Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Help with tire sizes for 2007 bmw 328i Sport
      04-25-2012, 08:57 PM   #1
Kngli
Drives: 2007 BMW 328i Sports Package
Hey guys,
I have a 2007 BMW 328 w/sport package and came with stock tires of these sizes
front: 225/45R17 on 17x8 RIM
back: 255/40R17 on 17x8.5 RIM
i was looking to get a new set of Michelin Super Sport (keeping the stock RIMs) but Michelin SS doesn't come in those sizes. The closest is
front: 225/45R17
back: 245/45R17
the back wheels thus will be slightly lower (approx 4mm in radius) than the stock ones.
Can anyone tell me if this is exceptable configuration and what/if there's any negative performance imapct.
Thanks appreciate your help!!!
      04-25-2012, 09:26 PM   #2
Gator335i
Gator335i's Avatar
20
Drives: E38 E39 E60 E70 E92
If you had the sport package you'd have 18s, not 17s.
      04-25-2012, 09:41 PM   #3
Kngli
Its a sedan it has 17s.
      04-25-2012, 11:03 PM   #4
JS82
JS82's Avatar
Drives: '08 E92 328i 6MT Jet Black
I would just buy the Michelin Pilot Sport 2 tires in the correct size.
      04-26-2012, 05:38 AM   #5
Wilhelm
Drives: 3281T
Many functions of your car, such as the DSC, rely on accurate speed data going to the computer. The tire's overall diameter affects the speed information that goes to the computer.
The speedometer on your E90 shows the speed based on the rear wheels. The diameter of the new rear tires would be 0.66 inches more than the current rear tires, or a 2.53% difference. For a passenger car a 3% or under difference is generally considered acceptable.
The speed difference with the larger diameter tires at 60mph would be +2mph. BMW feels that a speedometer error of up to 10% + 2.4 mph is acceptable. So at 60mph the speedometer could show up to 68.4mph (60+6+2.4). Add to this factory built in calibration error the 2mph increase attributed to your new tire size and the speedo could show 70.4mph when you are actually going 60mph. Other than that, you should be ok.
      04-26-2012, 07:01 AM   #6
driverman
Drives: 2008 328i 6MT - SOLD
I have a similar question.
The diameter of the stock 225/45/17 front tires is 25" (833 revs/mile)
The diameter of the stock 255/40/17 rear tires is 25".
Since Michelin doesn't make the 255/40/17 for the PSS, there are 2 options:
The diameter of the 245/40/17 rear tires is 24.7". (841 revs/mile)
The diameter of the 245/45/17 rear tires is 25.7". (810 revs/mile)
What difference would the 10mm narrower and 4mm shorter (98 mm vs 102 mm) than stock 245/40/17's make in handling? It seems like narrower would reduce understeer and shorter would increase understeer. Would there be any noticeable difference in handling?
How about the 245/45/17's? They are 10 mm narrower but 8 mm taller (110 mm vs 102 mm) than stock. Once again, 10 mm narrower would reduce understeer but 8 mm taller would also reduce understeer. Would the net effect be oversteer?
The 245/40/17 seems like the better choice. That's what the e46 sedan with sports package had in back with 225/45/17's in front.
Regarding speedometer error....
I think our speedometers normally read at least 5% too high. If we went with 245/40/17's in the rear, the circumference would be about 1% smaller, which would help reduce the discrepancy.
      04-26-2012, 01:26 PM   #7
Kngli
Thanks for your response. I'm just being little too hard headed on the Michelin SS, the PS2 would do but its an older model, not as good, and suprisingly more expensive than the SS....it doesn't make sense to go wth PS2.
I'm going to check with the dealer but they would likely say stick with recommended sizes even if nothing wrong, i mean why would they recommend anything different unless they are your friends .
      04-26-2012, 03:07 PM   #8
Kngli
This is the best information i've found so far
http://www.automobile-catalog.com/ti.../bmw_330i.html
The site doesn't list the specific model (2007 328i w/sp) i'm looking for but the 2006 330i is pretty close.
The spec for the tire diameter difference is pretty consistent for all bmw which is
+3%/-2% in diameter.
And these BMW model uses the configuration i'm looking for....
2002 BMW Z3 3.0i Front Tires 225/45ZR17
2002 BMW Z3 3.0i Rear Tires 245/40ZR17
2000 BMW 328Ci ZR Wheel Package Front Tires 225/45ZR17
2000 BMW 328Ci ZR Wheel Package Rear Tires 245/40ZR17
2006 BMW 330Ci Sport Package Front Tires 225/45ZR17
2006 BMW 330Ci Sport Package Rear Tires 245/40ZR17
      04-26-2012, 06:19 PM   #9
username604
username604's Avatar
Drives: bmw
2008 BMW 335i  [10.00]
You can put 225s all around. The difference is 0.2% - last I checked.
That's like nothing! At the top of the tire section of this forum is a tire calculator.
Having 225s all around will help make the car feel more neutral in corners. I don't think the 328i would have a hard time putting down its power on 225s.
I would recommend spacers for the rear if your go that route to make sure the car looks extra spiffy!
      05-17-2012, 09:36 AM   #10
driverman
Can an expert (like Gary) chime in on this?
Many of us with 328 E90 sedans with ZSP would like to get a set PSS's but we don't know what the effects would be of installing 245/40/17's in the rear instead of 255/40/17's.
- 245/40/17 are .4" narrower than 255/40/17 (wheels are 8.5" wide)
- 245/40/17 go 841 revs/mile; the 255/40/17 go 833 (1% difference)
Would we notice a difference in normal driving? Spirited driving?
If so, could we increase tire pressure in back to compensate?
Thanks.
      05-17-2012, 10:49 AM   #11
Gary@TireRack
Moderator
Gary@TireRack's Avatar
Drives: Formerly 1995 M3
245/40R17 is such a small difference in size compared to 255/40R17 that you would not see or feel any real world differences in normal or spirited driving. You could add a psi or two in the rear but that is also not something you would notice.
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp
Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum.
      05-18-2012, 07:49 AM   #12
driverman
Thanks Gary.
      05-18-2012, 08:18 AM   #13
Surly73
535
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
My 328i sport came with style 160s, a square 17x8J setup calling for 225/45/17 on all four corners. The PO has some all seasons on there. No trouble with rear grip and it's nice to have a square setup.
      12-11-2018, 09:38 AM   #14
PeterBernhard
Drives: 2007 bmw 328 xi sport wagon
Have a 2007 328 xi wagon with sport package. 17 inch rims. 225 45 R17. Sits low and want to raise bottom height using wheels and tires. Anyone know max rim or tire size for this vehicle. 18 or 19 inch wheel? 65 as opposed to 45? Would a 19 inch wheel and 225 60 R19 work? Is there enough clearance?
      12-12-2018, 06:19 AM   #15
johnmyster
Drives: 2011 e92 n52
Going one size wider or narrower will not be noticeable. You're talking 4mm reduction in sidewall. 8mm (1/3") in diameter. Significantly more than that occurs during the life cycle of the tire itself due to tread wear.
Stock diameter on my car was right at 25". I ran/run 26" nominal setup no problem.
225/40r18, 235/40r18, and 245/40r18 fronts, on 18x8 rims. 245 fronts barely touch fender liner on one side at full lock. Not enough to worry. Plenty of clearance to spring perches on struts.
255/35r18 and 255/40r18 rears, on 18x8.5 rims.
235/40r18, and 245/40r18 rears, on 18x8 rims.
All Michelin Pilot A/S3+. I'm cheap, so I run whatever deals I run across. Currently I'm 18x8 square with 245/40 all around, which is a pretty happy setup.
      12-12-2018, 06:24 AM   #16
johnmyster
Wrong direction. You'd need a taller tire to get the speedometer closer. A 26" tire would be 4% taller, and would be pretty close.
