Code 29DC but interesting fix
02-18-2012, 01:13 PM | #1 |
109
Rep 1,948
So had my car serviced at my dealership in preparation for my big trip down south. Had brakes done, and basic service. Got my car back, thought i'd open her up and WHAM... code 29DC - Cylinder Injection Cutoff everytime i do a WOT. I check the forums and all basically say the same thing... HPFP.
This would be my fifth if it was the case. I told the dealer this so instead of the usual 'replace the hpfp' they did some investigating. They found some carbon buildup so do a full clean and tested the hpfp which held pressure as required. Gave me the car back and i've been running it for 2 days and NO ISSUES AT ALL. No more code and the car runs like a champ! |
02-18-2012, 01:16 PM | #2 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
It's your low pressure fuel pump. Do yourself a favor and have it replaced before you come to the airstrip event. You WILL trigger that code and make your runs miserable. Only costs $250 and is easy enough to do yourself (30min job). If that is the code you've been getting all among, they have been misdiagnosis your issue.
02-18-2012, 01:19 PM | #3 | |
109
Rep 1,948
back the car goes!!!! |
02-18-2012, 01:29 PM | #4 | |
109
Rep 1,948
02-18-2012, 02:16 PM | #6 |
1737
Rep 17,960
Drives: A Lot
Ah yes.. Better yet, buy it online for ~$230USD and do the job yourself. If you do a search, you will probably find the link to order. It comes as an entire low pressure fuel system assembly. That means pump, bucket, fuel level arm, etc,. Definitely an easy DIY
02-18-2012, 02:31 PM | #7 | |
109
Rep 1,948
I did do a search but didn't see the part number. |
02-18-2012, 02:33 PM | #8 |
1737
Rep 17,960
Drives: A Lot
03-23-2012, 03:03 AM | #9 |
Rep 931
The same error 'appeared yesterday on my car after 26 minutes of track with a large number of curves at 90 degrees
Procede Rev 3 map stage 1 3-17 29DC Cleared and made over 100 miles withot problems Bubble in the tank ? Any idea ?
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
03-23-2012, 08:57 AM | #10 |
109
Rep 1,948
Actually I can't be sure. Shiv figured it was my lpfp. I was going to replace it but after the carbon clean, I didn't have it come back. But, I had a loose turbo inlet pipe do I had lean codes on bank 2. Not sure if this was all related. After they did a smoke test, replaced that clamp for the inlet pipe, no more codes.
Sad to say, not sure what the issue or resolve was! |
03-23-2012, 08:59 AM | #11 |
Rep 931
Ok
Carbon clean is the filter in the tank ? Is a INPA procedure or physically clena the filter ?
03-23-2012, 09:02 AM | #12 |
109
Rep 1,948
No, carbon build up in the intake heads. I really doubt this was the cause of my issues. There are a few threads on DIY carbon clean or walnut blasting.
03-23-2012, 09:15 AM | #13 | |
Rep 931
I think another possibility : The Carbon Filter (number one in the pic)
03-24-2012, 12:54 PM | #14 |
Rep 931
check with inpa the LPFP
no particular issue found.
03-24-2012, 12:59 PM | #15 |
109
Rep 1,948
It could have been just a fluke case? I haven't had anything come back again. Its getting into racing season soon here. Once it warms up, I'll beat on it more to see if the code re-appears.
03-25-2012, 03:20 AM | #16 | |
Rep 931
I think a momentary interruption of fuel flow during a track day session. Another possibility is something wrong on the new 3-17 maps Before (11-25) no particular problem durind a track days I investigate
03-25-2012, 09:46 AM | #19 | |
Rep 3,456
Drives: Harrop E90 M3
03-25-2012, 09:51 AM | #20 | |
Rep 931
appears only on the track with tight curves and hard cornering. However, the tank was 30 liters
03-25-2012, 10:08 AM | #21 | |
Some dude
92
Rep 1,780
1) You are getting faster, and now the fuel is moving around even more than before. I see this on customer cars as they get faster / more advanced. 2) The low pressure fuel pump is getting weak. When this happens, it is not able to pump fuel to the HPFP adequately and push fuel through the "sucking jet pump" to move fuel from the left tank into the right tank. 3) The sucking jet pump is not functioning properly. The LPFP is on the right side of the tank, and the sucking jet pump, fuel filter, and pressure regulator are on the left side of the tank. You can replace just one side unit first and try again at the track. I would replace both units complete at the same time just to be certain.
RRT
E92 335i/6MT with stuff and things |
03-25-2012, 10:58 AM | #22 | |
Rep 931
tnx I verify out of track
