3100 low boost mode engaged -- CEL displayed
04-21-2012, 08:22 AM | #1 |
Rep 2,621
I have been trying to diagnose a fault with my N54.
The car started stumbling/shuddering at high RPM and WOT - No codes were generated.. I replaced all the spark plugs and cleaned the Vanos solenoids (swapping them over on refit) - this seemed to resolve the shuddering. It seemed better for a week or so, but then I pulled a code for misfire on cylinder 3 started to get cut boost when repeatedly going WOT. I replaced the ignition coil on cylinder 3 and again things seemed much better. Now the car runs like a champ pulling strongly with/without meth. BUT... the car still occasionally goes into reduced boost - like 8/9psi. Could this be as a result of air in the meth line and the failsafe kicking in? a minute or so later its good to go! A few back to back runs like this and switch to map two - I dont usually have so little mechanical sympathy, just trying to trigger a code!! pulls hard through the rev range and then when lifting off I trigger a CEL! Hopeful of finally pulling a code I Connect laptop and the only thing recorded is: 3100 low boost mode engaged -- CEL displayed What could be the problem? Other coils, Injectors, fuel pump? Its difficult to diagnose without codes...
Car: e91 330d with Viezu map
Gone but not forgotten: 2010 Jaguar XFR (Cat-back exhaust, pulley, intake mods and map), Highly Modified E90 335i LCI M Sport Manual (circa 480BHP/500lb ft) |
04-21-2012, 10:34 AM | #2 |
Rep 3,456
Drives: Harrop E90 M3
Possibly a vacuum leak in the waste gate circuit, or binding/sticking waste gates- aka turbo time
04-21-2012, 03:28 PM | #3 |
Rep 522
Any other codes?
Have you checked your vacuum hoses that goes across the engine? Have a look at them and the hoses from the vacuum canisters to the pressure converters. I just changed mine today as a pre-caution. The looked like they had seen better days. |
04-22-2012, 09:51 AM | #4 |
Rep 2,621
I'll give this a try. Thanks
08-01-2013, 08:06 AM | #6 |
Rep 2,621
Changed the vacuum lines, canisters and boost actuators.
Runs well now.
11-03-2013, 12:39 PM | #8 |
Rep 2,621
Yep
