Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > HELP: Engine fan on after short drive
      02-23-2012, 10:36 PM   #1
krapnoj
IG: krapm3
krapnoj's Avatar
Drives: '12 Prius
Hey guys,
I just got done taking out the CAI and placing in the stock airbox [which required me to remove the cabin filters and the loom support under the cabin filters], then took the car out to go get something to eat locally. So we didn't drive too far. In fact the oil temps barely started to move when we parked. After an hour or so we drive back and the car's oil temps are just starting to get warmer when we pull into the garage and here the loud engine fan blowing hard. I never heard the fan on that loud with the temp being in low 40's tonight. Any ideas? Is it the water pump? or a sensor issue?
2007 E90 AW 335i -ZSP/6MT- Delivered: 4/2007 SOLD: 3/2012
ETS IC - Stett CAI - AE Exhaust - UUC SS - Morr VS8 - Mtech kit
IG: krapm3
2010 E90 SSII M3 -ZPP/ZTT/6MT-Found: 5/2012
Turner Testpipes/Stage 2 - Corsa Exhaust - Bilstein B16 - BBS LM - BBK - AutoSolutions SSK
      02-23-2012, 10:39 PM   #2
krapnoj
IG: krapm3
krapnoj's Avatar
Drives: '12 Prius
Inside the garage the temps were in the low 60's when I pulled in btw.
IG: krapm3
      02-23-2012, 10:40 PM   #3
E92TTKING
E92TTKING's Avatar
Greece
251
Drives: e92
if fan is super loud , bizarre loud its water pump
      02-23-2012, 10:41 PM   #4
krapnoj
IG: krapm3
krapnoj's Avatar
Drives: '12 Prius
if it is the water pump, then will the fan stay on no matter how cold it is outside?
IG: krapm3
      02-23-2012, 10:47 PM   #5
E92TTKING
E92TTKING's Avatar
Greece
251
Drives: e92
mine stayed on and it was 20 outside
when I turned the car off it stayed on for a while then went off
But it is VERY loud then its water pump fan
      02-23-2012, 10:59 PM   #6
boostaholic786
boostaholic786's Avatar
40
Drives: E92 N54 with MHD Custom flash
Do you have any tunes on your car? For instance the JB4 new firmware has a "Max Cool Mode". When it is enabled, the fan and water pump both turn on when the engine temperature reaches a certain degree. It's not set to a high temperature because I turned it on to see how it works and I barely went to the grocery store which is across the street and sure enough it turned on..my oil temp gauge was pegged all the way at 160 or so lol. You might have enabled it without knowing...but if you don't have a tune then it's exactly what the OP said.. Or it might be a thermostate and turns it on because it can't read the temperature.
[SIZE="2"]Crimson Red E92 335i M-sport 6-speed with MHD custom stage 2+ flash only , 40% E85/93 mix,+ HRE P40S wheels, KW Clubsport, M3 sways,+BMW performance CF Mirrors, BMW Performance CF deck lid spoiler,+ CF interior trim, p3 vent boost gauge,+ LUX angel eyes (11.73@124mph on street tires)
      02-23-2012, 11:21 PM   #7
krapnoj
IG: krapm3
krapnoj's Avatar
Drives: '12 Prius
great.. sounds like mine. Thanks for your help
IG: krapm3
      02-23-2012, 11:22 PM   #8
krapnoj
IG: krapm3
krapnoj's Avatar
Drives: '12 Prius
no tune. could I have damaged something while switching out the intake and putting in the stock air box?
IG: krapm3
      02-24-2012, 04:21 PM   #9
krapnoj
IG: krapm3
krapnoj's Avatar
Drives: '12 Prius
update:
Took it to the dealer this morning and they said "failed water pump." They gave me a loaner and said we will see you Monday.. Thanks for the quick responses guys.
FYI my car has 70k miles.
IG: krapm3
      02-24-2012, 04:40 PM   #10
marv85
marv85's Avatar
70
Drives: '07 E92 335i MT
Originally Posted by krapnoj View Post
update:
water pump never changed?
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar.
'05 C55 AMG
SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT COBB, FBO, st2 LPFP, Mfactory LSD | '07 E90 335i, PTF COBB E50, FBO, HFS4
      02-24-2012, 04:52 PM   #11
ace008
Drives: 2013 F10 535i
2007 335i  [0.00]
Seems like we are hearing alot of water pumps failing lately... Just last week, mines failed and my car was overheating. Replaced water pump and radiator under extended warranty. Car has 86k miles....
      02-24-2012, 05:40 PM   #12
krapnoj
IG: krapm3
krapnoj's Avatar
Drives: '12 Prius
Never. 2 Fuel pumps, but never a water pump. The dealer is about 15 minutes away from my house and the loud fan was on the entire time..
IG: krapm3
      02-24-2012, 05:40 PM   #13
krapnoj
IG: krapm3
krapnoj's Avatar
Drives: '12 Prius
Wow. Thank goodness for extended warranty. All I have to pay $50 for deductible.
IG: krapm3
