e92 rear rubbing
03-05-2012, 09:11 PM | #1 |
10
Rep 378
e92 rear rubbing
I have 19x8.5 wheels in the rear with a +30 offset. Tire size is 245 35 19.
When i back up and turn the wheel out of a parking spot my rear rubs. I am not lowered and its a coupe. Is it the tire? is it the offset? Thanks for your input |
03-05-2012, 09:26 PM | #2 |
Rep 1,275
I can't visualize this setup, but you may just need to increase your negative camber. A decent alignment shop should have no issues recommending a setup.
Out of curiosity, did you research the wheel/offset/tire size before you installed them?
2019 ///M5 Competition
On Order: 2023 ///M3 Competition xDrive |
03-05-2012, 10:10 PM | #3 |
10
Rep 378
I got a square set up, 19x8.5 all around and was assured it would be fine. The offset arent agressive nor the tires so I thought I would be good. I also bought a set of lowering springs but now I dont wanna install them if I already rub when backing out of a parking spot
03-06-2012, 06:06 AM | #4 |
1569
Rep 29,202
I don't see the rear rubbing, but the front might be with ET30 and 245 tires.
03-06-2012, 11:17 AM | #6 |
Rep 554
Drives: E92 335i 6MT
I have 19x9.5 +22 with 245 35's stock sport suspension and a conservative roll (~10mm more clearance). I hear a faint rub if I hit dips on the highway at fast speeds. I can't see how +30 8.5's would rub in the back. If its while you have the wheel turned, could it be the front like they mentioned above? Can you post a pic of the front and back?
