Not another tuner war! I just want honest opinions please...
02-22-2012, 02:33 PM | #1 |
62
Rep 370
Ive tried two different tunes and I'm still undecided... so I'm looking for some opinions from people who have also tried more then one tune...
Here is my quick story... So far I've tried the JB4 map 1 back when my car was stock. I got maybe two pulls in before it started misfiring all the time, so I installed all new spark plugs and moving coils around but continued getting a #3 misfire, so I removed the JB4 and took the car to the dealer, which they replaced the #3 injector under my used car warranty. When I got the car back, I bought and installed the Cobb AP and I ran stage 1 for a couple weeks before it started misfiring again! This time #4 was doing it. And since the used car warranty was up, I changed out the bad injector myself and I noticed that I only have the #5 & #6 injectors with the old part numbers left.. but and all was good and the car was running great again on Cobb Stage 1. Two weeks later, I finished installing all my mods (Stett CAI, Helix FMIC, ER charge pipe w/Tial BOV, and cat-less AR downpipes... and I continued to run stage 1 for a couple days which was pretty impressive now! So I loaded up their famous Stage 2+ FMIC map to give it a try, and needless to say, I'm not that impressed with it. Don't get me wrong, It runs great, but to me, it doesn't feel much faster then stage 1. And the boost feels like it flutters if you accelerate while only going part throttle. Full throttle is fine, but I still feel like I want more! So after a week of running Stage 2+FMIC, I decided to remove the Cobb AP and I reinstalled the JB4 to try it out again, because I remember how hard it pulled back when my car was stock (before it started misfiring anyway)... So with the JB4 I tried running map 5 and I got about two 3rd gear pulls in, and what do you know, it's MISFIRING AGAIN! This time its #6, which is still one of my old injectors... But what I don't understand, is how can I run 18psi on Cobb Stage 2+ for a whole week, and as soon as I install the JB4 on map 5 running about 14-15psi, I get misfires almost instantly? And now even map 1 is doing it while going part throttle, and the SES light comes on. Then I have shut down the car and restart it, to get it running smooth again. So... I guess I need to buy two more injectors to get them all up to current models... or could it just be the JB4? But Anyway, now I'm thinking I want to try the Procede... which is what I wish I would have bought in the first place. I really like what Ive read about the Procede and how the meth kit works. I also would like to have the gauge hijacking again, I don't like how long it takes to switch maps on the Cobb, and I know I want to run meth, so.... Am I crazy or what? What to do, what to do? Thanks for any info guys!
2009 Z4 35i 6mt, SpeedTech 6266 Gen2 turbo kit, Tial WG, VRSF 7.5 race IC, ER charge pipe, Tial BOV, Radium Fuel cell w/ surge tank and twin Walbro 525 pumps, Radium FPR and return line, Bluetooth ethanol sensor, Phoenix intake manifold w/PI, JB4 tuner, PR coil packs, Custom oil cooler, ECS Radiator, Spec 3+clutch, Mfactory flywheel, single 3.5" into dual 3" exhaust, H&R springs, 19" TSW wheels, 235/19 & 275/19 RE11 tires
02-22-2012, 03:00 PM | #3 |
Rep 2,132
Drives: FBO+ N54xi
I dont think this has nothing to do with tunes? Did you calibrate you're Injectors?
JB4+usb | P3 Vent Boost Gauge v2 | BMS OCC | BMS DCI | AMS FMIC | AR xi CL DP's | BT Tool | Edibias/NCSExpert/INPA BMW Coding | Cyba Quad Exhaust tips | M-Tech Rear & M3 Front Bumper | Red Cyba Air Scoops | Blacklines | Vinyl Overlays | ACS Roof Spoiler | Matte Black Grilles | LED Side Mirrors | Rear Euro Fogs | etc..
02-22-2012, 03:05 PM | #4 |
Joint Chiefs of Staff
4918
Rep 115,980
Nothing wrong with changing things up. But fix those misfire codes ASAP. They are hardware related and will act up on any tune. Also check out the bms WW meth kit. Integrates nicely with the JB4, makes tons of power, and is priced right.
Mike |
02-22-2012, 03:23 PM | #5 | |
I even mod my cereal
246
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
I really don't think the Procede will fix your problem.
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
02-22-2012, 03:55 PM | #6 |
196
Rep 2,669
I agree with everyone else
Buy a complete set of spark plugs, a complete set of coil packs install them and see if the misfires are gone. If not then injectors are next. Get it working on one tune completely, before trying it on another tune. They all do the same thing (in general) |
02-22-2012, 04:10 PM | #7 |
151
Rep 1,809
Also you should verify the injector coding at an independent shop that has the means to do this. You said you changed an injector yourself, did you code it properly ?
02-22-2012, 07:00 PM | #8 | |||
62
Rep 370
I did not code the #4 injector yet, but I just ordered a cable to try self coding them... The spec numbers on the replacement injector were bigger in value then the old one, so theoretically it should run a littler richer for now, which is fine with me. And it did run just fine with no stumbles or misfires at all while running the Cobb Stage 1 or Stage 2+FMIC maps for a combined two week period. And its the #6 that is misfiring this time, which happens to be one of the two old injectors left. Quote:
And I already bought the BMS WW meth kit from you, I just haven't installed it yet because I can't even get map 1 to work without misfiring. Quote:
02-22-2012, 07:06 PM | #10 | |
4918
Rep 115,980
Mike |
02-22-2012, 07:21 PM | #11 |
Rep 4,936
Stop blaming it on the tunes, You have a problem with fueling components.
Always remember, if you have a hardware problem a tune will only magnify it not cause it. You should have replaced everything at one time. Not replaced 1 or the other.
[SIGPIC][/SIGPIC]
02-22-2012, 07:46 PM | #12 | |
62
Rep 370
I know I probably should have bought 3 injectors, but I didn't realize that I still had 3 "old" injector part numbers in there until I installed the new one myself... And at $100 a pop, I was hoping the "don't fix it, if it isn't broken" theory would have applied... just wishful thinking I guess
02-22-2012, 08:03 PM | #13 | |
Rep 4,936
I went through the same thing until i replaced all injectors and all sparks plugs. Once i did that i ran 18psi and meth for 1 year problem free with my JB4. Think whatever you like to think but you have experienced members with all different tunes telling you the same thing... " a tune will just magnify an existing problem"
[SIGPIC][/SIGPIC]
02-22-2012, 08:09 PM | #14 | |
Rep 794
Gone But Not forgotten:
-07 Shelby GT500 W/ Full Bolt on E85 -08 335i 6MT W/ Full Bolt On E85/Meth -08 M3 DCT W/ Full Exhaust / Tune -13 B8 Audi S4 APR Stage 2+ |
02-22-2012, 08:18 PM | #16 |
Rep 8,745
An ugly chick would look even scarier close up!
SB, Terra, 6MT. Only a few mods here and there.....nothing extreme!
