Mixing gas and JB4
04-26-2012, 11:28 AM | #1 |
Rep 439
Mixing gas and JB4
Okay guys, I had a couple quick questions regarding mixing 93 octane and E85. I ran strictly E85 before in my evo and have it on hand, 1 mile down the road. With that being said, I have seen that a 30% mix of E85 is appropriate for map 5 use. Now if I am filling my tank all the way, I should get 10 gallons of 93 and 3 gallons of E85 to make the mixture?
Tell me what do to guys!
2011 335is "Redrkt" 6 MT
DocRace 6266 Single Turbo - Fuel it stage 3 LPFP - Fuel it PI - spec stage 3+ clutch - mfactory SM flywheel - 100% E85 - VRSF 7.5" intercooler - VRSF charge pipe w/ HKS BOV - JB4 - MHD back end flash 768 whp 695 ft lbs - E85 - 32PSI |
04-26-2012, 03:51 PM | #2 | |
DIYER
614
Rep 5,521
Here is a thread about mixing: http://www.e90post.com/forums/showthread.php?t=665920
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
04-26-2012, 04:01 PM | #3 |
54
Rep 327
I am working on a custom map 6 for this map to see how it will work out, just waiting on some DCI's to finalize it, and then I will be posting up the settings for you other guys to try it.
24 XM(Current)
22 X540i(Sold) 21 M5 Comp(Sold) 07 Single Turbo 335i(one of the first, sold) |
04-26-2012, 04:06 PM | #4 |
DIYER
614
Rep 5,521
Hell yeah!!! I want to do this bad, would the 25-30% mix be enough for your map you're working on?
04-26-2012, 04:08 PM | #5 | |
54
Rep 327
I tried a 50/50 mix but my car got fuel mixture codes thrown at it.. so the most I am doing is the 70/30 .
24 XM(Current)
04-26-2012, 04:12 PM | #6 |
DIYER
614
Rep 5,521
That is what I do...4gal of E85 and 10 gals of 93.
04-26-2012, 04:39 PM | #8 |
54
Rep 327
that's more then a 70/30 mix. With 10 gallons you should only be putting in 3 gallons of e85.
Simple math people. Let's say you are getting 6 gallons of 93, you would then add 1.8 gallons of e85 to make it 70/30 6 *.3 = 1.8
24 XM(Current)
04-26-2012, 06:17 PM | #10 | |
62
Rep 370
So if you were to pump 14 gallons total, like robc1976 and I are doing, 30% of that is actually 4.2 gallons... But just to make things easier at the pump, I've been running 10/4 which is actually 29%
2009 Z4 35i 6mt, SpeedTech 6266 Gen2 turbo kit, Tial WG, VRSF 7.5 race IC, ER charge pipe, Tial BOV, Radium Fuel cell w/ surge tank and twin Walbro 525 pumps, Radium FPR and return line, Bluetooth ethanol sensor, Phoenix intake manifold w/PI, JB4 tuner, PR coil packs, Custom oil cooler, ECS Radiator, Spec 3+clutch, Mfactory flywheel, single 3.5" into dual 3" exhaust, H&R springs, 19" TSW wheels, 235/19 & 275/19 RE11 tires
04-26-2012, 07:03 PM | #11 | |
Objects in the mirror are losing
105
Rep 1,133
Drives: 2007 BMW 335i E92 AW/CR 6MT
PERFORMANCE: JB4 G5 \ Backend Flash \ DCI \ BMS Downpipes \ CX FMIC \ ER Chargepipe \ Synapse BOV \ KW V2 \ Muffler Delete \ CDV \ ZHP Shifter \ Cyba Scoops FUN: M3 Front \ Mtech Rear \ JL 10W6 \ ModMyNav \ V1 Hardwired \ LUX H8 \ Gloss Black Trim \ Gloss Black Roof \ Cyba Quads \ Cyba Mtech Diffuser |
04-26-2012, 08:05 PM | #12 |
Rep 897
I've been running 11 gals 93 4 gals E85 with a JB4 car Map 2 (14.5 psi) just a DCI and the logs look great. No timing drops, lots of power although I did bump my open loop fueling to 95 to make sure I wasnt maxing out my fuel trims.
04-26-2012, 08:58 PM | #13 |
11
Rep 399
Doing the same E85 is good stuff!
JB4 G5 ISO W/BMS FLASH, FBO, Walbro LPFP, Spec S2+ SMFW
04-26-2012, 09:05 PM | #14 | |
Rep 658
map 5 was stronger than map 2 for me and my only mod is jb4 |
04-26-2012, 09:07 PM | #15 |
DIYER
614
Rep 5,521
I am testing ths now...map 5 is strong for sure. Map 2 you should have Dps & FMIC WICH MAY BE WHY MAP 5 is stronger for you...I had only dci and tried running map 2 and it was not as powerful as map 5 but when I added Dps & FMIC it was a totally different ball game!
04-26-2012, 09:16 PM | #16 |
DIYER
614
Rep 5,521
I may look into this as well
04-26-2012, 09:30 PM | #18 |
DIYER
614
Rep 5,521
Have you tried map 2 yet? If you do tell us hat feel,I better.
04-26-2012, 09:30 PM | #19 |
54
Rep 327
I just tried it on Map 7 - holy shit. Logged and sent to Terry for his feedback. I would suggest not doing it tho. Just doing an experiment. But my boost gauge read up to 18 PSI at one point.
24 XM(Current)
04-26-2012, 09:35 PM | #20 |
DIYER
614
Rep 5,521
So tempting!!! I want 16.5pi so bad...basically a map 2 with 2 psi added on lol!! Still deciding on if map 2 or map 5 is better ll!!
04-26-2012, 09:40 PM | #21 | |
54
Rep 327
I roll raced a buddy of mine on Map 5 and he would pull me hard, but soon as I switched to Map 2 I would pull him. So it really depends on your style of driving..
24 XM(Current)
04-26-2012, 09:42 PM | #22 |
Rep 495
But doesnt Map5 have a higher possible max PSI with the right mods? up to 16 PSI on map 5 compared to 14.5 on map 2? how could map 2 be stronger?
Garage///2013 e92 M3 ZCP ///2007 e90 335 FBO/// |
