Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > N00b question...
      05-16-2005, 03:36 PM   #1
roburado
roburado's Avatar
Drives: '03 Passat, '09 Cayman S
1991 318is  [0.00]
N00b question...
Say I get 19 or 20 inch wheels. Does the odometer need to be reprogrammed or something? I think I heard that somewhere. Don't know if it's true.
      05-16-2005, 04:26 PM   #2
Mark
Administrator
Mark's Avatar
6725
Drives: 1M
Nope, it definatly does not need to get reprogrammed.
The reason is that even though your buying bigger rims, you'll be getting smaller tires, so that the overall wheel+tire combo will be the same size as stock. As long as the overall size is the same, then the car doesnt notice a difference and the speedo will be on check.
You can actualy use the calculators on the top of the wheel and tire forum to see how much of a difference there will be in the speedo with your new tire setup. Use the boxes on the right to set in a new tire size
For example, I used 19" wheels with my E46 once, and I put on 235/35/19 tires on the wheels, with that setup, according to the calculator, there is only a 1.53% difference, and my speedometer will read 61mph (when im really going 60mph), not enough of a difference to really matter
      05-16-2005, 06:48 PM   #3
roburado
roburado's Avatar
1991 318is  [0.00]
Cool. thanks.
E30 1991 318is, Red on Black Leatherette
Family History: Two E21 320i, One E28 535is, One E34 535i, One E34 540i
