DIY - halogen to xenon error removal
06-20-2007, 05:41 PM | #1 |
parachute
96
Rep 539
DIY
rememeber: I am not responsible if any damage occurs to your car. price reduced to $180! ---- 1- Screw relay onto hole behind bumper (hole is a plastic plate underneath headlight, where the arrow shows). this keeps the relay high and away from water (even when it is a water resistant relay). 2 - Connect fuse end to battery 3- Connect round connector to ground 4 - Disconnect pin #3 from headlight connector by applying pressure on the little hole above it with a needle 5 - Connect bmw pin from harness in the place of pin #3 6 - Connect original pin #3 to the last wire and tape it up - remove original fog light and brake plastic piece that separate pins (so that the connector fits -very easy to do, look at the last picture, thats not the original fog light, it's for illustartion purposes) - place foglight back in it's housing - connect socket from harness to fog light - connect 27w bulbs to the original fog light socket and adjust the fog light harness so that the bulbs are held onto the bumper facing towards the engine. (don't worry, they only turn on if you press the fog light button) If you need to know how to do the initial swap of the lights refer to this thread: http://www.e90post.com/forums/showth...+halogen+xenon
335i Coupe - LeMans Blue
325i Sedan - Mystic Blue (Retired) Last edited by parachute; 12-07-2007 at 05:02 PM.. |
06-21-2007, 01:30 PM | #2 |
Rep 441
First of all, Parachute, you are THE MAN!
Secondly, my 323i did not come with OEM fogs. I just finished reading that entire 28 page thread in which you figured this out. Basically, my question is, if I wired this with the relay and added the fogs in line as you suggested, would it still work? What I mean to say is, if I add the foglights inline and add the housings to the bumper, will I be able to install xenons AND fogs (that light up with the headlights) without ANY error? If so, that is incredible! |
06-21-2007, 01:54 PM | #3 | |
parachute
96
Rep 539
325i Sedan - Mystic Blue (Retired) |
06-21-2007, 02:01 PM | #4 |
Rep 441
Awesome man! The two things I most regretted not getting in my car all tied up into one nice and easy mod! Dude, you are the MAN.
Euro Xenons: Ordered! Fogs: Lemme see if I can find that old FS thread! |
11-10-2007, 09:50 PM | #5 |
156
Rep 1,207
Drives: SG E90 325i sport + idrive
Garage List E90ANdy Lighting So ... [0.00]
cbv v bb [0.00] 06 E90 SG + M3 19&q ... [0.00] 06 E90 SG + Iforged ... [0.00] |
Hey Parachute, I just got some projectors and NON-oem ballast. They are made by Osram. So yeah, i did the wiring and everything for the projector conversion 5+6 together and ground to 2. My HID's flicker really fast. They would work fine for about 10seconds and then do that.. Will your harness fix this? If so.. LET ME KNOW! thanks for your help
AIM me if you have it :: ******* |
11-14-2007, 09:33 PM | #6 |
Rep 62
If I can throw in a question as well for Parachute.
Will your harness leave the fog lights on all the time? Let's say leaving the switch on 1) auto 2) parking light |
11-15-2007, 10:29 AM | #7 | ||
parachute
96
Rep 539
in auto mode, when low beam automatically turns on, so do the fog lights in parking light mode, only angel eyes light up, no fog lights you can also set up this harness so that the 2 27w bulbs provided turn on with the low beams and hide them behing your bumper with a housing i don't provide. and you will have OEM operation of all your lights ERROR FREE!
11-15-2007, 04:07 PM | #8 |
156
Rep 1,207
i got my my xenons to stop flickering using capacitors 4700uF 35v. But have errors.... :/ What does this harness include? is it plug and play? or do i have to modify my harness to integrate this.
11-15-2007, 04:10 PM | #9 |
parachute
96
Rep 539
plug and play man, check the diy pictures above. everthing is explained there
12-06-2007, 10:54 PM | #11 |
Rep 1,402
thank you parachute,
the last picture explains alot better. I think it starts to make sense now so my question is do I take the blue color fog lamp plug from your hardware and plug directly into my fog lamps? I don't need to worry about the existing fog lamp wiring, correct?
323i, Arctic metallic , Cream beige leatherette interior , Titanium matt trim , Premium , Auto , 18" style 189 sport wheels , 335i bumper + kidney grills, CF pillars, Chrome window trim package , LCI halogen.
12-07-2007, 05:00 PM | #12 | |
parachute
96
Rep 539
01-20-2008, 11:34 PM | #15 | |
Rep 1,402
I've noticed Parachute has a built-in fuse, will it help the over heating problem?
01-20-2008, 11:40 PM | #16 | |
G-STAR
200
Rep 1,897
I am not sure if the Parachute will overheat or not. |
01-21-2008, 02:33 AM | #17 | |
Rep 1,402
01-21-2008, 02:43 AM | #18 |
G-STAR
200
Rep 1,897
My kit doesn't. I do not sell it though. It's a simple black box with everything built in. 8A fuse with a 10A relay that supports 12 lines. The relay is the most expensive thing.
For foglights make sure you use 35W, or 55W max. Don't go 100W bulbs. |
06-06-2008, 10:07 AM | #19 |
E60
39
Rep 587
is there a way to set this up with resistors rather then the bulb? any help on this? i finally have time to install this kit i bought months ago but im not too fond of using the dummy bulbs
07-27-2008, 12:42 PM | #20 |
E60
39
Rep 587
what is the set up for this in comparison to the instructions above (im asuming reverse the connections between the dummy bulb and fog lights)? where can i find the housing to hide the bulb?
07-31-2008, 04:00 PM | #21 | |
parachute
96
Rep 539
and regarding the previous post from excellence, there's no such meltdown issue
08-03-2008, 10:40 AM | #22 |
E60
39
Rep 587
anyone experiment with resistors to replace those bulbs yet? id try it myself but i dont know which ones to use. does anyone know?
