Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Wheel Spacers
      04-26-2012, 09:21 PM   #1
Lankster
Sigma Alpha Epsilon
Drives: 2007 335xi
Wheel Spacers
Hey guys searched the forums and couldnt find any recomendations. What would everyone recomend for a daily driver '07 335xi all stock? I was thinking 15's around but dont want ANY wheel rub.
      04-26-2012, 09:53 PM   #2
hxs80
hxs80's Avatar
Drives: 2008 E92 328i
Lots of info on spacers if you <search> around but from what I've gathered, it seems more people went for the Mach Schnells. 12 to 15mm rear and 5 or 10mm front on stock 18" rims. Some other member posted pictures on another thread with 15mm rears and he had no issues at all and they looked good.
      04-26-2012, 11:37 PM   #3
nOshi
nOshi's Avatar
Drives: TiAg E90 335i
I wouldn't worry about spacers on stock ride height, especially on an xi. I'm not sure which stocks your running, so it would be hard to throw out a recommendation. But as hxs80 posted, theirs a ton of info on various setups. Check out the "Wheels and Tires" section.
      04-27-2012, 04:18 AM   #4
username604
username604's Avatar
Drives: bmw
2008 BMW 335i  [10.00]
i'm keeping stock on my front and putting 20s on the back with a slight stretch on the rear tires.
pre-lci e90s can take like 25mm without rubbing last i checked
      04-27-2012, 12:05 PM   #5
cssnms
cssnms's Avatar
Drives: 2011 BMW 335d
Check out VAC's wheels spacers. I ordered them and they are VERY nice. They make them in-house. I also own like 3 other brands.
http://www.vacmotorsports.com/catalo...-bolt-kits.htm
Alternatively RS Technic makes a nice a spacer, sold by PY Speed or Velocity motorcars spacers.
IMO though the VAC spacers are some of the nicest feeling/looking spacers that I have seen. They seem like a real quality spacer.
      04-27-2012, 02:00 PM   #6
335BBS
55
Drives: 2009 335 coupe.
Depends on offset of your wheels. If offset is correct you wont need spacers to fill the wheel well.
      04-27-2012, 02:02 PM   #7
oshusttoley
Drives: 2008 335i sedan
whats the point of putting spacers in? sorry im kind of a noob to all this. i just recently bought an e90 pre-lci like a month ago
// JB4 ISO // Running Meth // Full FBO // E85 user //
      04-27-2012, 03:02 PM   #8
Bingobimmer
Bingobimmer's Avatar
157
Drives: e90 n54
People use spacers so that their wheels are flush with the fender.
LOST BUT NOT FORGOTTEN 2009 E90 335i AW... Black grills/jb4/lux angel eyes/clear side reflectors/and a few more small mods
2011 e92 335iSSSS Black
      04-27-2012, 03:37 PM   #9
ECSTuning
New Lifetime Replacement Policy
ECSTuning's Avatar
815
Drives: Independent Tuning Specialists
I'd measure the "gap" on your particularity car so you can decided how aggressive you'd like to go. HERE is a pdf we did a while back that shows how to easily measure for spacers.
      04-27-2012, 03:58 PM   #10
avocet
Drives: 2007 328i 2011 X5d
I am running 15mm front with oem 17 and 19's(winter summer) and find the 15 a little too aggressive, meaning I think it sticks out a little far. Doing it again, I would run 12 or 10 front and 15 rear. 18mm on rear will touch around hard corners(sport susp with staggered set up).
This is with an e90.
      04-27-2012, 04:02 PM   #11
edirtaynine
Drives: e92
on stock xi suspension, you could run negative offset. lol
      04-27-2012, 08:42 PM   #12
username604
Drives: bmw
same car, same wheels, but one of them has spacers.
