TPMS sensor says "INACTIVE"
02-28-2012, 10:18 PM | #1 |
Rep 32
I just mounted a new set of rims with the beru tpms sensors. After driving on the first day the tpms light came on and said "inactive". I've tried multiple times resetting the tpms using the steps offered in the manual and even methods on e90post but haven't found a solution.Also checked tire pressure and all wheels were balanced.The only thing I can think of is that they didnt balance them correctly or one or more of the sensors are bad.Any other suggestions to this problem would be much appreciated.
02-28-2012, 10:50 PM | #2 | |
Rep 8,952
Did you reset in idrive? Full reset should show TPMS initializing. You would need to drive for few blocks. Try bumping air pressure by 2lb all around then reset again. |
02-29-2012, 03:35 PM | #3 |
Rep 32
Thanks for you response Sean...I dont have the idrive so i used the left toggle and went to reset then held down the end button until it saif resetting....then drove for a bit till the tpms light goes off, but after driving a few miles the tpms goes on again and says inactive.The sensors were purchased brand new also. I do have the tire pressure to exact specs of what the inside of the door jam says but I think since the tmps is "inactive" it's not reading it.
02-29-2012, 03:42 PM | #4 | |
Rep 8,952
02-29-2012, 07:38 PM | #5 |
Rep 32
02-29-2012, 07:46 PM | #6 |
127
Rep 6,773
I had that and it wasnt any of the wheel sensors..but the TPMS control unit itself..it could also be anyone of the antennas..they all sit behind the carpet liner in the trunk near the battery
TPMS Diagram |
03-18-2012, 02:16 PM | #7 | |
Rep 1,369
Drives: F80 M3 6MT
15 F80 M3 Mineral Grey/Black 6MT
03-18-2012, 02:27 PM | #8 | |
127
Rep 6,773
Beacause I changed the wheel sensors and the problem was still there..and when I changed the control unit the problem went away |
05-30-2012, 08:59 AM | #9 |
Rep 147
Drives: E90 335i
How much was to replace the thing for tire pressure? the whole unit i mean? cause it seems i have the same problem it blink and the stays on the tires are good and everythig is there.
05-31-2012, 11:55 AM | #10 |
BimmerPost Supporting Vendor
2045
Rep 25,989
You won't lose any performance unless your PSI is actually low in your tires. It'll just give you a really annoying notification.
VMR|Wheels | 714.442.7916 |
05-31-2012, 06:08 PM | #11 |
Rep 299
Drives: 2022 X3MC BSM/SO
OP, are you sure your tire shop installed the correct TPMS sensors? BMW changed the sensors in 2010 (I think), so you need to make sure they used the correct sensors for your 2009 car.
06-27-2013, 03:39 PM | #12 |
Beach Bum
95
Rep 210
I have this dam problem.
I just had a local shop mount some new 19" Vossens and tires and now my "TPMS is Inactive." I've tried resetting with no luck. I'll try the trick of adding two pounds per wheel and report back. I really don't want to take the car back to the shop. My usual guy (sharp) isn't there and the other manager is a moron.
2018 340i - lease returned
2008 335i - sold 2006 SL55 - Sold 2004 SL600 - Sold 1999 540i - Sold |
03-10-2016, 08:01 PM | #13 |
Rep 660
Drives: 2014-320Xi / 2017-330Xi
I had the same issue yesterday. Tireman in Holland, OH. Awful experience. I run over something, not only cut my tire, but also made hole in my rim. Yes, it was huge. These guys replaced the tires, and replaced the rim. When I went to get the car, the rim was different than the other 3. Car had to stay one more day so they get correct rim. Next day, the yellow light for tire pressure is on. They say they cannot ride the car 20 minutes to reset the system, while we know just 3 or 4 miles it is all set. So I rode, but Next day I take the care back because the tire pressure is INACTIVE. I mentioned the sensor could be bad, since the wheel was severely damaged. After couple hours they called me back, everything is good, TPMS sensor was replaced and alert lights are off. They had to connect the ODB to reset, so they broke one of the prongs and the little cover doesn't hold in place. I'm meticulous and like everything right in my almost 7 years old car. The question is why these guys don't do the right thing first? Why they are so much in a hurry to don't do what needs to be done? Why they don't care and break stuff in your car? Well, to aleviate my pain, they did not charged the replacement TPMS sensor, but I would pay if I had a good service first time. They waste more time, they loose money and disappoint customers by not paying attention to the detail.
