installed vanguard exhaust now this
04-20-2012, 11:16 AM | #1 |
@cndream
17
Rep 101
i just had installed my vanguard exhaust on my 08 335i coupe an now im throwing a cat code an the car is in limp mode. im new to the 335 world so is there a way i can get the light off so i can pass inspection? would appreciate all the help. also im in NEW YORK
04-20-2012, 11:36 AM | #7 |
Rep 7,377
you installed a fully catless exhaust without having a tune ? The engine will throw codes since its complaining about the missing cats.... Get COBB tune and run stage 2, Codes gone and 70 whp added to the wheels...
04-20-2012, 11:40 AM | #8 |
Rep 2,160
Depends on what your state inspection is...
If its sniffer test you may be able to pass as long as your secondary cats are still in place. If its OBD scan then the ONLY way you will pass inspection is with the DP fix. Cobb wont work because it only surpresses the cat readiness state. |
04-20-2012, 11:47 AM | #9 |
Rep 2,132
Drives: FBO+ N54xi
Get cobb or jb4 or procede, really do your research and get a tune if you want to take advantage of ur catless exhaust and really see what going catless + tune can do..As for the codes get a tune and bms dp fix v3 and u should be good to go. im in NYC as well and with bms dp fix u should have no problems passing inspections..
JB4+usb | P3 Vent Boost Gauge v2 | BMS OCC | BMS DCI | AMS FMIC | AR xi CL DP's | BT Tool | Edibias/NCSExpert/INPA BMW Coding | Cyba Quad Exhaust tips | M-Tech Rear & M3 Front Bumper | Red Cyba Air Scoops | Blacklines | Vinyl Overlays | ACS Roof Spoiler | Matte Black Grilles | LED Side Mirrors | Rear Euro Fogs | etc..
04-20-2012, 01:37 PM | #13 |
Rep 2,014
Wow 2nd thread in a couple days with people getting Dp's prior to a tune. Very interesting.
OP, you might as well get a tune to take full advantage of your current set up |
04-20-2012, 01:45 PM | #14 |
Rep 2,626
COBB would suppress cat codes, but your car should not go into into limp anyway
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar.
'05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT COBB, FBO, st2 LPFP, Mfactory LSD | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
04-20-2012, 01:56 PM | #15 | |
I even mod my cereal
246
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
should be changed to an island
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
