BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Dealer Lying About Alarm??
      06-15-2007, 10:42 AM   #1
328droptop
Drives: 07 328i Convertible MT
k so my cars on the boat & arriving in a couple weeks...so i called the dealer asking about the alarm since ive only just realized after being on this forum that the alarm does not come standard...anyhow, after reading through all the posts related to the alarm, i realized that the best way would be for me to buy the alarm & install it myself & then just have the dealer program it. so i suggested this to my dealer & he said that they dont charge for the actual install--its basically plug & play. he said the $700 (!) fee is for the alarm itself, parts (?), & 2 hours labor to program it (which he also said is very complicated process)....anyone have thoughts on this? the dealer is essex bmw in nj by the way...
      06-15-2007, 10:55 AM   #2
Stinger
Stinger's Avatar
Drives: 2007 335i Convertible
2007 335i E93  [7.00]
1993 318is  [0.00]
1996 Z3 1.9  [0.00]
I checked the BMW web site and it says the alarm is $175 (states some additional parts anyone else know what these are and how expensive?)
Seems a couple hours of work should be around $200-$250 (assuming dealership hourly rates of around $125 an hour.)
http://accessories.bmwusa.com/ItemVi...=2&subItemId=2
      06-15-2007, 10:57 AM   #3
Ninjaneer
Shadow Warrior
Ninjaneer's Avatar
Drives: '07 335i Sedan
I thought the $600-700 was the whole shabang, not just them programming it for you after you've installed it. That sounds wrong to me... I don't have an alarm though but from what I remember reading about it before.
335i E90 / Arctic / Gray / Burl Walnut / Steptronic / ZPP / ZSP / Paddles / CA / Nav / PDC / OEM Spoiler
Mods:
PIAA Angel Eyes, Rear Fog Switch, Escort X50 Blue hardwire, 30% Charcoal Llumar
Installing soon: Rear Power Outlets (Happy Robot mod!)
      06-15-2007, 11:06 AM   #4
sterns
sterns's Avatar
Drives: '20 SMB F83
2020 M4 F83  [0.00]
2016 F83 M4 Vert  [0.00]
You might want to rethink if you really want this. I paid $500 to have my alarm installed (parts+labor+programming) with the asumption that it would work as described in the owner manual. That is, there are supposed to be 4 sensors inside the car near the foot area for each person to sense motion. These are microwave sensors built into the door panels which would sense if someone jumped into the car when the top is down.
As it turns out, if you don't get the alarm installed from the factory, the cars don't come with these sensors and the alarm you buy does not have them either. I was told when I made the appt. that my alarm would have the sensors but when I got my car back they didn't work, so we finally discovered they are not there and that it would cost $170 per sensor (+install) to add them. I am currently trying to fight this with BMWNA.
All you will get is a blinking light on the mirror, and a tilt sensor that would sense if the car is heavily jacked, like being towed. You can rock the car all day long and nothing will happen. There isn't even a glass breakage sensor. The only way the alarm goes off is if someone manages to open a door, the hood, or trunk.
Had I know this I would have looked for an aftermarket alarm more suited for verts. :mad:
'20 M4 SMB Vert
      06-15-2007, 11:16 AM   #5
JSpira
Freude am Fahren
JSpira's Avatar
Austria
336
Drives: Fünfer, Dreier, +
AFAIK, there is no option to order the alarm as factory installed.
Freude am Fahren.
Jonathan
E90 2006 330xi
E90 2006 325i
E39 2003 530i Sport*
E46 2000 328Ci*
E36 1996 328iS*
E36 1992 325i*
E30 1991 318is
E21 1982 320iS*
E21 1979 320 (6-Zyl)*
*retired
Nominated: Most Contributing Member
      06-15-2007, 11:20 AM   #6
anderson007
Drives: 330cic
Go for a lo-jack with early warning. BMW alarm is a waste of money
      06-15-2007, 11:22 AM   #7
japac1
japac1's Avatar
21
Drives: 2015 M4
2007 335xi  [0.00]
Correct. You cannot get the alarm installed at the factory, just the pre-wiring (which everyone has). I did pay my center to install/activate it. I like the blinking clown nose, and mostly, I like hearing the audible noise when I lock/unlock the car. Makes me feel better...
[FONT="Garamond"]2007 E90 335 xi, Monaco Blue, Beige, Prem, Cold, Step, Navi, Sat, iPod
      06-15-2007, 11:24 AM   #8
bartman32
bartman32's Avatar
Drives: F87 M2
2017 M2  [0.00]
Got mine parts and install for $650. BTW It takes WAY longer than 2 hours to do the programing. Expect it to be there at a minimum most of the day if not 2.
It's more of a deterent that to stop anyone. If someone REALLY wants to steal your car they will! I think of it more as a way to stop someone from breaking into it and stealing my shit.
      06-15-2007, 11:49 AM   #9
328droptop
yea my main reason for getting the alarm is to prevent/notify me of break-ins, NOT actual car theft...but now, if what "sterns" said is true about there being no glass breakage sensors, then whats the point?? can anyone else confirm this b/c theres no way im paying this much $$ for the clown nose & chip if it doesnt even have the basic components of most alarm systems...
      06-15-2007, 12:01 PM   #10
ngoni
Drives: 335i
If you read the PDF instructions from BMW (posted in the Alarm DIY) it tells the dealer to bill the time on the PROGMAN machine to warranty service.
      06-15-2007, 12:39 PM   #11
Wosby
Wosby's Avatar
United Kingdom
23
Drives: 20 G05 40i - Searching
2007 E90 335i  [0.00]
I installed my alarm myself the day before I was scheduled for regular service. My dealer "activated/programmed" it at no cost.
The labor charge they're referring to is the actual installation. Although it is a simple plug-n-play, it's very time consuming getting access (panels need to be removed and the car jacked up) to the ports where the components are plugged in. The actual programming of the already installed system doesn't take more than 5 minutes.
Install it yourself. If you have a good relationship with your service department, they'll probably do it for free, especially if you're already in for other service.
08 E92 335i - Pictured Below - Sold
07 E90 335i - European Delivery - Sold
01 E46 330i - Sold
91 E30 325iX - Stolen
      06-15-2007, 12:54 PM   #12
328droptop
thanks Wosby, so let me ask you- does the alarm have an impact sensor? like if you knock on the body or glass will the alarm go off? cuz from what ive read on the forums these alarms do not- but i also heard that the new alarms for the e92/93s are different...please let me know, thanks!
      06-15-2007, 01:44 PM   #13
Mr. BMW
Mr. BMW's Avatar
262
Drives: 2012 E92 M3
2012 M3  [0.00]
2006 330i  [0.00]
2018 Jeep Grand Che ...  [0.00]
Your dealer is trying to rip you off. I paid $380.00 for the alarm and installation when I got my car in April 2006. $700 is way too much.
12 M3 Interlagos Blue/Black
18 Jeep Grand Cherokee (Yeah, it's got a HEMI)
21 X3 Silver/Black(Wife's)
06 330i Monaco Blue/Black (retired)
02 X5 3.0 Topaz Blue/Black (retired)
      06-15-2007, 01:51 PM   #14
Dinan335i
Drives: Turbo Vert
Wow. This is really good to know. I was thinking about getting it also, but w/o the motion sensors it is a complete waste.
Have any of you convertible owners out there found a better solution?
A.
      06-15-2007, 01:53 PM   #15
rsjames
Drives: 07 335i Montego Blue
$700 is way too much? Heh. Crevier quoted me $1025. I said no thanks.
      06-15-2007, 02:49 PM   #16
BMW F22
BMW F22's Avatar
Drives: ///M235i
it should be around $500 or so...
      06-15-2007, 02:51 PM   #17
GregL
GregL's Avatar
98
Drives: 2016 CLA45 AMG
You should e-mail a couple of different dealers. That's what I did here and now I have written confirmation of prices ranging from CAD$522.50 + tax all the way up to $960 + tax.
2016 Mercedes-AMG CLA45
2013 Mercedes-Benz B250 - Gone
2010 Mercedes-Benz C350 4Matic - Gone
2006 BMW 330xi - Gone
2001 Infiniti QX4 - Gone
      06-15-2007, 02:53 PM   #18
rrandyy
Drives: E92 328
There is no aftermarket alarm solution for any E9x. You're stuck with what BMW offers.
      06-15-2007, 02:54 PM   #19
Bimmer335i07
BK Employee of the month! / Moderator
Bimmer335i07's Avatar
Drives: BMW 335i Sedan
2007 335i  [0.00]
If you want the shock sensor, you should read this thread.
http://www.e90post.com/forums/showthread.php?t=45815
I haven't had time to get the parts, but when I do, I will do this mod.
Btw, I paid $495 for my alarmed installed.
Sponsored by: Pics of the ---> Barbera Beast <---
Martino Auto Concepts (Like them on Facebook MAC) Factory Trained & Authorized by BMW of North America
Matt@Camber-Toe (Like them on Facebook Camber-Toe)
LuxAngelEyes (Like them on Facebook LuxAngelEyes)
LTBMW (Like them on Facebook LTBMW)
OEMconcepts (Like them on Facebook OEMconcepts)
      06-15-2007, 03:07 PM   #20
Magictek
Drives: 335xi Arctic Metallic
My dealer installed the alarm for 695 or so. According to the manual it has a interior motion sensor if your windows are up (I have an e90). I have never tested this however. For the most part the blinking clown nose is what I am really paying for so that the theif will try for a 'easier' car next to mine...
      06-15-2007, 04:01 PM   #21
msimon18
Retired
msimon18's Avatar
Drives: Z4 s30i
I am having the alarm installed in my E93 Monday for $495. It will have the motion sensors - I verified this today.
There is no factory installed option.
The installation takes a full day and they are giving me a new BMW as a loaner fro the day or two if it takes longer. The actual ionstallation takes about 3 hours rest of the time os for programming. For some reason the BMW programming process takes forever due to all the options that can exist in a car. Seems to me these could be self sensing but apparently they are not.
M3 GTR - 1/5 scale - 4.2 HP w/ Collari hydraulic brakes - would you believe ~80 MPH on straightaway !!
      06-15-2007, 04:03 PM   #22
GregL
GregL's Avatar
98
It doesn't help either that BMW connects to the car with a serial connection.
