Now,What did i do...
03-12-2012, 04:59 PM | #1 |
Rep 153
went and got my car dynoed by a local shop one day, was impressed by the power i put down with jb4 intercooler and intake and dp 360whp. everything was good next day i was messin around with a friend of mine after he got his new car. evo 8 E85 tuned bolt ons 29psi,putting down 410 to the wheels. we did a couple pulls had our fun( lost everytime exept from a stop :/. drove home no problems. but today i get into my car start it up began to drive and noticed alot of smoke coming from my exhaust. First thing that came to mind was turbo. it only blows smoke when on acceleration. and smokes at a stop after driving. it dosent stink like burning oil but it may be. is there anything else it could be other then a blown turbo.
from research i see a couple diff numbers on turbo swaps from BMW one was over 3,000 and the other 1,800. Any help would be great
AR~~~Injen~~~BMS~~~~Hks~~~~ETS~~~~~Mtech~~~~~Helix ~~~~~Bimmian~~~~Vorsteiner~~~~~WeissLicht~~~~
03-12-2012, 05:01 PM | #2 |
Rep 153
i dont seem to have loss of psi or power.
03-12-2012, 05:07 PM | #3 |
Rep 3,730
Blew a turbo bearing seal. You won't have loss in power, it's just going to leak oil into your hot turbos and blow out smoke. Eventually they will fail due to lack of lubrication or seize up entierly. I drove around for a while with a bad seal, but eventually bought some RB's. Time for you to either a) purchase a used set of turbos from someone upgraded theirs b) but new OEM from Tischer c) upgrade to some Rob Becks, ASR, Shiv's Single, etc.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
03-12-2012, 05:09 PM | #4 |
Rep 153
thanks for the info ive been searching for RB turbos, thought that stood for Re-buildt turbos, thanks for clearing it up.
03-12-2012, 05:22 PM | #6 |
Rep 2,626
+1, he sold his last set. The wait is a couple of weeks. Definitely worth it though
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
03-12-2012, 05:49 PM | #7 |
Rep 2,978
03-20-2012, 08:27 PM | #8 |
Rep 153
bmw just quoted me $5,200 to replace the turbos.
03-20-2012, 08:39 PM | #10 |
Rep 153
haha does anyone think i need to change both turbos or just one? can i just change the seals? and last thing im blowing smoke out of my drivers side exhaust pipe is that front or rear turbo?
03-20-2012, 09:08 PM | #11 |
196
Rep 2,669
03-20-2012, 09:29 PM | #12 |
Joint Chiefs of Staff
4920
Rep 115,999
New OEM Turbos from Tischer are bout 650.00 I believe. If changing turbos I would do both. If it was me I would get the RB Turbos especially if you are going to mod the car more.
Mike |
03-20-2012, 09:37 PM | #13 |
Rep 153
whats the cost? does anyone know the labor time on an xi?
03-20-2012, 09:58 PM | #14 |
Rep 2,489
Drives: 2007 E92 SG 335i 6MT
always wondered that, how much is it to replace turbos? if parts are only 650, it must be a ton of work...
03-21-2012, 10:05 AM | #19 |
Mad Linux Guru On The Loose
1121
Rep 5,397
Drives: 2008 335i Sedan, 2023 M3
$650 EACH! That's $1300 for the pair...
03-21-2012, 10:18 AM | #20 |
Rep 2,626
yup they're at 1270$... If I have to change turbos and pay the labor cost, might as well get RBs
03-21-2012, 10:32 AM | #21 |
Rep 153
whats the cost on rb turbos? all i have seen were in the 3,00 range then expect another 1,500 in labor so im i looking at 5 k for rb turbos installed?
03-21-2012, 10:38 AM | #22 |
Rep 3,730
Yep! Don't forget about $400 in hardware (bolts, studs, gaskets, lines) if you want to use new oil lines. My RB install, all said and done, was roughly $5,500. Knowing what I know now, I would have done the turbo install myself, it's not very difficult.....just time consuming.
