The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Problem launching steptronic in 2nd....input needed!!
      02-23-2012, 05:15 PM   #1
jetblack07
Drives: 2007 335i
Ok here's the situation. Just got some drag radials on and decided to go out and practice some 2nd gear launches. When I rev up to 2k and let off the brake and push the throttle all the way to the kickdown point car launches perfect. No wheel spin or anything. The problem is when I get to about 4-4.5k I feel a clunk and it shifts to 3rd gear on it's own. It's not letting me take it all the way to 6k and my foot is to the floor. It doesn't do it in 1st gear and it doesn't do it if I just roll into the throttle. I'm puzzled...this happen to anyone else?
07 335i sedan AT 414rwhp/446rwtq
jb4, raceland, dci and meth...
12.06@117 with a 1.91 60'
      02-23-2012, 05:35 PM   #2
Beemw335
Drives: 335i
That doesnt sound good, but Ive never heard of it shifting on its own in m2 before redline???
Good luck.
      02-23-2012, 05:50 PM   #3
zeel
Drives: 08 AW e92 335i
Pretty weird. Could be tranny related?
Last edited by zeel; 02-23-2012 at 05:53 PM.. Reason: nvm not kickdown... saw it was goin to 3rd...no clue on this one
      02-23-2012, 06:21 PM   #4
jetblack07
Drives: 2007 335i
That's what I'm thinking....it has to have happened to someone else.
      02-23-2012, 06:49 PM   #5
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
Weird, 1st gear is known to shift short but never heard of 2nd gear doing it. No tranny error on the dash? Would it be possible to take a video of this happening?
You could reset transmission adaptations by holding the accelerator down all the way for 30 seconds with ignition on, engine off. Worth a shot.
E90 LCI N54 6AT
      02-23-2012, 07:07 PM   #6
jetblack07
Drives: 2007 335i
Yeah I'll post one up...not really sure how...
      02-23-2012, 07:10 PM   #7
jetblack07
Drives: 2007 335i
I've got the code clearing on in jb4...should I disable that to se if it throws a code?
      02-23-2012, 07:54 PM   #8
Beemw335
Drives: 335i
Yes, but check codes, you probably have transmision code a or b which wont throw any warnings, c or d will have lights in in the dash.
      02-23-2012, 08:05 PM   #9
BavanaghCndra
Drives: bmw
      02-23-2012, 08:33 PM   #10
jetblack07
Drives: 2007 335i
I was tinkering around under the hood and found that my blow off valve hose that goes to the intake tube had blown off. I guess I didn't put it on tight enough when I installed the meth elbow I purchased from themyst...took it out for a test drive...problem solved. I don't know if the fsb on the meth kit/jb4 intervened and kicked the meth off and dropped boost to factory levels which caused the tranny to upshift or what but...fixed!
      02-24-2012, 04:02 AM   #11
Bash
Bash's Avatar
Drives: E92-335i
Learn something everyday...nice
COBB S2+ - Mr.5 CAI, Catless DP, Catless MP, AMS FMIC.
      02-24-2012, 08:19 AM   #12
Velocity26
Resident old fart
Velocity26's Avatar
146
Drives: 2010 335i M-Sport
If you are testing, I would love for you to try a few 1st gear launches with the Drag Radials and see how that compares to 2nd gear launches. Most people bypass 1st gear since there is not enough traction to utilize it, but the Drags might make the difference, they have for others: http://www.e90post.com/forums/showthread.php?t=652589
      02-24-2012, 01:14 PM   #13
jetblack07
Drives: 2007 335i
See link below
http://www.e90post.com/forums/showthread.php?t=652815
