Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > EFI Logics Custom Tuned Stage 2+ 1M
      04-18-2012, 08:48 PM   #1
EFI Logics
EFI Logics's Avatar
Drives: '08 BMW 135i, 08 535Xi
This past weekend a customer brought us his gorgeous stage 2+ 2011 1M for custom tuning. After strapping the car down and installing a set of Forge diverter valves, we smoke tested the new intercooler system and discovered a small boost leak due to an improperly installed coupler. After the boost leak was resolved we went ahead with getting some baseline figures with the stock map and Cobb OTS map. The 1M has CPE catted downpipes, modified mid-pipes and bigger front mount intercooler already installed. The stock map put down 339whp and 393wtq with all of the modifications already installed. The Cobb OTS map put down 345whp and 406wtq. After some carful custom calibration we were able to make a healthy 371whp and 434wtq! This particular gained 26whp and 28wtq over the Cobb OTS map.
If you have any questions don't hesitate to ask!
-Josh
      04-18-2012, 08:59 PM   #2
rader1
70
Drives: Cobb Stage 2+ 135i
Good work guys!!! The overboost on the stock tune doesn't leave as much room on the table for peak numbers. I bet on a multi gear pull it's a world of difference
      04-18-2012, 09:08 PM   #3
805beemer
Drives: 2008 135i
They dont have a stage 2 map for the 1m yet so the ots map was just stage 1 correct? I'd like to think cobbs ots stage 2+ map would make similar numbers to your custom tune once released by cobb. Did he have an intake?
      04-18-2012, 09:11 PM   #4
Surquhar
Surquhar's Avatar
47
Drives: 2012 E92 M3
Nice work! I continue to be impressed!
992 C4
      04-18-2012, 09:16 PM   #5
onesuperboi
onesuperboi's Avatar
Drives: '08 e92 335i COBB 4.01 Stage 1
Wow. The 1M puts that much torque stock?
That's almost 100 more TQ and around 70 HP than stock N54.
      04-18-2012, 09:53 PM   #6
dfv2
dfv2's Avatar
Drives: 2009 CTS-V
What fuel was used, guessing 93 octane?
Do you think there is power left on the table due to lack of octane? Would you have added more timing throughout the powerband if the fuel supported it (E85, meth, etc?). One more, lol, did you guys do any tuning of the vanos cam timing or did you keep cobb's OTS values?
//ecg//
      04-19-2012, 08:39 AM   #7
Lulz_M3
Drives: AW 335i 6MT
The fact that those numbers are on a mustang dyno make it even more impressive. Thats got to be a blast to drive.
      04-19-2012, 08:58 AM   #8
nitehawk
nitehawk's Avatar
102
Drives: e92 335i 6MT
+1. That is a mountain of torque!
      04-19-2012, 12:17 PM   #9
themyst
themyst's Avatar
South Korea
177
Drives: '16 MK7 GTI
Which Cobb OTS map was used for that run?
E90 LCI N54 6AT
      04-19-2012, 12:19 PM   #10
marv85
marv85's Avatar
70
Drives: '07 E92 335i MT
with the overboost feature, it almost runs twice the boost
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar.
'05 C55 AMG
SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT COBB, FBO, st2 LPFP, Mfactory LSD | '07 E90 335i, PTF COBB E50, FBO, HFS4
      04-19-2012, 12:22 PM   #11
RnmEvo9
247
Drives: 2007 335i
+1
      04-20-2012, 03:15 PM   #12
EFI Logics
EFI Logics's Avatar
We are comparing the Cobb Stage 1 aggressive map to our Stage 2 and the stock calibration. After speaking with Cobb, the stage 2 map should be out soon for you guys who want a canned solution. As for making the same power as our custom calibration, I doubt it. Cobb leaves some room on the table since the OTS mapping is typically conservative. I will say that after tuning this car, BMW themselves didn't leave a whole lot of room in there, these cars are pretty stout from the factory.
- Chris
      04-20-2012, 03:18 PM   #13
EFI Logics
EFI Logics's Avatar
This was tuned on 93 octane, which is the local premium fuel here on the East Coast. We actually did advance the timing, along with tweaking the cam timing (Although there wasn't much found in doing so). We will be playing with E85 in our shop N54 5 series, but until then it's hard to tell. I do believe other forum members are just mixing 50/50 E85 to the cars and allowing the car to learn itself, I'm personally not a fan of it, but we shall see how it goes on our car.
- Chris
Edit: This car was tuned with the stock intake + Forged Diverter valves.
      04-20-2012, 03:28 PM   #14
Elliott@DetailAddict
Drives: E90
EFI for the win!
      04-20-2012, 03:33 PM   #15
805beemer
Drives: 2008 135i
- Chris
Thanks for the info chris. I'm not knocking your tuning ability, I just wanted to make sure which ots map your were comparing your custom tune to. I and I'm sure many others would love to see a dyno on a stage 2+ car comparing the ots 2+ map to your ATP protune to see how much power a custom tune will net. Would be nice if the 1m can come back for a dyno run once cobb has the 2+ map. Keep up the good work!
      04-20-2012, 03:41 PM   #16
BrianMN
114
Drives: 4 Door Family Sedan
- Chris
Sorry if I missed this- but is the graph in the first post Mustang dyno numbers or the Shootout/Dynojet numbers?
I'm looking forward to your higher power results in the coming months! Should get a ton of east coast customers when the power creeps above the 400hp range (Dynojet, Pump-Only)
      04-21-2012, 09:30 AM   #17
EFI Logics
EFI Logics's Avatar
Thanks for the kind words. We are going to have a healthy database of BMWs soon given the cars we have already calibrated, are about to calibrate and cars from the dyno day we are hosting soon so you guys will really be able to get a nice sense of how much power can be made given specific modifications and tuning.
All of the numbers seen are from our mustang dyno.
-Josh
      04-21-2012, 10:10 AM   #18
E90SoFlo
196
Drives: E90 335i
So you showed a Stage 1 cobb tune vs a Stage 2 tune from you guys. Why?
      04-21-2012, 10:19 AM   #19
dfv2
dfv2's Avatar
Drives: 2009 CTS-V
You're talking LTFT...
As you know the N54 is full time closed loop, and STFT is quite capable of NAILING afr targets even on the very first pull after DME clear with 40% E85 on a 93octane OTS tune (admittedly close to maxing STFT)... So, why not a fan? You don't trust the DME? So long as you know the STFT limits it's all fun and games. This ain't your nephews ej257!!
//ecg//
      04-21-2012, 10:33 AM   #20
ZTZ1010
Aficionado of All Things Vroom
ZTZ1010's Avatar
Drives: 2020 F97 X3M Competition
wish this was a typical full bolt-on N54 with OTS/ProTune differences.... AA/ESS both make mid 340rw stg1 so with a little tweaking this sounds about right based on a stage1 map. nice results.
Current: 2020 F97 X3M Competition
Retired:
'18 6MT AW F30 340x Drive | '15 6MT F80 M3| '11 AW DCT E92 M3| '09 6MT AW E90 335i| 08' 6MT E92 328xi
      04-21-2012, 10:59 AM   #21
Q4P
Q4P's Avatar
Drives: Too Much
wow looks great!! would love to see this beast on a race gas map.
2jZ + RB26 + 4G63 + LS9 + N54 =
      04-21-2012, 01:03 PM   #22
Duke
Duke's Avatar
Drives: E92 335i
Wow that's a huge improvement in torque!
Tags
bmw 1m, calibrate, cobb, custom tune, efi logics
