how to plug up second diverter opening?
04-21-2012, 03:42 PM | #1 |
Rep 672
i been searching everywhere and can't find an answer, i got the plugs to plug up the return lines for the diverters after installed my BOV, what is used to plug up the hole where the second diverter valve was? the hold next to my bov where that second diverter use to be? any help would be much appreciated.
04-21-2012, 04:43 PM | #4 |
Rep 92
"4. Remove the stock diverter valves and plug the intake holes. What I used is the rubber caps that are put on the bottom of chair legs 7/8 size the 1' should work as well. I got a set of 4 at Lowes. They are pretty tight put I also bought small clamps from pep boys. Here is what it looks like."
http://www.e90post.com/forums/showthread.php?t=615084
E92 Cobb Stg2+ | VRSF Dp's | BMS DCI | AA Sport FMIC | Morr VS8.2
04-21-2012, 10:23 PM | #6 | |
Rep 672
Realtor, Architectural Engineering
Remax 200 Realty Winter Park, FL |
04-21-2012, 10:23 PM | #7 | |
Rep 672
04-21-2012, 10:36 PM | #8 |
70
Rep 2,197
04-21-2012, 10:51 PM | #9 |
Rep 672
So leaving it functional won't affect the new bov? No other way to plug that hole
04-22-2012, 01:52 PM | #12 |
Rep 462
I think it would be a good idea to plug both since the go to different turbos who know what one turbo getting recirculated and the other not can cause
Irub |
03-30-2015, 06:52 PM | #13 |
Rep 197
Drives: e93 N54 335i MHD TUNED
I know this is an old post, but i was wondering if you were able to find a way to plug that DV hole up? I'm looking for a way my self, i'm using a HKS with an adapter on my stock charge pipe, until i have the need to replace it with an aftermarket CP. Thanks
03-30-2015, 10:31 PM | #14 | |
Rep 672
04-04-2015, 03:52 PM | #15 |
Rep 197
Thanks! I found it on YouTube. I just cut the bottom part of the stock Diverter valve and plug it with an expansion plug and popped It back down in the hole. Seems to work fine and hold the 12psi of boost.
04-05-2015, 08:31 AM | #17 | |
Rep 197
04-05-2015, 10:53 AM | #18 | ||
Rep 672
04-05-2015, 11:28 AM | #19 |
Rep 197
I'm not sure on BMW DV's, but I know that on Audi DV's you can actually switch the recirc side with the boost side of the DV and have a pull rather than a push type DV.
If BMW is the same, you can switch around the one of stock DV's and use it as a plug. This way the only valve venting is the BOV, but the hole for the other DV is plugged. |
04-05-2015, 01:25 PM | #20 | |
Rep 2,013
335i e92 TPC 19Ts
04-05-2015, 04:32 PM | #21 | |||
Rep 197
04-05-2015, 04:38 PM | #22 | |
Rep 197
