Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > VAC Motorsports - 335i, 135i Performance Built Differential - How we do it!
      02-13-2012, 10:02 PM   #1
Brian_VACsales
Brian_VACsales's Avatar
194
Drives: E92 M3 VF Supercharged, 135i
Arrow VAC Motorsports - 335i, 135i Performance Built Differential - How we do it!
Follow us on Facebook
Hey guys,
A number of folks were wondering what our banner ad means when it says 'precision work done in house on our CNC machines.' I am proud to say that we in fact do everything in house - nothing is outsourced.
As many know, most 335i and 135i models have a challenging stock differential. Unlike most cars, most 335i and 135i models have a differential where the ring gear is WELDED to the unit. Note: Just about every car on the road has a ring gear that is BOLTED to the unit.
In order to add a Quaife, Wavetrac, OS Giken unit to your 335i or 135i, you need to re-use the ring gear and pinion in your differential. Not so easy since the ring gear is WELDED to the stock unit!!
So, in order for us to upgrade to a Quaife, Wavetrac, OS Giken etc. we put our machines to work and created this incredibly accurate process to to separate the ring gear from the carrier and prepare said ring gear it to be bolted to the new aftermarket unit.
This is a quick tutorial. We wanted to do the best job possible, so we configured our CNC lathes and mills to handle this challenging task. The end result is beautiful =)
VAC Performance Built Differentials are built to last with the highest quality components, procedures, and technical expertise in the industry. We have been building BMW differentials since the 1980s - 2002, E46, E92, street, race - we have done it.
How is a VAC Performance Built Differential made (this is not a complete list, but most major operations are covered)
1. Photograph and inspect every differential for damage/missing parts etc.
2. Drain and inspect fluid looking for shavings or anything odd with the fluid.
3. Remove cover, inspect ring gear, confirm gear ratio. Pictured: The infamous welded ring gear. Note how it is actually welded to the carrier.
4. Test backlash before dissassembly.
5. Remove axle shafts, old side cover seals, snap rings.
6. Carefully remove the carrier.
7. Remove inner races from carrier.
8. Clean up the carrier, and prep for CNC operation.
9. Set up the carrier in our ultra rigid and precise CNC lathe. Pictured: Stock welded ring gear/carrier on one of our lathes.
10. Machine away weld that secures the ring gear to the carrier. This is an extremely robust weld.
11. Remove the resultant step (weld) so it is flat enough to machine. Pictured: stock ring gear separated from carrier.
12. Machine the ring gear flat (to ensure a precise mating surface for the new unit) Pictured: Separated ring gear | fully machined ring gear | drilled/tapped ring gear
13. Set up the newly finished ring gear on our CNC mill. Pictured: Machined ring gear on our HAAS 5 axis machine.
14. Machine the ring gear to make it compatible with the limited slip unit.
Pictured: Completed ring gear still in the HAAS mill.
Before:
After: Note how we machine the entire face, not just the area where the LSD bolts. Our machining method ensures ideal accuracy and reliability. Not sure that anyone takes it this far.
15. Assemble the limited slip unit.
16. Pressure wash and paint the housing.
17. Soda blast and clean the differential.
18. Install bearings/snap rings.
19. Check pattern, install seals, gasket material and differential cover. Pictured: Checking the pattern on the newly assembled differential.
20. Tag and prepare for install/shipment. Pictured: VAC Performance Build Differential with optional Billet Differential Cover.
Brian Casella
Sales Representative, VAC Motorsports
Office: 215.462.4666 | Fax: 215.462.4667 EXT 13 | Email: brian@vacmotorsports.com
      02-13-2012, 10:03 PM   #2
Brian_VACsales
194
reserved
      02-13-2012, 10:11 PM   #3
M3_WC
Drives: M3
WOW!
      02-13-2012, 10:13 PM   #4
CJ421
CJ421's Avatar
1559
Drives: BMW M3
Excellent write-up Mike. I was wondering myself, even though VAC already built my diff into a Quaife. Write-up of my differential build experience at VAC:
http://www.e90post.com/forums/showthread.php?t=631500
A performance diff is worth every last cent!! At VAC.
P.S. make sure you get the M3 subframe brushings to go with it.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT
      02-13-2012, 10:30 PM   #5
ichi_ban
Drives: X6 50i
Newb question, but what's the benefit from removing that weld?
@ichi_ban
      02-13-2012, 10:34 PM   #6
blisstik
blisstik's Avatar
151
Drives: E92
I got mine built there as well, then I ended up getting the M3 suspension with it.
      02-13-2012, 10:35 PM   #7
Brian_VACsales
194
Since the ring gear is welded to the carrier, it is impossible to upgrade to a Quaife, Wavetrac, OS Giken etc. You are not able to buy a new ring gear, so the stock unit must be re-used.
Brian Casella
      02-13-2012, 10:39 PM   #8
turugara
turugara's Avatar
91
Drives: 335i Coupe, 6 Speed
2011 BMW 335i  [9.44]
I also had my differential built at VAC. Excellent place to go.
here's my review of it:
http://www.e90post.com/forums/showthread.php?t=566942
      02-13-2012, 10:48 PM   #9
amclint
boom
amclint's Avatar
12
Drives: 335xi
Wow that's very impressive!
      02-13-2012, 10:50 PM   #10
ichi_ban
Drives: X6 50i
PM with a Quaife LSD please.
@ichi_ban
      02-13-2012, 11:07 PM   #11
BQTuning
Drives: 2012 Z4 sDrive35i M Sport 6MT
@VAC
Do you need the car or can I send you the 335is Final Drive for it to be worked on and then shipped back ?
      02-13-2012, 11:10 PM   #12
ichi_ban
Drives: X6 50i
^^I'm pretty sure you can ship it to them.
@ichi_ban
      02-13-2012, 11:21 PM   #13
skim7x
skim7x's Avatar
Drives: 335i, C63 AMG
2007 335i  [10.00]
I see what you did there
Nice write-up Mike!!! Hopefully I'll be getting one of those beauties in my e92 this spring!!!! YOU tell ME
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife
      02-13-2012, 11:41 PM   #14
99three
25
Drives: 993, e92, e36, F355, Z32, Jag
Nice details!
      02-14-2012, 03:22 AM   #15
Alpina_B3_Lux
Alpina_B3_Lux's Avatar
263
Drives: Audi R8 LMX, BMW M550i xDrive
2009 335i  [8.90]
Very interesting documentary. I already have a Quaife, but still quite enlightening to see how it's done.
BTW I'm getting my VAC differential cover (anodized black street version) installed right now. A real quality piece!
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
      02-14-2012, 07:26 AM   #16
tres
tres's Avatar
Drives: 2011 bmw 335is 6MT
Nice I plan on installing the solid diff bushings in a few
      02-14-2012, 10:42 AM   #17
Brian_VACsales
194
Will do!
Send us the final drive and we handle the rest. I will PM with more info
Originally Posted by turugara View Post
I also had my differential built at VAC. Excellent place to go. here's my review of it:
Originally Posted by M3_WC View Post
WOW!
Originally Posted by 99three View Post
Nice details!
Thanks guys. This is in my opinion the #2 mod for a N54/N55 powered vehicle. #1 being boost/power stuff.
Spring already started
Our machine shop:
Brian Casella
      02-14-2012, 10:50 AM   #18
Slops
Slops's Avatar
South Africa
188
Drives: 2005 C55 AMG
I'm so happy and proud that you guys are semi local to me
      02-14-2012, 11:35 AM   #19
GTiceman
Parrothead
GTiceman's Avatar
137
Drives: E90 M3
2020 BMW X3 M40i   [0.00]
2009 BMW M3  [0.00]
awesome write-up Mike
|e46 M3 Stahlgrau/Red| - Sold
|E92 335i BSM/Saddle| - Sold
|e90 M3 Space Gray/Fox Red/6MT|
See Garage for Mods
      02-14-2012, 11:39 AM   #20
trialskid
Drives: 08 335i
Can you pm me with pricing for shipping you my unit?
      02-14-2012, 12:03 PM   #21
vasillalov
Mad Linux Guru On The Loose
vasillalov's Avatar
1121
Drives: 2008 335i Sedan, 2023 M3
2023 BMW M3  [0.00]
2008 335i E90  [8.00]
Droool! My next big purchase will be an LSD from you guys!
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
      02-14-2012, 12:43 PM   #22
Fundahl
Drives: VO 1M, 300zx TT
Awesome documentation!
It would pair well WITH THAT ported/enlarged intake-valve N54 HEAD! (hint hint)
Tags
differential, os giken, quaife, vac motorsports, wavetrac
