Boost leak from divert valve seal leak
02-11-2012, 11:48 PM | #1 |
Rep 289
Something to keep in mind when you think you have boost leak...
I had recently installed a FMIC, following which I had significant boost leak (boost max'd at ~10 psi, but should have been around 18-19 with the COBB). After the shop checked the clamps associated with the FMIC a couple times and performed smoke tests, they finally traced the problem to leaking diverter valve seals. After removing the diverter valves and cleaning the seals, everything works great. Max boost is now 19+ psi.
SG e92 335i 6MT / Pure Stg2 DD / JB4 + MHD BEF / ETS FMIC / Dinan CAI / AR DPs / Stage 2 LPFP / Spec 3+ / Spec SMFW / MFactory LSD / KW V2 SCs / Vibrant 1792s
e36 M3 ... gone but not forgotten |
02-12-2012, 12:24 AM | #2 | |
102
Rep 1,903
Drives: e92 335i 6MT
I'm also on factory diverter valves without issues on Cobb S2+ Agg |
02-12-2012, 01:02 AM | #3 |
Rep 289
Yes, just clean and reinstall. It took the tech about an hour to diagnose and complete.
02-13-2012, 11:18 PM | #5 |
Rep 289
My understanding is they just cleaned the seals and the seal area. I think the tech mentioned that the valves weren't fully seating themselves due to a buildup of something.
02-14-2012, 07:38 AM | #7 |
Rep 2,558
Yeah I'm on cobb stg2+fmic with stock diverter valves and charge pipe without any problems...
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife |
