Hks Ssqv4 Bov, Working Or Not? Video Inside
04-23-2012, 04:27 PM | #1 |
I <3 My E93
180
Rep 3,259
i dont think my bov is functioning at all, its suppose to be sucking in air then releasing it making a whistle sound...but it does nothing..can this cause alot of damage to my engine since it isnt sucking or releasing anything?
Bagged and Wrapped E93 335i
04-23-2012, 04:51 PM | #2 |
Rep 906
Drives: 2008 535xi / 2011 Z4 35Is
It shouldn't be sucking anything.
04-23-2012, 05:01 PM | #5 |
Rep 878
best way to find out is, go WOT with windows open and see if you hear the whoosh. i can hear mine even with windows closed but to be sure have windows opened that way you can hear it better
just saw the video you posted, mine does that also. people tell me you have to oil the valve if it gets stuck and you should be fine.
08 335i | Space Gray | Burl Walnut Wood Trim | Sport pkg | Premium Pkg | LOGIC7 | Navi | Comfort Access
| COBB | Injen DCI | Active Autowerke | Sonic Tuning | E92 Lighting | ER | HKS | BMS | Ground Control | Vortex Tuning | |
04-23-2012, 10:40 PM | #8 |
Rep 854
That's odd, when I had my 08 335i with hks ssqv 4 I could hear the BOV go off just revving it...
10' Solid Red GTR
08' 335i 6MT - Sold 92' NA 300ZX 5speed - Sold 06 IS350 - Sold |
04-23-2012, 10:42 PM | #9 |
I <3 My E93
180
Rep 3,259
So it looks like the actuator is not releasing pressure, since I got this installed in a shop 5 hours from me and I have no idea how to put back my stock diverter valves in , so will leaving the hks bov installed cause damage to my engine bc it may not be releasing pressure ?
04-23-2012, 11:22 PM | #10 | |
Retired e90post Member
135
Rep 3,038
now that i think about it, did the shop cap of the connections for the DVs? |
04-23-2012, 11:56 PM | #11 |
Rep 1,019
Double check to see if you connected the vacuum line. Just drive the car and you'll know. Also, I could be wrong but if you're AT then put it in N.
@ichi_ban
04-24-2012, 09:55 AM | #15 | |
3441
Rep 79,211
If it wasnt hooked up correctly or not working correctly you would likely be having some drivability problems, hesitation, bad idle, and or bucking. Along with plenty of codes, like over-boosting if it was stuck closed, I would imagine. or under-boosting if it releasing pressure to soon. |
04-24-2012, 10:14 AM | #16 |
I <3 My E93
180
Rep 3,259
I have to check after I go home I'll go WOT and see if I hear anything
but I have no drive ability issues , no bad idle , I don't know what bucking is lol, but I have no warming lights on the dash But will any warning lights come up in the dash if there's a boost leak Or under boosting ?? Best bet is to get a bav tool to see if I'm throwing codes??
04-24-2012, 10:19 AM | #18 |
3441
Rep 79,211
You dont even need to go WOT, just give it some boost and let off the gas, it should release pressure and you should hear it. You would throw codes and CEL for anything on this car, its German
04-24-2012, 10:23 AM | #19 |
I <3 My E93
180
Rep 3,259
But what I don't under stand is the dude in the 2 nd video I posted he was in PARK and revving his engine and you can clearly hear his hks bov making a whistle sound
When I'm in park and rev I don't hear shit lol If my bov is indeed not working will it cause damage to my car bc it's not releasing pressure ?
04-24-2012, 03:24 PM | #21 |
Rep 1,019
Check that C-Clip if it's locked in cause you might have boost leak from it being loose. Next try putting your car in N and then try revving it (just a thought)
@ichi_ban
04-26-2012, 09:40 AM | #22 | |
I <3 My E93
180
Rep 3,259
When I rev my engine in my garage I can here a pshhh sound when I let go of the gas Since you have a tune and intakes etc maybe it makes the bov louder? Do you have the hks ssqv4 bov?
