1/2 engine light with Procede v5 installed
02-13-2012, 01:36 PM | #1 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
All,
First off I apologize in advance as I only spent a few minutes searching this topic which I'm sure has been answered on here somewhere but I don't have a lot of time to search today and I'd like to get my car looked at ASAP. Bottom line: only perf. mod on my car is the procede. had 1/2 engine light come on with Procede v5 installed on map 1. After turning the car off and then leaving the gym 2 hours later the light was gone and the car seemed to be at full power. If I take the tune out and bring the car to the dealer, are they going to see the error codes? What do you guys recommend?
Cobb E40 PROtune by Jake@PTF/RR catless DPs/aFe DCI/ETS 5" FMIC/ER CP/Forge DVs/Alpina B3 TCU flash/BMW Perf. Exhaust./BMW Performance Style 313s/M-Tech Rear
02-13-2012, 01:48 PM | #2 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
I recommend you leave the Procede in and use it to read the code
shiv |
02-13-2012, 02:32 PM | #3 | |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
02-13-2012, 02:38 PM | #4 |
1737
Rep 17,960
Drives: A Lot
Correct. You will need your laptop to read the codes. For just clearing, no laptop is necessary.
02-13-2012, 02:48 PM | #5 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
thank you!
02-13-2012, 04:33 PM | #6 |
36
Rep 332
When installing procede, don't push pedal to the metal immediately. Give the ECU some time to adapt the new boost settings.
Try a few pulls without increasing boost (throttle 25%), then 3-4 pulls with 50-70% and then push the gas pedal until it reaches the engine bay. The DME will adopt to the new boost settings and you will have no half-engine light. As Shiv said above, read the codes, clear them and try from the beginning. Oh, it reminds me my very first day with V2 trying to get 100 km to adapt settings. This is not necessary of course nowadays, but give your DME some time to get used to it's new neighbor. |
02-13-2012, 06:41 PM | #7 | |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
Shiv, not too familiar with the software: Where do I get the screen with the list of codes...do you go to "data logging" and choose "view data log?" The only code I saw (to the right of the gauge display in the program) was 12140, which is the unplugged exhaust solenoid...I think in messing around with it I ended up clearing all the codes anyhow
02-13-2012, 06:47 PM | #8 | |
1737
Rep 17,960
Drives: A Lot
02-13-2012, 07:00 PM | #9 | |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
02-13-2012, 07:04 PM | #10 |
1737
Rep 17,960
Drives: A Lot
02-13-2012, 07:12 PM | #11 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
03-28-2012, 07:56 PM | #12 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
ok so just to follow up. on Monday morning on my way to work the 1/2 engine light came on again and then went away while driving (previous times it has stayed on until the car was restarted). tonight I followed the procedure for code reading with the PROcede to the letter and only see the code 12140 (exhaust fumeflap, input sensor) which I guess is just the fact that I have solenoid in the trunk unplugged for the exhaust. So I guess that means that my issue on Monday didn't throw a code?
03-28-2012, 11:00 PM | #13 |
56
Rep 361
Not much of car knowledge but it might be your cars turbo solenoids? I don't know exactly what they are called, but it can be 'overboost protection' if your tune allows you to bypass solenoid do that, if not then you may need to replace the solenoid. Mine did the same thing as well 1/2 power light and when I removed the solenoid it ran fine.
03-28-2012, 11:06 PM | #14 | |
1737
Rep 17,960
Drives: A Lot
Shiv |
03-29-2012, 06:02 AM | #15 | ||
Freude am fahren
71
Rep 1,968
Drives: E90 N54
04-16-2012, 11:08 PM | #16 |
Rep 12
Drives: 2008 E90 335i
Not trying to hijack the thread, but I'm having similar issues. After reading the codes, I'm getting 10722 (Fuel injection rail, pressure sensor signal) and 10738 (no idea). My mods are the Vishnu DCI, PROcede rev3, ar catless dp's, and catback exhaust. I'm hoping this isn't something I'm gonna have to take to the dealer...not looking forward to that headache. Any help guys?
04-17-2012, 01:32 AM | #17 | |
Rep 7,377
10738 is 29F2 code
04-17-2012, 08:46 AM | #18 |
Some dude
92
Rep 1,780
I got the code for fuel pressure sensor during long highway pulls two times now. That's relatively simple and easy fix, just replace the HP rail sensor at the back of the rail. I've replaced them before on other 335s as well.
However the 29F2 code is a telltale that the HPFP may be going bad. If you have a warranty, turn CAN clear OFF, run the car until the fault occurs, remove the Procede, then take to a dealer for replacement of the HPFP and possibly the high pressure rail sender.
RRT
E92 335i/6MT with stuff and things |
04-17-2012, 08:59 AM | #19 |
Freude am fahren
71
Rep 1,968
Drives: E90 N54
don't you want to be careful if you turn CAN clear off and then not clearing all codes before taking to a dealer WOT? Might be shadow codes for the PROcede, no? I'd hate to see someone get their warranty voided!
04-17-2012, 11:50 AM | #20 |
79
Rep 1,617
Aparently it's a know error with the current official Procede maps and a fix is in the works/beta stage. So I wouldn't replace hardware on your car yet but contact Shiv.
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
04-19-2012, 04:14 AM | #21 |
Rep 12
