dyno results cobb ap stage 2 +fmic
04-18-2012, 09:20 PM | #1 |
Rep 107
So few of you may remember my thread when i first bought my car all give you guys as much info i feel is help full, I normally don't post results on forums but it seems that there is not a lot of info to be found still.I came from having pretty modified STI and posting on those forums was painful, but this forum is awesome!
Car info 08 335i 6 speed dyno pulls done in 4th gear on the same dyno as the stock pull. i dyno the car the first time at 47,000 miles then this pull was done with 52,000 about 4 months apart. have a baseline 100% stock New pull i have these mods cobb ap stage 2 aggressive+fmic beta 401, ar down pipes, remus axel back, ams fmic, and intake. Now i know the weather is different but i tried to keep is constant as possible from baseline same wheels were used to dyno the car same dyno and things of that nature. I hope you guys can benefit from this info. Last edited by va05sti; 04-18-2012 at 09:33 PM.. Reason: uplode vid |
04-18-2012, 09:42 PM | #2 |
169
Rep 1,677
Wow looks like a beast
| 09 335i Coupe | Alpine White/Coral Red | M Sport | 6mt | Premium | Logic7 | 19" Beyern Mesh | 20% Tint | LUX Angel Eyes | 5000k Fogs | Black Kidney Grill | BMS DCI | Cobb Stage 1 | M-Pedal Set | Painted Side Reflectors | Rear Lip Spoiler | Euro Front Plate | Passport 9500ix | BIM Coded |
Who is John Galt?? |
04-18-2012, 10:23 PM | #6 | |
33
Rep 1,029
http://www.e90post.com/forums/showthread.php?t=665232 |
04-18-2012, 10:43 PM | #9 |
33
Rep 1,029
04-18-2012, 10:59 PM | #10 |
70
Rep 2,197
Ok, here's his logs. I made two because there was so much timing correction happening it made it almost unreadable.
The first shows timing on cyl 1 and it looks bad. The second one shows corrections on all cylinder. IMO they look like they're knock induced and i'd recommend switching over to a less aggressive map immediately. |
04-18-2012, 11:01 PM | #11 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
OP, are you running 93 or 91?
The i8 needs a V8 amirite?
04-18-2012, 11:11 PM | #13 |
33
Rep 1,029
Heat soak could cause it, but I personally heat soak my car on purpose while logging to ensure it will run optimally in all conditions. Add a splash of race gas or E85 and get some more logs, see if it looks better.
04-18-2012, 11:12 PM | #14 |
70
Rep 2,197
Here's one shing your IATs. Start of pull they are 111F and top out at 126F.
The temps are warm, but IDK if they would cause universal timing corrections like that. Definitely possible. |
04-18-2012, 11:13 PM | #15 |
33
Rep 1,029
Not to thread jack but for anyone else running S2+ on V401 what are you seeing for timing advance? I did some logs tonight and max I'm seeing is around 7-8 degrees with no corrections. I was expecting more...
04-18-2012, 11:28 PM | #17 |
Rep 16
04-18-2012, 11:56 PM | #19 |
Rep 107
04-19-2012, 12:54 AM | #21 |
Rep 107
besides gas any one have any other idea what it could be i been in the car scene for awile but new to the bmw world. and advise would be awesome. all start with some new gas and new logs
04-19-2012, 01:31 AM | #22 |
114
Rep 2,428
Although that seems quite low for a "Stage 2+" tune, it looks to be pretty in-line with the other COBB cars. It would appear that Cobb is just not at the point where they want to start pushing more power yet with OTS maps, which isn't by accident or lack of ability.
Simply put- the numbers in the dyno above would be similar of a bone-stock car with a procede/new maps, and maybe a little less with the JB. Assuming your car is similar to the other FBO N54s, with your mods you would likely be around 400hp/440tq with a piggyback (without meth). I'd definitely suggest getting your car protuned and get off of these OTS maps |
