Any common driveshaft faults among RWD 335's?
04-19-2012, 08:27 PM | #1 |
Rep 2,396
Yesterday while driving I started hearing faint clicking throughout the interior. I couldn't pinpoint where it was coming from, but then I realized that I could feel it very faintly through the shifter.
Today I took a quick drive around the block with windows down and the clicking can be heard from the outside a lot more. It's very fast clicking, faster than the wheels turn so I'm thinking it might be either driveshaft or output shafts. Clicking does not depend on engine speed, clutch in or out or gear. It happens on deceleration only either in gear or in neutral. Now I do have around 500 pounds of torque to the wheels but I never usually launch the car. The car had Quaife LSD installed about 1500 miles ago and there's a chance the shop did something not right. Any areas i should be looking at? |
04-20-2012, 03:42 AM | #4 |
Rep 623
Ya I would drop it off at the shop you just got your LSD put in at... I have the same LSD and I don't have any clicking of any sort of what you described. And since you just got your LSD 1500 miles ago it might have something to do with it that's probably pretty simple (hopefully). Let me know since I have the same one so I can keep an eye out for anything that might come up. And I as well don't hardly ever launch my car..usually do 50-150mph pulls on highway loosing just a little bit of traction
[SIZE="2"]Crimson Red E92 335i M-sport 6-speed with MHD custom stage 2+ flash only , 40% E85/93 mix,+ HRE P40S wheels, KW Clubsport, M3 sways,+BMW performance CF Mirrors, BMW Performance CF deck lid spoiler,+ CF interior trim, p3 vent boost gauge,+ LUX angel eyes (11.73@124mph on street tires)
04-20-2012, 09:39 AM | #5 |
Rep 2,396
I checked few things last night myself. Had the car running in gear with both wheels jacked up and climbing under it listening to stuff (scary shit).
It doesn't look like it's the diff, the sound was coming more from driveshaft area but I couldn't really pinpoint it because of the heat shields. Shop will take exhaust and shields today and gonna try to pinpoint it |
04-20-2012, 10:44 AM | #6 |
I even mod my cereal
246
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
The bushing that connects to the passenger side driveshaft to the diff on my 335 failed and caused the diff to break. Might want to look there as well.
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
04-23-2012, 02:00 PM | #9 |
76
Rep 1,883
I broke my drive shaft while going WOT in 3rd gear. The CV joint that goes into the rear diff failed. Lots of grease everywhere. About pooped my pants when it happened. Nice loud noise.
Doesn't seem common though.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
04-23-2012, 02:10 PM | #11 | |
76
Rep 1,883
Haven't had a problem with it so far and that includes plenty of drag strip launches with drag radials. Who knows though. If you are considering buying a new OEM one, maybe you will want to contact AR and see if they'll make you an aluminum one instead.
04-23-2012, 05:09 PM | #13 |
246
Rep 3,441
LOL...I bet! when stuff breaks at that kinda speed it always sounds/feels 10X worse than it probably really is..
07-23-2012, 10:09 AM | #14 |
Rep 2,396
Little update.
Broke my axles and got DSS 1000hp axles. Right after they got installed shop mechanic took the car out on a test drive and the noise that I explained in 1st post came back. They say the weights inside DS came loose, also there's a crack developing in center U-joint. Gonna send whole thing to DSS and see if they can do anything with it. |
07-23-2012, 10:16 AM | #15 | |
76
Rep 1,883
07-23-2012, 06:33 PM | #18 |
69
Rep 310
Drives: 2007 BMW 335i M-Sport E90
I too recently bought a 2007 335i import from Japan and have noticed a slight clicking or rumbling noise at idle. I got it checked out by the compliance centre and they've said there is nothing wrong with it. Sounds normal, however I do have mechanical insurance if something does break in the long run so i'm not too worried but still wanted to find out if something needs to be replaced soon'ish to stop a bigger fault later on.
07-23-2012, 07:34 PM | #19 |
28
Rep 457
^ manual trans also??
the slight clicking or rattling At idle is usually the input shaft. Meaning the pilot or throw out bearing. If you press the clutch and it stops then that's what it is. Seems to be a normal issue with getrag/BMW manual setups as my 540 was the same. |
07-23-2012, 09:44 PM | #20 |
69
Rep 310
^ It's an AT. Definitely sounds from the mid to rear of the vehicle and can be herd more from the left side than right. Seems odd I know but I can't pinpoint what it is.
The engine purrrs under acceleration or deceleration. |
07-27-2012, 12:13 PM | #21 |
Rep 2,396
Heard back from the shop.
Both times it was the weights inside the DS. First time it was rear section, now front. Newsflash! A driveshaft is a hollow tube, like plumbing pipe! I thought it was solid piece all this time The weights are being removed and DS rebalanced. |
07-27-2012, 01:50 PM | #22 |
Rep 7
I am curious if I have a similar problem...
The noise in the cabin, while not deafening is certainly louder than my last BMW ('06 325i). I also have noticed a small amount of vibration coming from the floor. Obviously, the RFT's are very loud so I got the Michelin Pilot SS. The noise is only slightly diminished. The sound appears to be worse when the rear differential is under stress (acceleration and deceleration). However, it never goes away completely. Is this similar to the OP's problem? |
