Engine Malfunction!!
04-21-2012, 01:30 PM | #1 |
Rep 656
So, yesterday I was driving on the freeway and right when I pressed down hard on my gas pedal (to accelerate) my car got this error on the dash and I was limited to about 2,200 rpm!! WTF is going on? Is this a boost leak, limp mode? What is it. I waited unti the car's temp was at the cold start temp of 160 F but still that error was there! I looked at the car manual and it said that there was something wrong with the engine functioning and that it wasn't opperating how it should and therefore engine power had to be kept at a minimum.
Performanc Mods: Air Scoops, Down pipes, Exhaust, JB4. I also run on Map 2 all the time as a daily driver. Idk if that is the reason or not but I figured I would comment on that. I believe I have the neccessary mods to run it at Map 2. Anyways, WTF is going on here?? |
04-21-2012, 01:35 PM | #3 |
Rep 656
04-21-2012, 01:36 PM | #4 | |
Rep 1,473
Read the instructions for the JB4. It reads codes. |
04-21-2012, 02:10 PM | #5 |
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
Same thing happen to me on both tunes (JB4 and Procede).
If you have auto-clear your won't know the code when you hook up laptop. Best thing to do is shut down car for 2 minutes and restart again and drive again. |
04-21-2012, 02:16 PM | #6 |
54
Rep 327
what octane gas are you running? Also read the DME codes via JB4 under user settings.
24 XM(Current)
22 X540i(Sold) 21 M5 Comp(Sold) 07 Single Turbo 335i(one of the first, sold) |
04-21-2012, 03:02 PM | #7 |
Rep 2,013
Restart the car the limp mode is gone. Once you go wide open throttle, it will most probably come back. You need to read the codes with a serail to usb cable and connect to your laptop, or even in dash code reading with the jb4.
04-21-2012, 03:04 PM | #8 |
242
Rep 2,781
Drives: E90 335i Racecar
I might have had the same issue with you. It could be your in tank fuel pump. My car would act normal and then I would stomp on it in 6th gear and it would go into limp mode and idle like a 69 camaro. Go to a kragen and get an obd2 reader and get the codes. Im sure it is a pump issue if it went like that after you step'd down on the throttle.
HG Motorsports | Motiv Motorsport | Sparta Evolution | BBS Motorsports | Sabelt | JRZ | NASA ST1 SoCal --- 554whp/487wtrq --- 3200lbs <<YouTube Channel w/ Race Videos>> |
04-21-2012, 04:20 PM | #9 |
Rep 2,132
Drives: FBO+ N54xi
Scan the car with either the jb4 or a BT cable, no1 can really tell u anything with no codes..
JB4+usb | P3 Vent Boost Gauge v2 | BMS OCC | BMS DCI | AMS FMIC | AR xi CL DP's | BT Tool | Edibias/NCSExpert/INPA BMW Coding | Cyba Quad Exhaust tips | M-Tech Rear & M3 Front Bumper | Red Cyba Air Scoops | Blacklines | Vinyl Overlays | ACS Roof Spoiler | Matte Black Grilles | LED Side Mirrors | Rear Euro Fogs | etc..
04-21-2012, 05:40 PM | #10 |
Rep 7,377
OMG i have never seen that light! must be bad... relax and read the codes. probably got it like 50 times in 3 years...
04-21-2012, 07:10 PM | #11 |
Rep 623
Do you have the USB cable attached with your JB4? How long have you had your JB4 or when did you purchase it? Depending on what firmware your JB4 is set to you might need to update it which requires you to have the USB cable. Its like 25 bucks or something man and is definently well worth it! You can click on settings tab with your JB4 interface and there is a box that says read DME codes. All you do is click on the read DME codes. Whatever codes you have, right the codes down and click delete all codes. After that see if the problem comes back and if not your good but if they do then you need to fix what the codes are. Its easy once you get use to it dont worry anything and everything can be fixed
04-21-2012, 07:16 PM | #12 | |||||
Rep 656
Ok that makes me feel a little better. Should I just put it on map 0, delete all the codes and take to dealer? |
04-21-2012, 07:21 PM | #13 |
33
Rep 1,034
Fuel pump
04-21-2012, 10:26 PM | #15 | |
Rep 1,476
No worries OP its just the warning light. On the good side the ECU just went into failsafe mode. Hopefully its just a misfire code |
04-21-2012, 11:02 PM | #16 |
Rep 656
thanks man. So can you elaborate on the failsafe mode? And what's a misfire code?
04-22-2012, 04:30 AM | #17 |
Rep 7,377
the "limp" mode switches off the boost control. No boost. You have to read the codes otherwise nobody can help...
04-22-2012, 06:53 AM | #18 |
Joint Chiefs of Staff
4918
Rep 115,980
Here is BMS' form response to getting a "reduced power mode":
Any time you get check engine light (yellow half engine or reduced power indicator) or service engine soon light (orange SES) the first step is to read the codes. With a JB4 installed there are two methods. The easiest method for beginners is to connect the laptop interface and use the "read codes" button under settings. This will give a full listing along with descriptions. Alternatively for more advanced users or if a laptop isn't available you may use the in dash reading on menu 1 option 1. Directions for that method are here: http://www.n54tech.com/forums/showpo...98&postcount=1 If a JB4 is not installed you can also use a BT or CT tool to do the scan. Once you have the exact code details email those in for advice. Mike |
04-23-2012, 01:02 AM | #19 |
33
Rep 1,034
04-23-2012, 03:30 PM | #20 |
Rep 621
I wouldn't be running map 2 on 91 octance unless you are logging to make sure everything looks ok, and from the sound of it I'm sure you have no clue how to log. I'd switch to map 5 (autotuning map) or even back it down to map 1.
Read up on the JB4 instructions on code reading and make sure you turn off the "auto-clear" function. |
04-23-2012, 03:43 PM | #21 |
Rep 2,014
04-23-2012, 10:47 PM | #22 |
Rep 656
Ok. So I turned on my car just right now. It started revving high and low by itself!! I wasn't pressing down the throttle. Also my car was shaking and making very loud sounds (kin of like a winding sound). Then the half engine light came on again, followed by the yellow service engine soon light. I turned the car off, turned it on again and it did the same thing!! I'm going to try and see if I can hook the cable up to the laptop and read the code. But until I do. Wtf is this??????? And has anyone encounter ed anything like this???
