Some early customer results for the BMS OCC!!!
02-16-2012, 10:16 AM | #1 |
Joint Chiefs of Staff
4918
Rep 115,980
Just wanted to post up these pictures from a customer car showing nice collection of oil after only 1 and 2-months of use.
1 Month 2 Month |
02-16-2012, 11:27 AM | #5 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Uggh, we've been through this before fellas!
Is the output pipe from the OCC clean of oil? If not, then it is not capturing everything. Also, OCCs work ONLY during acceleration. During deceleration, cruising and idle, the flow goes through a different valve.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
02-16-2012, 11:43 AM | #7 | |
4918
Rep 115,980
Mike |
02-16-2012, 11:50 AM | #8 |
65
Rep 1,708
I would NOT expect 99% oil collection... >50% is acceptable in my opinion and anymore is bonus, but flow is most important. Which I think BMS has done, but it's only speculation based on the design. Anyway, good job!
Wasn't someone going to check CC pressure through the oil cap? |
02-16-2012, 11:59 AM | #9 | |
273
Rep 5,876
Vas you can't expect 100% clean return pipe as well as have max flow AND perfect location/placement on this car...so far this can is the best non-DIY setup on the market period, and it looks great! it basically addressed many issues discussed in the pcv discussion on this board...the only remaining thing that hasn't been addressed that i'm looking forward to is routing the vapours of the "other" check valve that's open during off boost situations...and that part of it may be as simple as just adding T-ees in the tubing going to/from the can and hooking it up with some sort of adapter to the OCC's in/out.. this is a great OCC and recently added it on my car as well, no issues...have about 500km with it on so far, will check in about 500km to check up on the situation in the can..would also like to run the crankcase pressure test on it once i get some time... |
02-16-2012, 12:28 PM | #10 |
1121
Rep 5,396
Dzenno,
Thanks for your input! I still prefer to clean my valves and intercooler every 30K miles and not mess with the PCV system.
02-16-2012, 01:14 PM | #11 |
273
Rep 5,876
And honestly, there's nothing wrong with that...i don't remember the last time i heard some extra oil hurt an engine it gets trapped in the fmic inlet end tank and you can just drain it...that's what i planned on doing until bms came out with theirs which i'll test out and see how it does crankcase pressure wise...if within stock spec i have no issues with it really
02-16-2012, 01:16 PM | #12 | |
Rep 2,626
Totally unrelated, do you mind sharing how many km you have on your car?
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar.
'05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT COBB, FBO, st2 LPFP, Mfactory LSD | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
02-16-2012, 01:20 PM | #13 |
273
Rep 5,876
02-16-2012, 02:08 PM | #14 |
The Engineer
26
Rep 329
Drives: AW 07' 335i
Looks like I need to finally install mine. I don't have both vehicles down here so working on my car gets limited to things that must be done. Like LSD install
02-16-2012, 02:22 PM | #15 |
29
Rep 1,551
Damn! My BMS OCC has been in for ~3000km and its clean as a whistle. I've never had that much blow by though, and I havn't been pushing it as its winter here. I'll report again in the summer
02-17-2012, 07:59 AM | #17 |
4918
Rep 115,980
02-17-2012, 09:53 AM | #18 |
Rep 4,499
Mike,
Do we order this from your website or do you have stock? And what is the price?
Have BT Tool professional, will scan and clear codes on your BMW. And now I am able to code my 2011 335is and M4
Link to my M4 euro delivery! http://f80.bimmerpost.com/forums/sho....php?t=1006526 |
02-17-2012, 10:17 AM | #19 | |
4918
Rep 115,980
Mike www.n54tuning.com |
02-17-2012, 10:35 AM | #20 |
Burrito bowl connoisseur
124
Rep 3,501
i really like the design of this occ and how short the tube is. i currently run the AR Design occ that is mounted on the passenger side by the vacuum canisters...and the tubing is pretty long. wonder if i would notice any type of "improvements" by switching...
02-17-2012, 11:08 AM | #21 | |
Rep 2,559
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
02-17-2012, 11:18 AM | #22 |
124
Rep 3,501
awesome....let us know what your findings are....i'd appreciate it!
