Just removed Clutch pedal spring (mod)
04-27-2012, 11:08 PM | #1 |
Rep 942
Read about it on another M3 forum and the guys were taking the clutch pedal springs out. Has anyone else done this? 15 minute job. I looked at how it worked before I removed it and basically it's a spring that works upon release of the clutch pedal. when the pedal is traveling back up it helps slow it down. Kind of like a door closer. However now I notice the pedal has a lot of side to side slop. So I may have a worn clutch pedal hinge bushing.
'07 335i Sedan, base pkg, 6spd Manual, Procede 3 V5 w/NLS, Macht Schnell Downpipes, 18" Staggered 313's w/Conti DWS's, OS Giken TCD LSD, VAC Street Diff Cover, Dinan Oil Cooler, Dinan Intercooler, Akebono Euro Pads, CDV Removed, Black BMW Grilles, Interior & Exterior white LED lighting, LUX Angel Eyes, Debadged, Blend V1 mount, Llumar ATR Tint.
04-27-2012, 11:54 PM | #4 |
Rep 942
http://www.m3post.com/forums/showthread.php?t=195777
Where I found the DYI mod. Only benefit is the clutch comes up w/out a spring buffering it. that's what BMW calls it... a return buffer spring. Edit- Been doing some research regarding the side-to-side play the clutch pedal has... it's not related to this spring. Looks like it's the pivot bushing and/or the pedal itself. There are some aftermarket pedal bushings that will tighten up the side to side play. I think when you remove the buffer spring it just becomes more noticable. I'm leaving the spring out and going to get the aftermarket bushings.
04-28-2012, 09:20 AM | #5 | |
31
Rep 365
after reading this.. i will be doing this on my day off.
04-28-2012, 10:00 AM | #6 |
Rep 1,023
Wow, never heard of this before. I just installed the "clutch stop" from n54tuning.com, and next week will be doing the clutch delay valve from them as well, hoping to fix these same issues. May have to give this a try after that.
04-28-2012, 06:57 PM | #8 |
24
Rep 592
Drives: JB 335i-M3
both cars have the same spring with the same function, basically your clutch pedal will come back up faster!
04-29-2012, 09:15 PM | #9 |
Rep 942
Drove the car about 200 miles this weekend. No issues. All that spring does is slow the pedal return down. BS. I'm glad I removed it. Onto the side play issue for the clutch pedal which seems to be a rampid issue on all bmw's going back a few generations.
I need to look into this "stop mod" for the clutch pedal also... I didn't look to see if the car has a stop bumper.
04-30-2012, 11:56 PM | #10 | |
Rep 78
http://www.ebay.com/itm/E9X-BMW-CLUT...ht_2728wt_1185 The spring mod is a must |
05-01-2012, 09:10 AM | #11 |
Rep 942
Ok, so someone fill me in on why the stopper is needed vs the OEM??? Doesn't that limit the travel of the pedal and not move the clutch fork as far???
05-01-2012, 09:12 AM | #12 |
31
Rep 365
05-01-2012, 09:25 AM | #13 |
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
The clutch stop made a huge difference for me - amazing improvement, even better than the CDV "delete" and UUC SSK + DSSR. Is this spring removal worth trying?
05-01-2012, 10:30 AM | #14 | ||
Rep 1,023
http://www.burgertuning.com/clutch_stop_BMW.html Quote:
05-01-2012, 10:42 AM | #15 |
Rep 942
hate to say it but the one Ebay looks better. But they both look cheap. I'd like to see something that's bolted with an adjustment nut. Just me 2 cents... SO I need some kind of a stop and a bushing kit. Clutch mods should be done.
05-01-2012, 02:44 PM | #16 | |
Rep 78
05-01-2012, 02:46 PM | #17 |
Rainbow Racer
1008
Rep 2,539
I made my own stopper for $1
I can attest for the spring mod, it certainly made the clutch pedal feel more natural when I did it on my E46 M3
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
05-01-2012, 04:21 PM | #18 |
407
Rep 2,704
Wow, really
Clutch stopper and spring remove You guys sound like your trying to make the clutch a video game pedal I just installed an act clutch and it's stiffer and I love it makes it feel way more sportier and much easier to launch. Must be an Asian thing <---- I know hate me for this one lol |
05-01-2012, 04:56 PM | #20 |
104
Rep 1,529
just did it and it feels great however there is a little more side to side movement now...you really wont notice it pressing in the clutch but when its just sitting there you can wiggle a more side to side.
either way i think this is a great mod and someone else said there is a bushing for the clutch pedal to lessen the movement. you could possibly make something out of pvc piping to go where the spring was and that should help with the side to side movement as this was sort of a support.
Space Gray l 6MT l OSG LSD w/ VAC Race Diff Cover l Cobb e30 l Morr vs8.2 l UUC SSK w/ DSSR l VSRF Catless Dps l RPI Intercooler l CDV Removed l HID AE 8000k l ETS Catback l AST 5200 w/ Vorshlag Camber Plates l ER Dual Oil Coolers l Rear Camber and Toe Arms l K&N Drop In l Solid Tranny/Diff/Subframe Bushings l Bridgestone RE-11
05-01-2012, 06:52 PM | #21 | |
Rep 1,023
05-01-2012, 07:06 PM | #22 |
407
Rep 2,704
