Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > New wheels with existing tires
      04-30-2012, 12:25 AM   #1
335Ike
Drives: '08 MT 335i
For those of you that have put existing tires on new wheels... What should I expect to pay for having the TPMS and stock tires swapped to new wheels? Also, any potential issues I should be aware of when making the swap?
Last question; I shouldn't have any issues putting stock sport package tires on a 18.8.5/18x9.5 set-up, correct?
      04-30-2012, 12:33 AM   #2
#Tee
#Tee's Avatar
560
Drives: yes
Pends on the type of wheel youre planning to run. some can just swap over and some you will need tpms adapters.
no issues on your second question.
You can follow my builds on IG: Tee212
      04-30-2012, 08:35 AM   #3
Gary@TireRack
Moderator
Gary@TireRack's Avatar
Drives: Formerly 1995 M3
Most charge about $20-$25 per tire.
Yes, the stock front 225/40R18 will fit on 18X8.5" wheels and the rear 255/35R18 will mount on 18X9.5" wheels with no problem.
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp
Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum.
      04-30-2012, 11:19 AM   #4
335Ike
Drives: '08 MT 335i
Thanks for the help!
      04-30-2012, 01:27 PM   #5
tanginaglaz
tanginaglaz's Avatar
Drives: 2007 e92 335i
The tires will be stretched.
