TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > turbo upgrade with catted downpipes?
      02-17-2012, 05:58 AM   #1
Schnitzel
Germany
10
Drives: E92 335i MT
Hi guys, I have mods as stated below and want to do a turbo upgrade soon.
PROcede rev 3
PWM meth kit
Riss Racing catted downpipes
Spearco Code3 FMIC
DCI
ACT street clutch (coming soon)
BMW performance exhaust
My question now is: When I do a turbo upgrade, should I swap the catted downpipes for catless downpipes? Since now I have no issues but I don't know if the exhaust restriction would be too high and the turbos can't breathe properly.
Your comments are welcome.
[SIGPIC][/SIGPIC]
      02-17-2012, 06:19 AM   #2
Zebra99
Zebra99's Avatar
112
Drives: 2011 335is E93
I'm no expert, but I thought we had 3" piping from cat back...that being said, with catless DP's you may have the perfect set-up for the larger turbos. After all you need back pressure to help build the boost no?
That's unless you go and put truck turbos on it and will need 4-5" piping lol
You should ask the few guys here with the RB set-up or any of the vendors working on larger turbo set-ups. There exp. would be invaluable here.
      02-17-2012, 06:23 AM   #3
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
i would go catless dps. just take them out and empty out the cats from yours.
      02-17-2012, 07:26 AM   #4
nitehawk
nitehawk's Avatar
102
Drives: e92 335i 6MT
Yes, you really wont reap in the benefits of a turbo upgrade without catless Dps. I would change them out.
      02-17-2012, 07:58 AM   #5
scottp999
Drives: 4runner SR5
2007 BMW 335  [9.00]
Catless is the best flow, hi flow cats you will still see most of the gains. I don't have the magnaflow image here, but basically the had a test with a pipe showing, stock cats flow 300 CFM, high-flow cats 600CFM, and open pipe 1000CFM. So you should be seeing twice the flow rate as stock with hi-flow cats. I don't know what cats riss racing used, do you know the brand and model number?
Going catless when they change out the turbos, is a great time to switch over.
      02-17-2012, 07:59 AM   #6
dzenno
273
Drives:
Catless from turbo back is best but if you can stand it...i've put the stock catback on after 2.5 years and left the catless dps on...car is a 100x nicer to drive now...
By the way i daily drive my car 70000miles on the clock
      02-17-2012, 09:57 AM   #7
Schnitzel
Germany
10
Drives: E92 335i MT
Good idea but I think it would be very difficult to empty out the cats without cutting them, wouldn't it?
[SIGPIC][/SIGPIC]
      02-17-2012, 10:33 AM   #8
Syndicategt
Syndicategt's Avatar
Drives: 335i
I run Rob Becks with AR's hi-flow cats.....no issues here. Don't take opinions from people who can only theorize.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
      02-17-2012, 10:39 AM   #9
dzenno
273
Drives:
+1
      02-17-2012, 12:08 PM   #10
Schnitzel
Germany
10
Drives: E92 335i MT
I have just bought RB turbos. But I still don't really know what to do now with the downpipes
[SIGPIC][/SIGPIC]
      02-17-2012, 01:06 PM   #11
scottp999
Drives: 4runner SR5
2007 BMW 335  [9.00]
I also run AR DP's with hi-flow cats (magnaflow cats) with RB Turbos. Don't worry about it. Put the RB's in = have fun. Yes you can probably squeeze a few extra whp with no cats but there is a trade off, noise, pollution, smell. Keep what you have now.
      02-17-2012, 01:17 PM   #12
dzenno
273
Drives:
Agree
      02-17-2012, 01:31 PM   #13
GmoBmw
GmoBmw's Avatar
34
Drives: 2007 335i
Im In Socal and Im going catless. When i smog ill switch it to stock for the day.
2007 BMW 335I- JB4 G5,DCI,VRSF DPs,NT555r Drag Radials Daily Driver
      02-17-2012, 07:12 PM   #14
Schnitzel
Germany
10
Drives: E92 335i MT
Is that really mandatory? I thought an o2 fix would prevent switching back to stock. Or do you have a "real" emission test? Our emission test consists of OBD reading and that's it.
[SIGPIC][/SIGPIC]
      02-17-2012, 07:43 PM   #15
GmoBmw
GmoBmw's Avatar
34
Drives: 2007 335i
Ya they do the sniffer test here in California. When I was in texas they just do inspections lol..
      02-17-2012, 09:07 PM   #16
Rotary Rasp
Rotary Rasp's Avatar
241
Drives: 2009 E92 335i 6MT
(stolen from the interwebs)
"Set to begin January 01, 2013; Model year 2000 and newer vehicles will no longer require the tailpipe emissions test portion of the smog check process. AB 2289 will require late model vehicles be administered the smog check's visual and functional tests only.
The implementation of AB 2289 is expected to reduce the time and cost of the smog check. The program will now take better advantage of a vehicle's OBD II technology by eliminating tailpipe testing and instead using the vehicle's own OBD II emissions monitoring system.
This new smog test system is already in place in 22 other states. "This new and improved program will have the same result as taking 800,000 old cars off the road, also resulting in a more cost effective program for California motorists." said ARB Chairman, Mary D. Nichols.
Currently California's smog check procedure requires all vehicles undergo a tailpipe emissions inspection to measure harmful pollutant output from the tailpipe, a visual inspection for present and properly installed emissions components, a functional test to insure the proper operation of various emission components; and as part of the functional test, an OBD II computer diagnostic check.
Under AB 2289, the tailpipe emissions portion of the smog inspection will be eliminated for 2000 model and newer cars, trucks, vans, and SUVs.
Background on the OBD II system - All vehicles imported into the United States as of 1996 have had to be equipped with an On Board Diagnostics system referred to as OBD II. The OBD II diagnostic system is designed to monitor all aspects of your engine's emission conditions and report this information to a central database within it's computer. This information is processed and checked against the computers pre-determined values for various input levels and performance patterns.
If any problems are found, the computer will determine whether to alert the driver or not. If a decision has been made to alert the driver of an emissions problem, the "Check Engine" or "Engine Malfunction" light will illuminate on the vehicle's dashboard. In more serious emission conditions the computer may even begin to rapidly flash the "Check Engine/Malfunction" light indicating to the driver, that the vehicle needs immediate diagnosis/repair attention.
AB 2289 now requires the smog test inspection to rely on data from a vehicle's own on board emissions computer to determine the vehicle's harmful emissions production as opposed to using a smog machine to sample the vehicle's emissions output from the tailpipe. This design is expected to reduce the cost of equipment at the smog station, reduce the amount of time it takes to smog check a vehicle, and reduce the cost of the smog inspection to the consumer.
AB 2289 - Makes changes to the following smog inspection procedures and guidelines:
A. Authorize the use of On Board Diagnostic II testing to expedite the process.
B. Vehicles known to release large amounts of pollution must test at stations with the highest performance ratings.
C. Stricter fines structure for improper inspections.
D. Permit the state to contract with the private sector to manage franchise-like networks of independently owned Smog Check stations.
E. Encourage community colleges and other training institutions to develop technician-training programs."
      02-17-2012, 09:22 PM   #17
GmoBmw
GmoBmw's Avatar
34
Drives: 2007 335i
Dude.. You Just made my day...
      02-20-2012, 02:40 AM   #18
blisstik
blisstik's Avatar
151
Drives: E92
Whoa. So starting next year, CA will only do ODBII test?
      02-20-2012, 01:03 PM   #19
GmoBmw
GmoBmw's Avatar
34
Drives: 2007 335i
I wonder if I can pass with my jb4 installed.
