4/14 HPDE at Thunderhill, might rain, tips?
04-09-2012, 01:57 AM | #1 |
151
Rep 1,677
Any tips from seasoned veterans? This will be my second time. First time was at Infineon last month. Ran 32 psi (cold) on the tires all around and Bilstein coilovers were 8/9F and 9/9R. They were pretty stiff.
04-09-2012, 03:39 PM | #2 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
Set the rebound to soft. Put 2-4 PSi more air in the tire. Stay off of the painted stuff. Don't run slicks (treaded R-Comps are okay). Take most corners 1 gear higher than you normally would in the dry. Keep car 1/3-1/2 car width from the apex and exit (reason being, more oil and tire laid down right on top of the apex and exit and when initially wet, they're more slippery unless it's been driven over a few times).
Other than that...Stay sunny side up.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
04-10-2012, 03:33 PM | #3 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
What Hack said, STAY OFF the painted surface as it'll be slick as ice, last thing you want to do is drive over it and end up going into a wall. End of day, as obvious as it sounds, you want to avoid wherever the water collects so try to figure out which areas have good drainage and stay there. Being smooth is even MORE important during the rain!
