Q: People with LSD!
04-27-2012, 02:32 PM | #1 |
17
Rep 338
Q: People with LSD!
For people with an aftermarket LSD.
Do you always drive with your traction control completely off. (holding dtc button), Or only turn it off when you need to? Would turning traction off be better to get the most noticeable difference with the LSD.. I just got an Quaife LSD installed ordered from HPautowerks, and I do notice a difference in traction when i floor it from a stop, i dont lose traction. What kind of tests did you guys do when you guys received your LSD to make sure it was working properly?
2007 335i e92 Sport package (BSM)
04-27-2012, 02:35 PM | #2 |
Rep 3,730
Waited about 1,500 miles then changed the diff fluid. Once it was "broken in" she was raced around several tracks, drag strips, and spirited driving. The first time you step on it, you will immediately feel the difference. No more unpredictible one wheel burnouts. While at the track, it helps tremendously when exiting corners as well.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
04-27-2012, 02:57 PM | #3 |
104
Rep 1,529
can anyone explain the difference between static and dynamic lock for clutch lsds? cause im trying to decide whether to get a clutch type or torsen type, but what does the dynamic lock on clutch type actually do?
Space Gray l 6MT l OSG LSD w/ VAC Race Diff Cover l Cobb e30 l Morr vs8.2 l UUC SSK w/ DSSR l VSRF Catless Dps l RPI Intercooler l CDV Removed l HID AE 8000k l ETS Catback l AST 5200 w/ Vorshlag Camber Plates l ER Dual Oil Coolers l Rear Camber and Toe Arms l K&N Drop In l Solid Tranny/Diff/Subframe Bushings l Bridgestone RE-11
04-27-2012, 03:03 PM | #4 |
Rep 963
Old fashioned lock were either on or off. Nowadays both types can be variable.
E90 traction control is passive, which means it only kicks in if it detects a wheel spinning (which is less likely now) I find ESP off, dtc on is a good compromise, but even fully enabled traction light hardly comes on now. Chris |
05-01-2012, 04:50 AM | #5 |
17
Rep 338
Should i be always driving with DTC on, or Holding dtc with traction fully off... or should i just leave the traction on.. Which is the best with a quaife LSD.
What should my setting be on, if i want to take an aggressive turn? or If im flooring straight line from stop? or if i take a highway ramp fast?
