Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > tramlining
      04-26-2012, 12:14 AM   #1
wrcftw
Drives: BMW 335i
tramlining
So i bought a 335i Coupe in March. Had winters on and I had a BMW shop do an alignment etc. Everything was all good, until i put my summers on. Running stock rims, 225 fronts 255 rears on the OEM Bridgestone RFT. The car tramlines like crazy on anything but freshly paved, grooveless roads. Is this the tires causing the problem, or is it because the widths are staggered, or did the BMW shop screw up the alignment?
Any suggestions on how to fix this without spending alot of money? It feels almost dangerous, I just about got thrown into another lane today when my attention wandered for a second....
      04-26-2012, 01:27 AM   #2
skatenc123
skatenc123's Avatar
11
Drives: 2007 335i coupe
Take it backto the place that did the alignment make sure everything is all good. If it wheels get your wheels check for bends etc.
      04-26-2012, 10:40 AM   #3
asus389
asus389's Avatar
Drives: 11 E90 328i
2011 BMW 328i  [0.00]
What tires? The Re050a RFTs tramline quite a bit. Also what PSI are you running? But yeah, get a printout of the alignment settings they used. If your toe is off it can make the car feel very darty.
      04-26-2012, 11:24 AM   #4
wrcftw
Drives: BMW 335i
The Bridgestone Potenza RFT's, I think the psi's are 35 all around
