Intake Valve Cleaning - Pictures of Carbon Buildup
04-17-2012, 05:38 PM | #1 |
Rep 2,314
I'm putting together a more comprehensive DIY for Walnut Shell Blasting than what is out there. After removing the intake/throttle body I snapped a couple pictures of the carbon buildup. It's interesting to note, that some with higher mile cars have less buildup. Mine needed cleaning.
Year: 2008 e92 Miles: 49.5k (lots of stop and go Houston highway traffic at 110+ degrees) Notes: Always had a good amount of blow by Cyl 1 Cyl 2 Cyl 3 Cyl 4 Cyl 5 Cyl 6 Last edited by ianthegreat; 04-17-2012 at 07:35 PM.. |
04-17-2012, 08:27 PM | #5 |
Rep 748
Cyl 1-3 aren't too bad.
2008 335I E92, AW, VFF700, 18" Forgestar F14, M3 front/side, M-tech rear, AMS IC, H&R Touring Cup Kit suspension, HID AE, ER Charge Pipe & Synapse BOV, CIC Retrofit, Quafie, DSS, Defiv Lockdown, SPEC 2+/Steel SMFW, Walbro 450
04-18-2012, 02:55 AM | #9 |
Rep 2,559
I've done the walnut shell blasting with the BMW tool last Sunday. I'll post up some pictures and a review of that too, most probably this week-end.
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
04-18-2012, 03:16 AM | #10 | |
Objects in the mirror are losing
105
Rep 1,133
Drives: 2007 BMW 335i E92 AW/CR 6MT
PERFORMANCE: JB4 G5 \ Backend Flash \ DCI \ BMS Downpipes \ CX FMIC \ ER Chargepipe \ Synapse BOV \ KW V2 \ Muffler Delete \ CDV \ ZHP Shifter \ Cyba Scoops FUN: M3 Front \ Mtech Rear \ JL 10W6 \ ModMyNav \ V1 Hardwired \ LUX H8 \ Gloss Black Trim \ Gloss Black Roof \ Cyba Quads \ Cyba Mtech Diffuser |
04-18-2012, 07:45 AM | #11 | |
Rep 2,314
I think the hardest part is going to be able to create/build something to fit the blaster and shopvac in the same inlet. |
04-18-2012, 08:37 AM | #12 |
55
Rep 1,690
^^That blaster is pretty cool!
I have been considering doing this myself and the idea I had to prevent the shells from going everywhere I was considering cutting a peice of thick, clear plexiglass and putting two holes in it. One bigger than the size of the blaster (so it can be moved around) and for the vacuum part I was going to get a micro cleaning kit similar to this one (will probably need a bigger opening but you get the idea) http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1 and use the small pointed head in the second hole for suction. Plus the plexiglass will allow you to see what you're doing. Edit: Here is the BMW part number 81 29 2 208 037 for the adapter Last edited by BoostedE90; 04-18-2012 at 09:26 AM.. |
04-18-2012, 08:47 AM | #13 | |
Rep 2,559
As for the adapter for the inlet, it should in fact be included in the package (it's even pictured on the manual provided with it), but in my case unfortunately was not. We therefor had to improvise and used a hose attached to the vacuum cleaner with a small hole for the blasting wand. Wasn't perfect, but it worked. I have now ordered the adaptor separately, which should make things much easier. Alpina_B3_Lux
04-18-2012, 09:22 AM | #14 | |
BMW
71
Rep 974
04-18-2012, 09:30 AM | #15 |
55
Rep 1,690
Awesome! Thanks for the reply. Glad to know the plexiglass idea works. If you don't mind me asking what blaster did you use?
04-18-2012, 10:31 AM | #16 | |
BMW
71
Rep 974
But I just got the cheap portable blaster from Harbor Freight (same as what other members have used: http://www.harborfreight.com/portabl...kit-37025.html
04-18-2012, 11:42 AM | #17 | |
Rep 2,314
04-18-2012, 11:43 AM | #18 | |
Rep 2,314
All in all I've spent maybe $150 of an air compressor, blaster, and shells (shells are on back order from harbor freight though ) Anyone know if a Lowes or Home Depot sell these? |
04-18-2012, 12:12 PM | #19 |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
Apparently bird supply stores carry bunches of the stuff.
04-18-2012, 12:15 PM | #20 |
Rep 1,137
I'm at 60k now and have been considering doing this as I already have a compressor and shop vac. Don't you need to remove the head?
2008 335i coupe AW 6AT, RB Turbos, PROcede 2.5 V5, Alpina Flash, Injen Intake, VK MW DP . Helix IC, Vishnu PnP Meth(M10 nozzel), M3 sides, OEM Aero Lip, VMR V710 Midnight Blue, LUX H8, HID Fogs, M3 front bits, D2 Coilovers, Whiteline Rear Bushing inserts, Custom M3 Steering Wheel, Cyba scoops, M2 Performance Exhaust |
04-18-2012, 12:33 PM | #22 |
king of the hills
92
Rep 2,915
No, just the intake manifold. You are just trying to get to the backside of the valves and intake port, not the cylinders themselves.
