Help!! Problem after bov installation
04-19-2012, 07:02 PM | #1 |
Rep 672
*Update, just got the codes read and it says cylinder 5 and cylinder 6 misfire, is that a spark plug problem or more serious? I'm starting to think it has nothing to do with the intake and bov**
I installed the dual cone intakes and a Greddy Type S bov today, everything went fine, but after starting the car, I'm hearing a small knocking sound from the engine and the bov is working incorrectly, only thing I suspect is my vacuum because the vacuum line is not 100% tight on the small plastic nipple on the car, would the vacuum cause that? Please give me your input, I can't drive the car right now! I sealed up the places where the old dv houses were and the spot next to the bov also
Realtor, Architectural Engineering
Remax 200 Realty Winter Park, FL Last edited by JoNaH; 04-20-2012 at 05:12 PM.. |
04-19-2012, 10:28 PM | #3 | |
Rep 672
Remax 200 Realty Winter Park, FL |
04-20-2012, 05:39 AM | #4 |
Rep 128
Also make sure you're connecting the vacuum hose to the right nipple on the BOV. The type S has 2.
From experience, I'm not a fan of the Type S. you can get all sorts of issues (flutter, Etc) if the adjustment screw isn't properly set. |
04-20-2012, 03:54 PM | #6 |
Rep 672
I installed the stock diverters back on and still getting the same problem, car shakes a lot at idle and no steady rpm, then shakes very bad at acceleration while lagging very much and not accelerating properly, also got a service engine soon light. Anyone have any input?
04-20-2012, 04:23 PM | #7 | |
Rep 2,626
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar.
'05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT COBB, FBO, st2 LPFP, Mfactory LSD | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
04-20-2012, 04:28 PM | #8 |
Rep 672
put them back on correctly, can't really get codes cleared until wednesday, unless discount auto parts can read codes!
04-20-2012, 04:30 PM | #9 |
Rep 672
the stock dv's are back on correctly, only thing different is that i got the dual cone intakes on and thats it yet the car still driving like crap, will clearing the codes make this problem go away?
04-20-2012, 05:13 PM | #10 |
Rep 672
04-20-2012, 05:24 PM | #11 | |
Rep 2,626
I find it weird that you didn't have any misfires and suddenly they appeared after trying to install a BOV. below is a clip by COBB detailing misfire diagnosis (excluding injectors)
04-20-2012, 05:38 PM | #12 | |
Rep 672
