COBB 1st experience...Some issues
04-30-2012, 10:23 PM | #1 |
Rep 73
First and foremost I cannot thank this community enough for all the valuable information and insight.
Back story: Took my 07' AT to a track day last year to only be a victim of overheating. Complained long enough to different dealerships and finally found one to agree to put in an oil cooler. Current: So with my oil cooler installed and an upcoming track day coming up I ordered the accessport. Installed stage 1 aggressive on Wednesday and had a blast. The power was great. I did notice at or around 4-5k RPM under WOT the car would seem to drop momentarily a bit of power and then come back really strong. A quick hesitation or loss of full power. No data log (still kind of a noob at this point). Saturday comes and it's day 1 of track weekend. Flash to stage 0 just to give me a baseline if my car would overheat again and to verify if the oil cooler helped. Well about 10 minutes into my first 30 minute session I get the half engine light and reduced power. Thought for sure I had overheated. Checked for codes and P2A87 popped up. Did a quick google/forum search and discovered it hadn't over heated, just a Vanos error. Per some other forum member suggestions, I reset the codes and uninstalled the Cobb. Trying to narrow any variables at this point. 2 more 30 minute sessions with everything uninstalled and I didn't have any issues. No codes, half engine lights, or overheating. Next day I decide to throw on stage 1 aggressive and after about 15 minutes on session 1 Sunday I get the half engine light and reduced power. Checked the codes and had four (P2AAF, P2A87, and P3100, and UODAD {service code for brake pad sensor I think}). I pulled up the boards again and discover that since I have had a new HPFP installed not long ago the P2AAF is something to essentially ignore. My concern is now just the Vanos codes. Is this an issue with the tune or did it just highlight an already slowly failing Vanos solenoid? Uninstalled the tune and cleared codes and went out for session 2 to only have the half engine light and P2A87 pop back on. So now I'm thinking it's probably truly a failing part and I left the code intact so I can schedule a service appointment and have it addressed. So you could imagine my displeasure for my overall weekend and started to blame the accesport I installed. So here I am, perplexed. I don't imagine it's any fault of the tune, rather an aging car (58k miles) and aging parts. I expected this may highlight any weaknesses with the car. So to my questions: What was the surge in power I experienced? I also noticed it on the track over the weekend with a good 100 miles since it was originally installed. I’m sure it’s impossible to comment without looking at a data log. Would the beta v. 4 maps elevate any of what I’m experiencing. Should I just expect to have codes thrown a lot and experience half engine reduced power? I certainly will have BMW service the Vanos code. When I get the car back from BMW and have them address the P2A87 can I post a log of a hard 3rd to 4th pull to be analyzed by you all to see if you detect any issues? What is the best/preferred method for acquiring a log file? 3rd-4th? 0-X MPH. A few hard pulls through all gears? Again, thank you all for this powerful resource of information. I am ecstatic with the gains in performance, just want to make sure it’s going to be a long and enjoyable one.
2007 335i
04-30-2012, 10:37 PM | #2 |
70
Rep 2,197
VANOS failures are a fairly common occurence and are just a quirk of the car(as are HPFP related issues.) The surge you described is more than likely the surge that v3.01 was notorious for. V4xx maps have smoothed out significantly.
04-30-2012, 10:43 PM | #3 | |
Rep 73
Thanks...I will try out the v.4 maps soon.
2007 335i
05-01-2012, 12:19 AM | #5 |
Rep 2,626
I had this issues when my car was around 45k. replaced the Vanos solenoids (both actually) and car ran like a champ. Haven't had one limp mode occurrence in the past 30k miles
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar.
'05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT COBB, FBO, st2 LPFP, Mfactory LSD | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
05-01-2012, 09:45 AM | #11 | |
Rep 73
2007 335i
05-01-2012, 10:00 AM | #12 |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
Vanos codes can be a simple as the solenoids, or it can be the cam bearing ledges (I had this repaired on mine under warranty). Both are known issues.
05-01-2012, 10:12 AM | #13 |
79
Rep 2,396
Drives: '08 E90 335i
Not to introduce a new problem, but I hope that if you were running the Aggressive map that you were at least putting 93 octance in your tank... And do you have any other mods on the car?
05-01-2012, 10:59 AM | #14 |
Rep 73
No other mods and yes I was using 93 octane.
2007 335i
05-01-2012, 11:24 AM | #15 |
79
Rep 2,396
Sounds like you need to make a service appointment & hope that its just a sensor. I'd also recommend that if you're going to keep putting your car on a track that you make some supporting mods -- upgrade your intake & your FMIC to increase your airflow and cooling. You're putting a lot of stress on the car if you're tracking an auto-trans (not the DCT trans either) car with just a tune & nothing else.
05-03-2012, 07:26 PM | #16 |
Rep 73
Got my car back today and BMW replaced the Vanos solenoids. Before I reinstalled I noticed two codes. H2A87 and H3100. All my searches came up empty on what the code is. Any thoughts?
2007 335i
05-03-2012, 10:23 PM | #17 | |
Rep 270
Do a search, seems to be a common issue actually. Many have also solved the issue by cleaning the solenoids with compressed air. Lucky mine was fully covered under my platinum extended warranty Edit: They may have forgotten to clear the codes after replacing the solenoids, my best guess. Clear them and drive hard to see if it shows up again. |
05-03-2012, 11:48 PM | #18 | |
Rep 2,626
About your search coming out empty, when you get codes that start with H, take the H out and search
05-04-2012, 04:56 AM | #19 |
Rep 1,247
I had the same vanos code P2A87 I believe it is. I cleared the code and it hasnt come back since. I didnt replace or clean the vanos solenoids. So hopefully they are ok. I have like 37,300 miles on my car and Im guessing parts will start to wear, especially with a tune installed.
2009 E92 BMW M3.
