny warranty claims.
      02-11-2012, 06:16 AM   #21
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
Read the calibrations notes on cobb site..... Aggressive is ... Well the most aggressive one, than sport than drive.
